Old 12-10-2013, 03:06 AM   #1
benlaz88
Drives: 2013 Asphalt FRS
Share your Unichip mapping w/mods
I have not seen any thread talk about which mapping you prefer on the Unichip. Let post up your mods and the mapping you like. ENJOY!!
Since i created this thread, I will start.
Only mods i have so far is AEM intake with fuel out and timing in (most aggressive).
benlaz88 is offline   Reply With Quote
Old 12-16-2013, 02:56 PM   #2
SCharged
Drives: asphalt fr-s
My mods are TRD intake, Lachute performance OP/cat delete FP, and the map that I like the most (suprinsingly) is TRD intake, all headers, Fuel out timing in. I am running 94 octane only as well.
For some reason the headers map pulls noticeably more than the all catback map that unichip said was likely to run best. I also asked, and they say there are no risks in running the headers map, as long as the map is for the correct intake...
SCharged is offline   Reply With Quote
Old 12-16-2013, 03:33 PM   #3
benlaz88
I only have 91 octane here in my state, so I'm mapping the highest octane Unichip provided. My mapping does pull the car well and idle does not dip anymore. I was testing the fuel standard and timing in, but the car shake like is going to stall when in second in low speed while aggressive mapping stop that. I still need to test other mapping and see if any are those can be better than the one i am using. Im glad you found your best mapping for your car! Thanks for sharing!!
Old 12-16-2013, 03:49 PM   #4
Boofneenee
Go-Kart Enthusiast
Boofneenee's Avatar
Drives: Toyota Scion FRS
I personally enjoyed their most consevative mAp which was timing out fuel in
FRS
Current mods: K&N air filter, OFT, OFH, berk high flow cat front pipe, Q300 exhaust, lighter wheels
Boofneenee is offline   Reply With Quote
Old 12-16-2013, 04:01 PM   #5
benlaz88
tell us your feeling on the timing out , fuel in mapping. Good pull, few more power, etc...
Old 12-16-2013, 09:12 PM   #6
Boofneenee
Go-Kart Enthusiast
Boofneenee's Avatar
Honestly, its a waste of time and money now that i have had the experience of a proper tune. Sorry for the brutal honesty.
FRS
The Following 2 Users Say Thank You to Boofneenee For This Useful Post:
jamesm (12-17-2013), Shiv@Openflash (12-16-2013)
Old 12-16-2013, 09:32 PM   #7
6speed_Sam
Thumper
6speed_Sam's Avatar
Drives: 2013 FRS
currently fuel +/timing +
I tried fuel~/timing~, fuel -/timing ~, fuel ~/timing +
mods below:
Car is gone - parts for sale
6speed_Sam is offline   Reply With Quote
Old 12-17-2013, 08:53 AM   #8
SCharged
Care to share differences/preference reasons from your experience?
Old 12-17-2013, 10:04 AM   #9
jamesm
I think he's coming to the conclusion most either have or will. Unichips are great, if they're all that's available they'll do the job somewhat well. That said, you'll never get anywhere near the kind of control you can get with a now-cheaper reflash. Without low-level control of all the various things, achieving good results is very difficult, or impossible in some cases.
Unichip can't:
Scale port injectors directly (I.e. Without a maf hack)
Scale direct injectors at all (no e85 for you!)
Modify knock control parameters
Adjust advance independent of base timing
Control di/port ratio (crucial to getting things right in the first place)
Adjust dbw maps
Many, many, many more
So basically you can't really do anything with it beyond tricking the ecu into adjusting fuel or timing. None of the vast subie knowledge on the Internet applies, can't use the common tools, and there will just be many issues that simply cannot be properly fixed with any piggyback because you just flat-out can't do what you need to do.
Old 12-17-2013, 11:21 AM   #10
benlaz88
mods below:
how do you feel with the fuel + timing +?
Old 12-17-2013, 01:21 PM   #11
6speed_Sam
Thumper
6speed_Sam's Avatar
Drives: 2013 FRS
It feels like it pulls a little better. Plus with the cooler air I wanted to add fuel.
Old 12-17-2013, 01:27 PM   #12
SCharged
Unichip can't:
Adjust dbw maps
On an NA setup, with just bolt ons, does anyone know how that actually translates to HP??? I'd be surprised that the difference be substantial between bolt ons supported by Unichip vs Ecutek or other flash.
Old 12-17-2013, 02:29 PM   #13
jamesm
probably not much if anything in terms of peak hp, except maybe from the ability to adjust cam timing. driveability and the stability of the tune are the biggest benefits i'd say. of course once you consider the ability to run e85, it makes a lot more power lol.
i think unichip is probably the best piggyback out there, but it's still a piggyback, and there isn't much need for them when flashes can be had so inexpensively.
Old 12-17-2013, 04:12 PM   #14
benlaz88
They have Unichip tuner in certain tuning place, but i don't know how much they charge and how well it can perform.
SOLD: Unichip + launch control + switch + Flux2 for Unichip + FLux2 download cable abutterman Engine, Exhaust, Bolt-Ons 40 11-22-2013 01:16 PM
Not a BRZ or FRS just thought i would share wrohdejr Northwest 6 03-25-2013 01:19 PM
What does your FR-S/BRZ share the garage with? Supermassive Off-Topic Lounge [WARNING: NO POLITICS] 35 09-18-2012 01:54 AM
Re-Mapping the ECU Rowdybell Engine, Exhaust, Transmission 4 06-08-2012 09:19 AM
GT5 Photos (Share yours) EJ20 Other Vehicles & General Automotive Discussions 89 12-24-2011 01:48 AM
