#99 | |
Drives: 2013 Subaru BRZ/FBM turbo flexfuel
Can the fender liner really cause that much of an issue? I had one of mine pop out after getting caught on a curb then somewhat burned off. so I have a big hole behind my oil cooler right now. I thought that would help air either way so I wasn't to concerned when I found it. how does it create pressure inside the engine bay? |
#100 |
Drives: Hydra EMS Powered FRS Raven Black
At low speeds no, but at high speed absolutely. The pressure from the rotating tire is massive which is why you see such massive vents on top of the fender and huge exits on the rear of race cars.
#102 | |
Don't overlook the obvious and that low splitter reduces under car pressure substantially which helps exit engine bay pressure. |
#103 |
Which aftermarket hood do you think would be the best at reducing engine bay temps?
From reading here, one with vents more towards the front? |
#104 |
Which hood, I haven't looked too much at what's available. After we are done building our engine etc. I'll make a decision to either buy something or work with the OEM hood. The vent over the turbocharger would be great for street cars since it will dump turbo/exhaust heat out instantly but at speed it doesn't have to be there unless you are ducting the radiator (hard to do with a turbo kit there).
#105 |
Drift King
Drives: '13 Firestorm FR-S 6MT
I've been told that the Seibon VS hood would be most effective since it is properly louvered, originally I thought the TS would be better, but apparently the VS would be most effective.
'13 6MT Firestorm FR-S
#106 | |
Drives: 2013 Raven FRS
That's what I have been led to believe as well.
#107 |
The VS hood has a proper "trip lip" in front of the vent to cause more suction, and the vent itself is located in front, right over the turbo (on the FB kit), so air should flow up and across the turbo and out=ideal.
There was one or two other hoods that looked like they'd be pretty functional as well. |
#108 | |
Drift King
#110 |
Drives: Scion fr-s
Nobody talked about Davies craig electri water pump conversion.. Or at least Evan's cooling coolant.
Davies Craig water pump: http://www.daviescraig.com.au/Electr...s-content.aspx Evan's cooling solution:http://www.evanscooling.com/ |
#111 |
OK, which do you think would be best between these two?
http://www.modbargains.com/seibon-ca...od-frs-brz.htm http://www.modbargains.com/seibon-ca...od-frs-brz.htm |
#112 |
Drives: Scion FRS
| The Following 8 Users Say Thank You to FullBlown For This Useful Post: | Brody602 (12-19-2013), Dipstik-sportech (12-19-2013), mack4477 (12-19-2013), OICU812 (12-19-2013), OjiGeorge (02-17-2014), pmccut (12-19-2013), Sportsguy83 (12-19-2013), TRD_07 (12-19-2013) |
| any serious benefit Heat Tapes? | Djen | Engine, Exhaust, Transmission | 22 | 02-18-2014 03:20 PM |
| Heat bad for your car? Ways to cool it? | BushMan | Scion FR-S / Toyota 86 GT86 General Forum | 35 | 08-01-2013 10:15 PM |
| Misfire with heat? | bigjake | Issues | Warranty | Recalls / TSB | 2 | 04-28-2013 09:02 PM |
| Do I Need a Heat Shield? | arleewa | Engine, Exhaust, Transmission | 1 | 01-08-2013 06:37 AM |
| Overpipe Heat question | Amadeus | Engine, Exhaust, Transmission | 5 | 12-19-2012 01:18 AM |
