Old 12-16-2013, 05:37 PM   #15
wparsons
wparsons's Avatar
It boggles my mind why anyone would upgrade their calipers, then downgrade on the pads?
You're far better off just running stock calipers/rotors with better pads.
flickr
The Following 4 Users Say Thank You to wparsons For This Useful Post:
Anthonytpt (12-16-2013), Captain Snooze (12-16-2013), CSG Mike (12-16-2013), Trac Toy (12-16-2013)
Old 12-16-2013, 05:45 PM   #16
CSG Mike
CSG Mike's Avatar
You have to admit those Brembos are pretty to look at...
2013GTRNate (12-18-2013), wparsons (12-17-2013)
Old 12-16-2013, 05:52 PM   #17
Anthonytpt
Anthonytpt's Avatar
Drives: '13 Argento 6MT FR-S
That's like saying [super model] will date me, but she has the clap. Don't skimp on the pads.
Anthonytpt is offline   Reply With Quote
The Following User Says Thank You to Anthonytpt For This Useful Post:
slicktop (12-16-2013)
Old 12-16-2013, 06:02 PM   #18
Trap63
Trap63's Avatar
Drives: Brz WRB - Europe LHD
Originally Posted by Vten View Post
I have the sti brembo brakes upgrade with a brand new hawks hps pads .
On the dry cold days , they're performs very well, but on the cold and wet days, raining and snow or even after the car wash , I can hardly stop !!
Any suggestion on the a better brake pads especially on the cold and wet days ?
I was thinking about the project MU , but open for a suggestions.
Thanks guys
Never tried Pagid? from RS5 to RS29, you can choose 8 pads mix/type for Brembo calipers on WRX STI.
Trap63 is offline   Reply With Quote
The Following User Says Thank You to Trap63 For This Useful Post:
Racecomp Engineering (12-16-2013)
Old 12-16-2013, 09:19 PM   #19
Vten
Drives: Too heavy
The reason why I did the sti brembos are solely for the aesthetic purpose as I don't track my car. Like someone mentioned that those brembos In a white finish are pretty .
So solely on that purpose, can anyone give me any recomendation for a pads that street DD Friendly that works great one cold and wet days ? I run those DBA 4000 T3 rotors at this moment ....
I heard good things about stoptech.... I did bought those akebono performance ceramic, but I don't mind to spend on another set if they're performs on the specific cold and wet well.
Thanks guys
Tan
Vten is offline   Reply With Quote
Old 12-16-2013, 09:33 PM   #20
ripper
ripper's Avatar
i'm running the HAWK HPS Brake Pads on my '04 sti for the last 5k and really like them. i don't track my car but drive it hard and take it for the occasional spirited drive through some local twisties. pads aren't terrible for dust, no noise and great all around performance in wet and dry.
ripper is offline   Reply With Quote
Old 12-16-2013, 09:56 PM   #21
Vten
Drives: Too heavy
How about on cold and wet 35F and under ?
Old 12-16-2013, 10:04 PM   #22
Cjymiller
Original 2013 Owner
Cjymiller's Avatar
Drives: 13 BRZ, Galaxy Blue Silica
I have hawk HPS and they work great regardless of temperature. Admittedly It doesnt get much below freezing here in norcal but if its cold or wet they work fine. As for performance, I just got back from a track day this past Saturday and they were fantastic. No noise, tons of heat and a great smell when pushed.
Perrin Headerback, OFH, OFT, Ohlins R&T MI20, 17x9 Weds TC105N, Hankook RS4 (235/40), TOM's JDM Tails, PCV AOS, Perrin Crank Pulley, Perrin Rear Trans. Mount, Whiteline Shift Bushing, SS brake Lines, Hawk DTC60, Bayson R Lip Kit, LED Lighting , Smoked JDM Sidemarkers, Rear Fog Enable, Carsmo Armrest, Grimmspeed Plate Relocater
φφκα
Cjymiller is offline   Reply With Quote
Old 12-16-2013, 10:28 PM   #23
Vten
Drives: Too heavy
Yeah, seems like the freezing temp is the culprit . As I mentioned before , I do like how the hps performs on the warmer temps , but as the temp drops close to freezing, it began to squeel and loose the initial bites .
Gotta find the right pads for this freezing months for sure
Old 12-16-2013, 11:29 PM   #24
We're big fans of Pagid.
Can't stand Hawk HPS.
Ferodo 2500 is a good sporty daily drivable pad. The stop tech pads are a good option on the cheap. There might be some newer options but these are my two go tos for a fun did pad.
- Andy
Old 12-17-2013, 03:31 AM   #25
Trap63
Trap63's Avatar
- Andy
Yeah! that's right. I tried both Ferodo DS2500 (H) but aren't very Sport and Brembo's.... They are mostly for "Road use" but not intense. They aren't so much reactive to fading. Now I fit Pagid U2487 (front) the grey type, RS15...they are fantastic, good initial grip and up to 650C° increase very fast. Sometimes may occour overbraking when very hot. Pagid needs a proper "setup" to be 100% operative. I think they are the more performing pads for road/track day.
Racecomp Engineering (12-18-2013)
Old 12-17-2013, 04:49 AM   #26
ZionsWrath
Thanks
ZionsWrath's Avatar
What is a good pad for 100% street (including winter temps) on bigger brakes than stock? Is it possible to find a pad like this?
I'm thinking AP sprint size.
Old 12-17-2013, 02:32 PM   #27
CSG Mike
CSG Mike's Avatar
There sure is, but pad size will be restricted by your caliper.
Old 12-17-2013, 09:50 PM   #28
ripper
ripper's Avatar
only a few days here under 35 but in the 30s no issue and i've stomped on it a few times due to the horrible drivers in northern va...
Hawk Performance Ceramic Pads? Anybody try them...? hmong337 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 22 07-13-2017 02:45 PM
Gotta Stop with one of these Brembo or Stoptech, Hawk Titanmotorsports Brakes, Suspension, Chassis 0 07-11-2013 07:11 PM
FS: NIB Hawk HP+ Front Brake Pads djfuller Brakes, Suspension, Chassis 4 02-22-2013 11:59 AM
Hawk HPS Front Pads Sheldon Brakes, Suspension, Chassis 1 01-04-2013 03:54 PM
Hawk ceramic brake pads yomchi1989 AUSTRALIA 5 09-26-2012 10:39 AM
