Old 12-19-2013, 12:43 PM   #113
pmccut
Drives: Blue Subarus
Originally Posted by FullBlown View Post
The shrouds are done. There will be an option for SPAL 12" fans as well.
Take my money!
'13 GBS BRZ 6MT | FBM 9:1 w/ GTX3076R| FBM oil cooler + catch-can + radiator + SPAL fans| Rays 57xtreme / PSS | Perrin 2.5" FP | Invidia 2.5" OP | Perrin 3" CBE | RCE T2s | Exedy Stg1
'15 STI LE | Cobb Stg1
pmccut is offline   Reply With Quote
Old 12-19-2013, 12:46 PM   #114
FullBlown
FullBlown's Avatar
Drives: Scion FRS
Originally Posted by pmccut View Post
Take my money!
haha, I will PM you about it bud.
FullBlown is offline   Reply With Quote
Old 12-19-2013, 01:24 PM   #115
mike the snake
It looks to me like the shroud will space the fans back a bit compared to their radiator-only mounting positions.
I have the larger Robispec radiator, and now, one of the fans has maybe 1mm clearance between the fan and the downtube with my FB stage 1 turbo kit. Not enough room to run the shroud as things sit presently.
There's a few points with this kit where things are dangerously (IMO) close to the downtube. The lines to the turbo, the fans, and intake tube all run very close to the downtube.
I'm planning on wrapping these parts with that gold heat shield stuff, as well as dealing with the engine bay heat with fender garnish vents, and possibly vented hood.
We're going to check the heat and see before I cut the front mouthpiece from the grill area. The crashbar and opened up grill will be a later project, after I deal with exhausting the engine bay heat..
Old 12-19-2013, 01:35 PM   #116
FullBlown
FullBlown's Avatar
Drives: Scion FRS
in comparison to a stock rad, is the thickness of your radiator towards the front of the car or towards the engine?
Old 12-19-2013, 03:19 PM   #117
kmbkk
First 86 Driver Baby!
kmbkk's Avatar
Drives: FR-S, Flex
Originally Posted by Brody602 View Post
I've been told that the Seibon VS hood would be most effective since it is properly louvered, originally I thought the TS would be better, but apparently the VS would be most effective.
I have the VS hood installed on my car and can easily see how well the heat dissipates through the vent. My turbo kit (Treadstone) is top-mounted like the FBM kit and the turbo sits directly under the vent. I also have a Koyo radiator I'll be installing, along with the Forester OEM oil cooler.
kmbkk is offline   Reply With Quote
The Following User Says Thank You to kmbkk For This Useful Post:
Brody602 (12-19-2013)
Old 12-19-2013, 03:27 PM   #118
toekneehair
toekneehair's Avatar
Drives: 2013 Subaru BRZ/FBM turbo flexfuel
What's the difference in flow rate between the SPAL fans and the ones from your kit? Also do you have any data supporting any improvements in air flow or cooling efficiency? Just trying to see how much improvement we will see here I know it will be better... You will be getting a payment from me soon for one. Just dropped a bunch on a flex fuel kit so it looks like next paycheck lol.
toekneehair is offline   Reply With Quote
Old 12-19-2013, 04:03 PM   #119
pmccut
Interested to know as well. I'll be sure to take it to the track for a comparo. Would be nice to complete a full session without coasting through straights
Old 12-19-2013, 04:13 PM   #120
FullBlown
FullBlown's Avatar
Drives: Scion FRS
The fans that we provide flows 1150cfm
Spal fans depending on thickness will flow 1300cfm and up. We have a few on order to see which ones will work. We will also will be testings the fans that we provide with the shroud as well.
Old 12-19-2013, 04:16 PM   #121
8686
8686's Avatar
Drives: 86
any idea about the stock fans cfm?
VOLK LE37 17X7.5, SWIFT Springs, Bilstein B8, HKS intake duct, Cosworth Air Filter, HKS headers, PLM Over Pipe, EVS Down Pipe & Exhaust, FD 4.55, GFB pulleys, Axle-Exchange Drive Shaft, Mishimoto oil cooler, Cusco F&R strut bar, TRD door stabilizer, Innovate SC, Delicious Tuned
8686 is offline   Reply With Quote
Old 12-19-2013, 04:30 PM   #122
toekneehair
Ok so sounds like a 10% or so increase on each fan. Or a little more. I think I found one that was like 1800 cfm but that looked a bit thick and that could be an issue. Keep us posted on your findings. The shrouds look good
I know it might be a little bit of work but could we possibly find a way to move the radiator a little more forward? We might need to use different radiator tubes but if we can gain a few inches more of clearance that could really help combat some of the direct radiant heat.
Old 12-19-2013, 04:37 PM   #123
FullBlown
FullBlown's Avatar
Drives: Scion FRS
The radiator can go forward more if you slot the upper brackets or make new ones. Not much but there is room
Old 12-19-2013, 04:49 PM   #124
mike the snake
I'm almost positive it's backwards, towards the engine, which pushes the fans back towards the downpipe.
On my car, the backside of one of the fan motors is 1mm from the downpipe. No room at all, and I expect the fan to get melted by the downpipe.
I'm going to wrap the downpipe with that gold shielding material, and slip a piece of heat shield material between the fan motor and downpipe and hopefully that will help.
Old 12-19-2013, 05:18 PM   #125
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
You can't wrap the downpipe in gold shielding material. The gold material is for protecting things from the heat not the thing producing the heat. Get a good header wrap and wrap the downpipe and then put the gold shielding on the intake pipe. Or between the wrapped downpipe and fans.
Old 12-19-2013, 05:44 PM   #126
toekneehair
Is it limited by the body and brackets or by the tubing to the radiator? If I remember correctly besides the location of the brackets the area seemed pretty open and it looked like at least an inch or two until you would hit the intercooler.
any serious benefit Heat Tapes? Djen Engine, Exhaust, Transmission 22 02-18-2014 03:20 PM
Heat bad for your car? Ways to cool it? BushMan Scion FR-S / Toyota 86 GT86 General Forum 35 08-01-2013 10:15 PM
Misfire with heat? bigjake Issues | Warranty | Recalls / TSB 2 04-28-2013 09:02 PM
Do I Need a Heat Shield? arleewa Engine, Exhaust, Transmission 1 01-08-2013 06:37 AM
Overpipe Heat question Amadeus Engine, Exhaust, Transmission 5 12-19-2012 01:18 AM
