CANADA Canada
Old 12-16-2013, 10:07 PM   #1
Fallen43
Drives: Sliver FRS done the way I like it
Good shop to do Coilover install
Lookimg for a good shop in the GTA/ Mississauga to do my Coilover install , and that will set them up correctly and that I won't have any issues later .
Thanks
Richard
Fallen43 is offline   Reply With Quote
Old 12-16-2013, 10:08 PM   #2
kALMIGHTY
Drives: TRD Ultramarine '13
Might Car Mods.
Old 12-17-2013, 07:33 PM   #3
l8apexr
l8apexr's Avatar
Drives: hybrid + racecar + FR-S
have you tried Cyrious Garageworks? Scion Canada's drift FR-S driver?
Team Lexus IS300 race car
'14 Lexus RX450h Sport Design daily driver
'14 FR-S fri/sat/sun car: SARD LSR wing, Downforce front lip, Mann Engineering dampers, TRDsways, Milltek xhaust, AEM Intake, RAYS 57xtreme, OnPoint Dyno ECUTek tuned: +30rwhp!
l8apexr is offline   Reply With Quote
Old 12-21-2013, 05:14 PM   #4
DR 86
DR 86's Avatar
Just do it yourself and get a proper alignment and corner balance after. The setting up will be done with a proper corner balance. Literally took an hour to do all four on jack stands.
Perrin CAI|Perrin MCB|P&L header|Motiv OP/FP|MXP catback|Tein Type Flex coilovers|Eibach F/R sway bars|GS front strut brace|Street:PM HC+800/Track:Carbotech XP10|StopTech slotted rotors/SS lines|SBC RPF1s|Street:FK453/Winter:Pirelli SottoZero3/Track:Toyo R888s|Leg Sport rear spoiler|EcuTek Tuned|OEM oil cooler|4th/F1 brake lights
DR 86 is offline   Reply With Quote
Old 12-22-2013, 08:26 PM   #5
rb123
rb123's Avatar
Drives: 2013 Scion FR-S Firestorm MT
teknotik!
rb123 is offline   Reply With Quote
Old 12-23-2013, 06:59 PM   #6
CreinCrein
i-garage in markham. very reasonable price and they get it done on the same day you bring it in.
CreinCrein is offline   Reply With Quote
Old 12-24-2013, 09:42 AM   #7
fenixv8
fenixv8's Avatar
Drives: 1991 Acura NSX, 2013 Scion FRS
Speedstar if you want it done right
1991 BB NSX . 2013 WO FRS . 1978 Yamaha SR500
fenixv8 is offline   Reply With Quote
Old 12-24-2013, 10:04 AM   #8
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
CanJam
CanAlignment
Teknotik
installing is easy, corner balance/alignment is what takes time.
but make sure you know what you want the car to do... and understand the limits/pros/cons of your choice of coilovers.
Old 12-24-2013, 06:07 PM   #9
krayzie
Drive From Home
krayzie's Avatar
Drives: BRZ STI Performance
Corner balance and alignment is actually not the hardest part. The real hard part is to first get the ride height and the various adjustments to the shock cartridge right for your intended application.
For this car the best starting point for ride height is 15mm lower than stock, and go from there.
Unless you bought them to slam the car for show then just disregard what I said above.
BTW Ivan @ iGarage seems to get recommended everywhere. They did my STI pink springs and the job was great (no clunking on turns or anything). I'm waiting for Toyota to release the 86 By Tada Handling Pack so I can get those Sachs shocks to go with my springs, will probably go back to this shop.
krayzie is offline   Reply With Quote
Old 12-25-2013, 12:11 PM   #10
df.dima
Drives: FR-S and Mazda 3 Sky
Scott @ CanAlignment is great, but you need to know what you want, not a bad idea to specify alignment specs.
df.dima is offline   Reply With Quote
Old 12-31-2013, 07:38 PM   #11
wparsons
wparsons's Avatar
Scott is also a wealth of knowledge for settings if you can give him some background on what you want out of the alignment and some general settings that have worked for others.
Your best bet is to go see him with feedback on how the car handles with the factory alignment (push/oversteer, tire wear, etc).
flickr
Old 01-01-2014, 02:24 PM   #12
DR 86
DR 86's Avatar
Thumbs up for Scott too. Had my car corner balanced and aligned there after installing coil overs myself.
Old 06-04-2014, 06:52 PM   #13
vignesh
Engineer
vignesh's Avatar
Drives: WRB 2022 Subaru Brz
Does Scott have Experience working on the frs/brz platform. I am looking at getting my tarmac II installed. I am also wondering if i should get the car aligned right away or wait for the coil overs to settle and then get it aligned. And is it worth corner balancing the car as well?
vignesh is offline   Reply With Quote
Old 06-04-2014, 07:09 PM   #14
KPDoubleX
❤ fr-s love ❤
KPDoubleX's Avatar
Drives: 13 Asphalt Scion FRS
Automatrix.....dont trust anyone else with my cars!!! They can do the install and the alignment in one stop!! Really cheap and they have worked with a lot of FRS/BRZ's before. Ask for Ed or Alic and tell them Rachel sent you. Shop is at Keele and Lawerence right off the 401.
Asphalt Scion FR-S
Enkei | Aero Jacket | BC Racing | Invida | AFE | JL Audio | Seibon | Chargespeed | Cusco | Mishimoto | Spec D |
www.themodmarket.com
KPDoubleX is offline   Reply With Quote
anyone know a good audio install shop NYCsubaruBRZ NY / NJ / CT / PA 6 01-16-2014 10:22 AM
Coilover and Springs Install at Performance Shop F-T Mechanical Maintenance and Tools 22 12-12-2013 01:12 PM
HELP kw coilover top hat install problem autoCAR Suspension | Chassis | Brakes -- Sponsored by 949 Racing 10 10-18-2013 10:55 PM
HKS Coilover install gtauto AUSTRALIA 16 04-21-2013 07:37 AM
Good coilover brand for DD ngabdala Suspension | Chassis | Brakes -- Sponsored by 949 Racing 8 09-26-2012 03:59 AM
