Old 05-23-2013, 11:17 AM   #15
cmspooner
cmspooner's Avatar
Drives: 2013 SWP Limited BRZ - Manual
Can you take a picture of the radio in daylight so that we can see the fitment? How well does it fit? Did you have to modify the trim pieces at all or add spacers? Finally does the rearview camera come on when you put the car into reviers even with the bypass installed?
I'm looking at getting this and using ARLiberator to control my android phone.
cmspooner is offline   Reply With Quote
Old 05-23-2013, 01:09 PM   #16
xjohnx
Grip>Slip
xjohnx's Avatar
I wish they made the AVH8500BHS with the AppRadio2's capacitive screen. I just picked up the appradio 2 to temporarily replace my AVH5500BHS until Pioneer gets their firmware act together. The screen on the AppRadio2 is better in every regard (touch, visual quality, and surprisingly smudge resistance) than the 2013 AVH lineup.
Old 05-23-2013, 03:47 PM   #17
mit_peid
Boosted Noob
mit_peid's Avatar
Drives: '13 FRS MT KW SC, '05 4Runner 4WD
Here's a photo from yesterday with the video from a Rydeen Duo camera. I can take a better one later today. Yeah, the X8500bhs's screen definitely isn't as responsive as an iPad or Nexus 7, but still okay.
mit_peid is offline   Reply With Quote
The Following User Says Thank You to mit_peid For This Useful Post:
cmspooner (05-23-2013)
Old 05-24-2013, 06:24 AM   #18
IntotheOcean
IntotheOcean's Avatar
Drives: Sexy Frs Firestorm M/T
Um this might sound dumb but how exactly does the navigation work on this? Through your phone or do you need an add on device?
Also, I'm guessing the faceplate lowers so you can put the dvd in behind it?..
-looks awesome btw. Was hesitant on not having a knob but I think it won't be a problem
IntotheOcean is offline   Reply With Quote
Old 05-24-2013, 09:31 AM   #19
mit_peid
Boosted Noob
mit_peid's Avatar
It works through AppRadio thru your phone with a number of apps (waze, intrix, igo, etc) or you can add on an external Pioneer nav module for about $400. I believe you lose AppRadio functionality with the external module, but I'm not sure since it doesn't appear as though anybody on the Internet went that route. Yes, faceplate comes down to reveal CD/DVD slot and SD slot. It can also be removed if you are inclined but I never really do it unless I'm parked in a shady area. IMO, the volume buttons work as well as a knob. In fact I'd rather have buttons instead of a tiny volume knob. My previous trial unit didn't have either and it drove me nuts.
Old 07-29-2013, 02:28 PM   #20
Gopherboy6956
Gopherboy6956's Avatar
Drives: 13 BRZ Limited WRB
Well, this thread just pushed me over the edge. I currently have the X4500BT, which met most of my needs, but it just died on me about 4 months in. First major failure i've had over 6-7 pioneer headunits.
Beyond that, the things that frustrated me about the x4500bt was how slow it was when navigating through the folders of a USB stick. Lack of SD slot was also an issue for me, but everything else was ok.
I was really hoping that the X8500BHS would have a different software setup and screen, which it sounds like it does.
I will be returning my X4500BT and getting the X8500BHS!
(Also, for reference here is my setup)
Pioneer Headunit (was x4500bt, will be x8500bhs)
JL Audio XD500/3 Amp
JL Audio C5-653 3 way components
JL Audio 10W3v3 Subwoofer
Integrity Concepts Subwoofer Enclosure
I plan to live forever. So far, so good.
My Build - http://www.ft86club.com/forums/showthread.php?t=31925
Gopherboy6956 is offline   Reply With Quote
Old 07-30-2013, 09:41 PM   #21
Whiteoutjames
Drives: 2013 Scion FR-S--> 2015 WRX
are you the stig?
Whiteoutjames is offline   Reply With Quote
Old 07-30-2013, 11:50 PM   #22
mit_peid
Boosted Noob
mit_peid's Avatar
Originally Posted by Whiteoutjames View Post
are you the stig?
No, but I play one on the ft86 forums.
Old 12-16-2013, 12:59 PM   #23
TONYpepperon1
TONYpepperon1's Avatar
Drives: 2013 CBS BRZ
you say it will work with waze but what about google maps?
TONYpepperon1 is offline   Reply With Quote
Old 12-16-2013, 06:49 PM   #24
mit_peid
Boosted Noob
mit_peid's Avatar
In mirror mode, it will mirror anything (including Google Maps) from your iPhone to the x8500 head unit. You won't be able to control Google maps from the unit in mirror mode. Waze (in AppRadio mode) will take inputs from the head unit since it is a native app.
TONYpepperon1 (12-16-2013)
Old 12-22-2013, 05:53 AM   #25
nyfries
Drives: 14 FRS Whiteout
can this HU utilize the OEM usb ports?
nyfries is offline   Reply With Quote
Old 12-22-2013, 11:10 AM   #26
mit_peid
Boosted Noob
mit_peid's Avatar
Yeah pretty much any HU can with something like this: [ame="http://www.amazon.com/Axxess-AX-TOYUSB-Adaptor-Retain-Vehicles/dp/B00EAYYQDO/ref=sr_1_6?ie=UTF8&qid=1387728515&sr=8-6&keywords=Toyota+USB+adapter"]Amazon.com: Axxess by Metra AX-TOYUSB USB Adaptor to Retain the OE USB in Select Toyota/Lexus Vehicles: Car Electronics[/ame]
nyfries (12-23-2013)
Old 12-29-2013, 03:10 PM   #27
NIKOLA
NIKOLA's Avatar
Drives: 2013 Scion FR-S in Ultramarine
What about the Aux. Port right below the USB? Is there a cable for that? I haven't been able to find any information on that.
Currently driving a Sprintex Supercharged FR-S in Ultramarine with an Invidia N1 Catback with Catless Front Pipe, Invidia Over Pipe, Injen Catless 4:1 EL Headers, Perrin Aluminum Drive Pulley & Driveshaft Shop Aluminum Driveshaft. Also, looking to upgrade wheels someday to Enkei PF01's (17x8's).
NIKOLA is offline   Reply With Quote
Old 01-01-2014, 04:42 AM   #28
mit_peid
Boosted Noob
mit_peid's Avatar
When was looking into that, I wasn't able to find a plug-n-play solution. I think you may need to do some soldering to make it work but I believe you will need to tear into that USB/AUX part. Should be a DIY on these forums or on the internets for that.
NIKOLA (01-01-2014)
RS*R Sports-i Coilover system installed (pics) R0ME0 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 139 02-05-2015 03:38 PM
Tein H Tech installed pics and review JoeBoxer Suspension | Chassis | Brakes -- Sponsored by 949 Racing 23 05-19-2013 12:22 PM
FR-S Stock Pioneer H/U Installed in 2002 Tundra? xxthrillxx Electronics | Audio | NAV | Infotainment 0 12-18-2012 02:56 PM
Exogear Car Mount Review - INSTALLED MattQ-WP Electronics | Audio | NAV | Infotainment 10 11-30-2012 02:32 AM
Installed Curb Alert system sesmls BRZ First-Gen (2012+) — General Topics 17 07-27-2012 01:26 PM
