Old 12-14-2013, 11:51 PM   #99
Malt
Drives: 2015 WRX
Originally Posted by autobrz View Post
question about adding bump travel: Does adding bump travel mean losing droop travel of the shock? I'm curious if it is the case and if it doesn't matter on our cars...
If shocks are designed to work at a certain ride height, does adding bump travel - moving the shock shaft up beyond the designed working ride height of the shock. Does this matter or is the shock happy at higher heights just not lower?
Also, will you make a set of plates that work with stock shocks and stock spring size while keeping the stock ride height?
In line with this question: I just picked up a set of RCE Tarmac 2's. I didn't pick up rear hats because I wasn't sure if they were necessary or not. I'm looking to lower the car about an 1" and I'm wondering if your rear hats require a certain amount of lower to work because the last thing I want to do is push the shock past what it is designed to do.
Malt is offline   Reply With Quote
Old 12-15-2013, 12:08 AM   #100
Race_Parts04
Drives: Spaceship Like
Great Looking Parts Guys!
Race_Parts04 is offline   Reply With Quote
Old 12-16-2013, 08:02 AM   #101
anajri
Drives: GT86
are these available for trd suspension?
anajri is offline   Reply With Quote
Old 12-16-2013, 08:52 AM   #102
Raceseng
Raceseng's Avatar
Responded to your email. Thanks!
Raceseng is offline   Reply With Quote
Old 12-16-2013, 08:53 AM   #103
anajri
Drives: GT86
thank you
Old 12-17-2013, 08:17 AM   #104
anajri
Drives: GT86
never received that email l
Lexus@deltacomercial.com.do
Old 12-17-2013, 08:41 AM   #105
Raceseng
Raceseng's Avatar
The email address bounced back, I've tried multiple times. Do you have another address?
Old 12-17-2013, 01:40 PM   #106
anajri
Drives: GT86
YES najria@hotmail.com
Old 01-06-2014, 11:01 AM   #107
whataboutbob
AutoX-10/10ths every run
I'll just leave these sexy pics here...BTW those are RCE T2s.
Build thread:Here
The Following 6 Users Say Thank You to whataboutbob For This Useful Post:
DAEMANO (01-26-2014), Malt (01-06-2014), normancw (01-07-2014), OICU812 (01-08-2014), Racecomp Engineering (01-06-2014), Trac Toy (01-06-2014)
Old 01-06-2014, 11:29 AM   #108
That's pretty.
whataboutbob (01-06-2014)
Old 01-06-2014, 12:52 PM   #109
Malt
Drives: 2015 WRX
Hey! Thats my exact setup . How did you like putting the shocks on the rear with the raceseng tophats? I'll just say the fronts were WAY easier than the rears.
The Following 2 Users Say Thank You to Malt For This Useful Post:
Racecomp Engineering (01-08-2014), whataboutbob (01-07-2014)
Old 01-07-2014, 12:07 AM   #110
whataboutbob
Not too bad. I didn't have an extra set of hands, so it was a bit of a challenge.
Build thread:Here
Old 01-07-2014, 06:45 PM   #111
Malt
Drives: 2015 WRX
I had my wife hold the shock assembly while I got the top hats threaded on which helped a ton. Got the alignment done today and it looks like it has to go back on stands to get the rear upper camber adjustment bolts up on. I should of done it all at the same time, but hey.. live and learn right?
The Following User Says Thank You to Malt For This Useful Post:
Old 01-07-2014, 09:42 PM   #112
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
Oh man!! Camber/caster plate porn!
(Don't need, want.)
billet, billet aluminum, caster adjustment, caster camber plate, raceseng
Tein Flex Z Coilovers Evasive Motorsports Brakes, Suspension, Chassis 54 07-16-2017 01:21 AM
Raceseng | Billet Aluminum Engine Pulleys Raceseng Engine, Exhaust, Transmission 174 07-24-2014 12:24 AM
Raceseng | Lightweight Billet Aluminum Tow Hook Raceseng Cosmetic Modification (Interior/Exterior/Lighting) 13 08-27-2013 01:48 PM
Question about adjustable LCA's vs Camber Plates vs Camber Bolts djdnz Suspension | Chassis | Brakes -- Sponsored by 949 Racing 13 03-27-2013 11:38 PM
SRP Billet Aluminum Door Sills pedalpusher Cosmetic Modification (Interior/Exterior/Lighting) 2 09-20-2012 06:44 PM
