Northern California NorCal
Old 12-18-2013, 05:07 PM   #1
QT0843
QT0843's Avatar
Drives: 10 series FRS
10 series fog light help
Is anyone know where to tap the positive switch wire for the fog light on the 10 series inside the driver side cabin?
QT0843 is offline   Reply With Quote
Old 12-18-2013, 05:10 PM   #2
Noob4Life
86 Noob
Drives: Firestorm FR-S
Don't want to tap into the low beams? You can add an add-a-circuit to the fuse box if you mean the power wire from the switch. As far as switched power sources from the stereo I am not sure
Sent from my SAMSUNG-SM-N900A using Tapatalk
Noob4Life is offline   Reply With Quote
The Following User Says Thank You to Noob4Life For This Useful Post:
QT0843 (12-18-2013)
Old 12-18-2013, 06:48 PM   #3
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
If you have a multimere just start testing wires in that area. The important thing is to tap it to an acc wire so that it not constantly drawing power. I need to do mine this weekend prob and will let you knkw what wire I tap, should be able to use the same one in that area of the dash at least.
QT0843 (12-18-2013)
Old 12-18-2013, 06:57 PM   #4
QT0843
QT0843's Avatar
Let me know, I have the push start ignition and I was follow the thread where they tap into the Green/Yellow Ignition wire but when I open up the side panel on the drive side for my car. I did not have that wire so I am stuck. I was wonder is it the wire required a 12V?
Old 12-18-2013, 07:00 PM   #5
RC51ed
RC51ed's Avatar
Drives: 2013 Scion FRS
Easiest way. Use one of these and tap into the fuse box. Acc or lights of course.Name:  ImageUploadedByTapatalk1387407598.899500.jpg
RC51ed is offline   Reply With Quote
The Following User Says Thank You to RC51ed For This Useful Post:
QT0843 (12-18-2013)
Old 12-18-2013, 11:06 PM   #6
QT0843
QT0843's Avatar
Originally Posted by RC51ed View Post
Easiest way. Use one of these and tap into the fuse box. Acc or lights of course.Attachment 60439
When you tap this way, when engine turn off is the line still have power?
Old 12-18-2013, 11:11 PM   #7
RC51ed
RC51ed's Avatar
Only if you tap in to a fuse that has power all the time. Just choose one that doesn't.
Old 12-18-2013, 11:38 PM   #8
QT0843
QT0843's Avatar
Do u have one for sale
Old 12-18-2013, 11:54 PM   #9
RC51ed
RC51ed's Avatar
Unfortunately I only have the one for the full size fuses. You might try one the higher end stereo shops. Or search under "fuse tap" on eBay. Etc.
Old 12-19-2013, 12:45 AM   #10
QT0843
QT0843's Avatar
I just went to pep boys and pickup one
Old 12-19-2013, 12:46 AM   #11
RC51ed
RC51ed's Avatar
Cool, I didn't know they carried it there.
QT0843 (12-19-2013)
Old 12-21-2013, 11:22 AM   #12
QT0843
QT0843's Avatar
Finish wiring tap into lighter wire look awesome
The Following User Says Thank You to QT0843 For This Useful Post:
PMok (12-21-2013)
Old 12-22-2013, 10:33 PM   #13
QT0843
QT0843's Avatar
Attachment 60910
Here is how it look
Krispeee (12-23-2013)
Old 12-22-2013, 11:19 PM   #14
PMok
Codename: Stitch
PMok's Avatar
looks really good Qui. can you still turn on the halos separate from the fogs or only all them at once?
The Following User Says Thank You to PMok For This Useful Post:
QT0843 (12-22-2013)
Has anyone removed the 10 Series Light up Emblems yet? Starkiller Cosmetic Modification (Interior/Exterior/Lighting) 58 01-17-2021 03:04 PM
Zeta Performance - Lights (HID, LEDs, LED Taillights, LED Reverse Light, Trunk Light) ZetaPerformance Exterior Parts - Lighting 172 11-13-2015 11:25 AM
SERIES 10 FR-S Fog Light Kit Ishii Motors Exterior Parts - Lighting 8 12-06-2013 03:34 AM
For Sale: Smoked/Red/Clear Reverse Light + Brake Light Bars Brand New! Vicious LED Exterior Parts (Aero, Lighting, Etc.) 9 08-25-2013 08:26 PM
10 Series are Release Series kALMIGHTY Scion FR-S / Toyota 86 GT86 General Forum 4 04-30-2013 09:23 AM
