Old 12-12-2013, 04:25 PM   #1
Hal@Dynosty
Dynosty Tuned FR-S yields 355WHP with GTX28 Turbo and E85
The Dynosty team specked out a GTX28 turbo kit and E85 fuel to create an awesome stock-engine power plant. After installing the turbo kit, we bolted up Motiv concepts over pipe and front pipe, and then a MXP exhaust system. The fuel system was upgraded with a set of Dynosty 550cc plug&play injectors and drop-in fuel pump. We replaced the clutch and flywheel in favor of an ACT clutch kit that would hold the power.
With all of the parts in place, it was on to the dyno where we used EcuTek to dial in 264WHP DD on pump gas (300whp Dynojet). At this point, the fuel was exchanged for E85 and we increased boost to 13psi yielding 355WHP DD (400WHP Dynojet).
Hal@Dynosty is offline   Reply With Quote
The Following 2 Users Say Thank You to Hal@Dynosty For This Useful Post:
MAPerformance (12-12-2013), SnapOv3st3r (12-21-2013)
Old 12-12-2013, 04:43 PM   #2
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Looks like the @FullBlown kit but shouldn't the GTX28 have a V band exhaust housing? Great numbers as usual, and I love that flat torque curve from 4400 RPM to redline.
Old 12-12-2013, 04:58 PM   #3
DeliciousTuning
PhoneFlash by EcuTeK
DeliciousTuning's Avatar
Looks good. Nice smooth curves.
Are you running MAF or Speed Density?
Also how is the bottom end holding up. Think it is good for any more power on the stock bottom end?
Cheers,
William Knose
Old 12-12-2013, 04:58 PM   #4
Hal@Dynosty
Yes, it's a base kit with turbo upgrade. +1 on torque curve!
Old 12-12-2013, 05:00 PM   #5
Hal@Dynosty
Cheers,
William Knose
Both, MAF down low but it pegs out... so we switch to SD in boost. Using Omni map sensor.
Old 12-12-2013, 05:08 PM   #6
SmsAlSuwaidi
Boosted
SmsAlSuwaidi's Avatar
Drives: Not a supra....yet
@DeliciousTuning is this the same reason you told me about ?
Nice numbers guys
Old 12-12-2013, 05:16 PM   #7
MAPerformance
Drives: Asphalt FRS
You guys are killing it right now! Love to see some good stuff coming out of your shop. Also digging that torque curve
MAPerformance is offline   Reply With Quote
Old 12-12-2013, 05:17 PM   #8
DeliciousTuning
Nice numbers guys
MAF will max out pretty quickly on this vehicle as you can see. Though you can rescale and use a larger intake pipe, etc... Just more work where as a quick solution is just to run hybrid. When running a hybrid setup with EcuTeK RaceROM (as performed well by Hal@Dynosty) it is a great solution as it keeps the wonderful low end drivability, cruising, idle etc... but allows for easy power on top which is basically unlimited now.
Cheers,
William Knose
Old 12-12-2013, 05:51 PM   #9
diss7
Drives: AE86, 2x GT86, TE27
What spec was the GTX28? 63 or 67 compreesor? 0.86 turbine A/R Im assuming?
Cheers
diss7 is offline   Reply With Quote
The Following User Says Thank You to diss7 For This Useful Post:
DriftEightSix (12-13-2013)
Old 12-13-2013, 05:36 AM   #10
DriftEightSix
Pegasus White
DriftEightSix's Avatar
Drives: 86
You able to give us an boost map?
& dyno for no e85 run?
Driving: Pegasus White Manual GTS 86.
DriftEightSix is offline   Reply With Quote
Old 12-17-2013, 11:48 AM   #11
Hal@Dynosty
Cheers
GTX2867 .63 AR
Old 12-17-2013, 12:07 PM   #12
jamesm
weird you ran out of maf. i run 15psi on e85... probably 340+whp and only see 4.9v. what size is the intake pipe on the full blown kit?
Old 12-17-2013, 12:35 PM   #13
uspspro
Drives: DGM BRZ, MR-S 3.5L V6 swap (sold)
Really nice stuff!!
However, I do have to nit-pick about the chart scaling.. 500 hp max Y-axis on a 355 hp plot, coupled with an already wide aspect chart.
It just makes it difficult to see the torque/power curves with any kind of detail.
uspspro is offline   Reply With Quote
Old 12-17-2013, 12:59 PM   #14
endrswrd
Drives: 2013 LTD BRZ
They are running blow through, which usually causes the top end to get flaky when your running near the edge of the maf limit. Blow through setups usually also need to be sized slightly larger to be equivalent to a draw through setup to get the resolution you want. And placement is very important, 12 inches of straight pipe with an air straightener is usually what I like to see in a Blow thru MAF setup. To close to a bend, or no air straightener just makes it harder to tune, and will cause inconsistencies that cant be tuned out if its bad enough. You may already know this from working on your setup, but 99% of the time its still easier to tune blwo thru's via hybrid SD...
endrswrd is offline   Reply With Quote
dynosty, ecutek, scion fr-s, subaru brz, turbo
Dynosty Greddy Turbo FR-S Doubles Stock WHP Hal@Dynosty Forced Induction 17 03-03-2016 02:03 PM
Vortech frs e85 Dynosty tuned charged86 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 10 06-19-2015 12:52 AM
Dynosty Tuned 530WHP 439TQ Toyota 86 with GTX3076 Turbo Hal@Dynosty Forced Induction 16 10-12-2014 10:59 AM
New Vortech Quarter mile record 13.1 Dynosty tuned charged86 Forced Induction 21 07-30-2013 08:32 PM
Dynosty Turbo FR-S Videos Dustin@Dynosty FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 0 11-01-2012 10:57 AM
