#533 | |
#534 |
#535 | |
That Guy
Drives: 2013 asphalt FRS MT
I've been thinking about asking the same question though, so, @gmsii how many teeth are on both gears. Or if you feel like saving us the time of doing the math, what did you end up with for a supercharger impeller rpm at 7450 engine crankshaft rpm? And Mike, do you know the supercharger impeller rpm for the JR kit. |
#536 | |
Drives: 2013 BRZ, WRB
Looking at DA's pics, I think I see 30T(-75mm?) on the small cog and 40T on the big one. |
#537 |
Oh, I forgot the belt system is independent. I suppose I'll be counting the teeth. Be back in a minute.
*edit* Okay, I can't see all the teeth, and I don't have a kit on hand to do any math. @gmsii: What RPM is the supercharger spinning at redline with the included pulley? |
#538 |
#539 |
Drives: 2013 BRZ, 2002 WRX
Being as though they recommend a redline of 7800 RPM, that may tell you what the rotational speed is at that point. Dunno if they've put some wiggle room in there. I have no clue.
#540 |
Perhaps the parts sheet has what you need:
#541 |
Crank pulley 100mm, Rotrex pulley 75mm. Got it. Not sure why it was so difficult for them to just tell me that... brb after I do some quick math.
3 rotations on crank = 4 rotations on Rotrex. Essentially, 1.33 multiplication. Teeth counts confirm, 30 vs 40. 7800 RPM redline * 40 teeth / 30 teeth = 10400 impeller RPM. The Rotrex C30-94 is spec'ed out for 10500 impeller RPM. Essentially, the blower is maxed out with the Kraftwerks kit, at the 7800 RPM that Kraftwerks recommends (per the post above). I'm guessing the 7300RPM redline pulley is a 38 tooth pulley/71mm pulley?? Last edited by CSG Mike; 12-19-2013 at 06:45 PM. |
#542 | |
yes, blower is close to being maxed out at 7800rpm, but kit performance is not maxed out by any means....we will be offering a pulley upgrade shortly that will change the power delivery quite dramatically
#543 |
Drives: White 2013 FRS
Would it make sense to wait for C38 kit for those of us that want higher power numbers on stock internals? Planning on WMI w 93 octane and upgraded fuel system.
#544 |
we'll be releasing preliminary test data soon enough for you to make that determination...keep an eye out
| The Following User Says Thank You to gmsii For This Useful Post: | OjiGeorge (12-19-2013) |
#545 |
Only if you have the supporting mods for that kind of output (Transmission, axles, etc). The base kit is plenty of power...
#546 |
Can't seem to stop spending money on the car, so the supporting mods are sure to follow. ATM trying to reduce the risk of buying a system that will not be able to keep up with future mods. It will likely come down to the the KW or the AVO kit. Both because Drift Office is relatively close, and has experience with tuning both of these kits.
| The Following User Says Thank You to OjiGeorge For This Useful Post: | sw20kosh (12-19-2013) |
| [TX] DFW General Discussion | feedbag | Southwest | 1488 | 06-18-2022 07:25 PM |
| HKS GT Supercharger (Rotrex) in development! | madfast | Engine, Exhaust, Transmission | 206 | 12-14-2012 03:28 PM |
| ROTREX SC Brainstorming | MANDALAY | Forced Induction | 61 | 12-11-2012 05:57 PM |
| Rotrex kit - why no build? | MindtheGap | Engine, Exhaust, Transmission | 5 | 10-26-2012 07:01 PM |
