Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > FT86CLUB Shared Forum > Regional Forums > AFRICA
Old 12-18-2013, 03:52 AM   #15
sav
Official anti-BS squad
sav's Avatar
Drives: Toyota 86 High 6MT
Originally Posted by Moe View Post
Interesting topic.
Quick question: At altitude (Gauteng specifically), is there any difference between 93 and 95 on these cars?
Car runs on 98 but 95 minimum.
Toyota 86 High 6MT (Satin Pearl White)
95RON SAV Tuned
sav is offline   Reply With Quote
Old 12-18-2013, 06:49 AM   #16
Fuzz
Drives: '13 Toyota GT86 , VW Chico "1.4"
as mentioned to the CPT guys earlier, fuel differs from day to day and station to station.
I run Shell from the same garage and today the car is pinging in the heat while other days its not pinging.
As per my datalogs from my Honda's Hondata EMS, fuel quality is totally variable day to day, station to station. One day logs will add timing +10deg from a station, a week later it will retard -10deg from the exact same station.
All the garages in the same area use the same base fuels. Their additives do differ though.
I use Shell and Engen as I believe their additive packs are best regarding keeping the engine, valves and injectors clean
Fuzz is offline   Reply With Quote
The Following User Says Thank You to Fuzz For This Useful Post:
Jacques Blom (01-07-2014)
Old 01-06-2014, 09:53 AM   #17
Fuzz
OK, update on my findings.
Been using Shell in Epping for a while and noticed a gradual increasing in pinging. Very apparent on the hot days we had recently.
Ran my tank almost dry and used Engen from 2 different stations in similar conditions and driving styles.
With Engen, zero pinging regardless of how I drive and regardless of how hot it gets outside.
I will therefore be sticking to the same Engen stations.
Old 01-07-2014, 12:36 PM   #18
Vladror
Vladror's Avatar
Drives: Toyota 86 M High - Dark Grey
I've been driving (only) a day now with Liqui Moly Octane plus in the tank and early observations are that's it's like driving with real butter in the tank (and that's a good thing btw). the throttle response is so much smoother whether in gear or shifting gear...
I've been getting a bit of a short 'buzz' sound from the engine recently when pushing the throttle abruptly (like the engine gets too much or too little petrol - if anyone has any ideas what that could be?) but that's all gone now. I haven't noticed the alleged power gain but the engine just feels so much happier that i'm considering using liqui moly all the time, despite it costing nearly R100 a can.
Vladror is offline   Reply With Quote
Old 01-07-2014, 02:28 PM   #19
Vic_RSA
The voice of reason...
Vic_RSA's Avatar
Drives: 2012 Toyota 86 6MT Standard
I also use Liqui-Moly Octane plus from time to time. Your description of butter in the tank is spot on - I found it much smoother. I'm still a skeptic with these boosters and the longevity of my spark-plugs so I use it only on breakfast runs etc. Is that buzz more like a crrrr (not crunchie ad lol!)? Could be pinging...
I fill up with Engen (close to home) yet I still notice some pinging between changes (especially uphill) after sitting in traffic for a while on a hot day.
Shell Nitro was a letdown for me. Have used Caltex - nothing special but not bad either. Sasol seems to be one of the better options but I have yet to use it over an extended period.
Vic_RSA is offline   Reply With Quote
Old 01-07-2014, 02:48 PM   #20
Vladror
Vladror's Avatar
i reckon you could describe it as a 'crrrr' too for just a fraction of a second after you push the throttle, yet not every time.
can anyone point me to a sound clip of what pinging is supposed to sound like?
I fill up at the same station most of the time (caltex) but it's only the last six weeks or so i've been hearing that sound.
Old 01-08-2014, 05:36 AM   #21
Jacques Blom
Turbo 86
Jacques Blom's Avatar
Drives: Toyota 86 Turbo
Hi think the opposite is posible .. as the boosters should improve on the plug as we are running below the needed RON the plug burns away.. as in my pref post 30 000 k and the cylinder one plug was gone.. so either run a colder plug or ge the boost to help.. Would like so hear some of the other technical experts view on this ..
I will do a water \ meth kitt in FEB .. to help with my turbo and give me a safety... will also try the booster..
Jacques Blom is offline   Reply With Quote
Old 01-08-2014, 05:50 AM   #22
Fish Eagle
Platinum Member
Fish Eagle's Avatar
Drives: Toyota 86 Vortech SC
Part of my SC conversion was colder plugs.
That was at 23000 kms, and my original plugs were fine.
Fish Eagle is offline   Reply With Quote
The Following User Says Thank You to Fish Eagle For This Useful Post:
Vic_RSA (01-09-2014)
Old 01-09-2014, 02:14 AM   #23
Jacques Blom
Turbo 86
Hi Fish Eagle , what plug are you using now and waht boost do you get on the SC ? = KW and Torque.. I would like to compare notes .. I am on a .05 boost and getting 175 KW 300 NM ... Would like to go up to .07 in the next month or so ?
Old 01-09-2014, 03:25 AM   #24
Ryan86
Road Warrior
Ryan86's Avatar
Drives: Toyota 86 Satin Pearl White
Jacques did lose coil pack on cylinder 1???
Ryan86 is offline   Reply With Quote
Old 01-09-2014, 03:33 AM   #25
Fish Eagle
Platinum Member
Fish Eagle's Avatar
I don't know the tech details of the plugs I've got now, but I know that RGM replaced the stock plugs with colder ones.
I'm running 0.5 bar which gives me 168wkw and 317nm
Old 01-09-2014, 04:38 AM   #26
Jacques Blom
Turbo 86
Hi Ryan , was just the plug.. will take a picture and share .. noticed the same experience in the other regions running a 95 RON on the forum.. where about 15 000 mile the plugs give a prob .. funny also plug 1 .. challenge to change the plugs is not a 5 min jobie..and with the Turbo .. will Toyota support me ?
Good word for the Athlone Toyota team .. replace my plugs just paid for the plugs.. all well and the car is running good now.. Must get it back to Dino as she spins now hard in 2nd .. so I am sure I gained a lot in KW by plug replacement.
The Following User Says Thank You to Jacques Blom For This Useful Post:
Matt_RSA (01-10-2014)
Old 01-11-2014, 04:52 PM   #27
Jacques Blom
Turbo 86
Here with the plugs....left is no 1... That gave the misfire.
Old 01-11-2014, 11:57 PM   #28
Ryan86
Road Warrior
Ryan86's Avatar
That plug certainly does not look good.
What was the cause of the failure?
all season high performance or winter performance tires? Aloxi NY / NJ / CT / PA 29 03-24-2015 09:23 PM
Can an NA FA20 produce exhaust burble/pop? FR-Slide Engine, Exhaust, Transmission 27 08-16-2013 12:38 PM
So what exactly will aftermarket feul injectors do to my frs Frsexxxy Engine, Exhaust, Transmission 8 03-10-2013 12:28 PM
