Old 12-17-2013, 05:37 PM   #1
husker741
Drives: 2013 Whiteout Scion FR-S 6MT
People who got the new AC drop TSB or injector seal TSB, you are needed.
Got my car back yesterday. It seems like there is a louder "air" noise with he engine now. The transmission was replaced, but I don't think that should effect this noise. I know it's the engine and not the good or anything because if I'm in neutral at 45, I don't hear the sound. But if I'm holding the engine at higher RPMs, I can hear the "airy" noise.
So my question is could this be related to the reprogramming of the ECU for those TSBs? It had both performed on it. I don't know if it just sounds different because of different air flow or what. And also, it does it with the AC on or off.
The sound is kind of like wind noise, but I know it isn't wind noise. It is the engine, not the hood.
husker741 is offline   Reply With Quote
Old 12-17-2013, 05:41 PM   #2
Fett4Real
AKA Mugen Dom
Fett4Real's Avatar
Drives: 2013 FR-S, 2007 FJ Voodoo Blue
Could be any number of things with all the intake and exhaust mods you have...
Fett4Real is offline   Reply With Quote
The Following User Says Thank You to Fett4Real For This Useful Post:
strat61caster (12-18-2013)
Old 12-17-2013, 05:43 PM   #3
husker741
Never heard it until after I got it back from the dealer. Mods had been on for thousands of miles.
Old 12-17-2013, 05:47 PM   #4
Fett4Real
AKA Mugen Dom
Fett4Real's Avatar
You said you had the tranny swapped out...thing the exhaust didnt get removed when they did that?
Old 12-17-2013, 05:50 PM   #5
feldy
feldy's Avatar
Drives: 2013 FRS Asphalt
Could be a exhaust leak
2013 Scion FR-S AT Picked up 5/30/2012
feldy is offline   Reply With Quote
Old 12-17-2013, 05:51 PM   #6
husker741
Well shit, I guess I didn't think of that. I was under the car yesterday tightening up a flange that I replaced and everything looked ok. I mean, the sound doesn't sound bad, it just sounds different than it did before the car went in.
Old 12-17-2013, 05:52 PM   #7
husker741
It's up in the engine bay so it could only really be the overpipe to header flange, or maybe the front pipe to overpipe. But it sounds higher than that.
Old 12-17-2013, 05:53 PM   #8
husker741
Rare triple post...
Maybe it's actually normal now and something was leaking before hand?
Old 12-17-2013, 05:59 PM   #9
AznBRZer
Drives: 16 CBS WRX Limited
[ame="http://www.youtube.com/watch?v=9J9haehfQeg"]Ghostbusters theme song HD - YouTube[/ame]
AznBRZer is offline   Reply With Quote
The Following User Says Thank You to AznBRZer For This Useful Post:
husker741 (12-17-2013)
Old 12-17-2013, 09:46 PM   #10
darthwong1138
Drives: Raven FR-S
There is a TSB now for injector seals?
darthwong1138 is offline   Reply With Quote
The Following User Says Thank You to darthwong1138 For This Useful Post:
Old 12-17-2013, 09:48 PM   #11
husker741
Only if your car has the symptoms.
Old 12-17-2013, 09:52 PM   #12
darthwong1138
Drives: Raven FR-S
When did it come out? I had my seals replaced 2 months ago but I don't believe they did any programming.
Old 12-17-2013, 09:53 PM   #13
husker741
No clue when it came out.
Direct Injector Seal Installation | Video and Issues Dezoris Engine, Exhaust, Transmission 234 03-07-2023 01:20 AM
Driver's side window seal/door seal KAB-FRS Issues | Warranty | Recalls / TSB 255 01-01-2021 06:09 PM
Injector / seal failure or Miss-fire codes.. please post here mad_sb Engine, Exhaust, Transmission 378 04-24-2020 06:33 PM
Portland people meet with Seattle area people before going into ForumFest 2013? stockysnail Northwest 24 06-18-2013 06:19 PM
Suggestions needed for a good quality coilover + lots of drop HiiiPwrFRS Suspension | Chassis | Brakes -- Sponsored by 949 Racing 3 01-01-2013 06:48 PM
