| Northern California NorCal |
Drives: 10 series FRS
10 series fog light help
Is anyone know where to tap the positive switch wire for the fog light on the 10 series inside the driver side cabin?
#2 |
86 Noob
Drives: Firestorm FR-S
Don't want to tap into the low beams? You can add an add-a-circuit to the fuse box if you mean the power wire from the switch. As far as switched power sources from the stereo I am not sure
Sent from my SAMSUNG-SM-N900A using Tapatalk
| The Following User Says Thank You to Noob4Life For This Useful Post: | QT0843 (12-18-2013) |
#3 |
Undisputed El Presidente
Drives: Zenki 37J ZN6
If you have a multimere just start testing wires in that area. The important thing is to tap it to an acc wire so that it not constantly drawing power. I need to do mine this weekend prob and will let you knkw what wire I tap, should be able to use the same one in that area of the dash at least.
| The Following User Says Thank You to finch1750 For This Useful Post: | QT0843 (12-18-2013) |
#4 | |
#5 |
Drives: 2013 Scion FRS
Easiest way. Use one of these and tap into the fuse box. Acc or lights of course.
| The Following User Says Thank You to RC51ed For This Useful Post: | QT0843 (12-18-2013) |
#6 | |
When you tap this way, when engine turn off is the line still have power? Sent from my iPhone using Tapatalk |
#7 | |
Only if you tap in to a fuse that has power all the time. Just choose one that doesn't.
#9 | |
Unfortunately I only have the one for the full size fuses. You might try one the higher end stereo shops. Or search under "fuse tap" on eBay. Etc.
#10 | |
I just went to pep boys and pickup one Sent from my iPhone using Tapatalk |
#11 | |
Cool, I didn't know they carried it there.
#13 |
| The Following User Says Thank You to QT0843 For This Useful Post: | Krispeee (12-23-2013) |
#14 |
Codename: Stitch
looks really good Qui. can you still turn on the halos separate from the fogs or only all them at once?
| The Following User Says Thank You to PMok For This Useful Post: | QT0843 (12-22-2013) |
| Has anyone removed the 10 Series Light up Emblems yet? | Starkiller | Cosmetic Modification (Interior/Exterior/Lighting) | 58 | 01-17-2021 02:04 PM |
| Zeta Performance - Lights (HID, LEDs, LED Taillights, LED Reverse Light, Trunk Light) | ZetaPerformance | Exterior Parts - Lighting | 172 | 11-13-2015 10:25 AM |
| SERIES 10 FR-S Fog Light Kit | Ishii Motors | Exterior Parts - Lighting | 8 | 12-06-2013 02:34 AM |
| For Sale: Smoked/Red/Clear Reverse Light + Brake Light Bars Brand New! | Vicious LED | Exterior Parts (Aero, Lighting, Etc.) | 9 | 08-25-2013 07:26 PM |
| 10 Series are Release Series | kALMIGHTY | Scion FR-S / Toyota 86 GT86 General Forum | 4 | 04-30-2013 08:23 AM |
