Old 09-30-2012, 10:17 PM   #1
JoeBoxer
JoeBoxer's Avatar
Drives: Whiteout FR-S
Tein H Tech installed pics and review
We installed springs yesterday that i got from Chris here at TiTAN Performance along with OEM camber bolts and my HID kit from TheRetroFitSource.com. I will post another thread on that in the coming days but i have to say these springs are great, excellent ride and took away some of the twitchy feeling the car had with just the wheels and i actually haven't even had it aligned yet because the car wasn't in our alignment machines software, we should be able to update it tomorrow and take care of that. I'm very impressed and even though i wanted KW V3's these will keep me happy for a long time. I'm going to add the SRT front strut bar because it fits with the Crawford AOS but i think the stance is perfect hope you guys agree.
JoeBoxer is offline   Reply With Quote
The Following 4 Users Say Thank You to JoeBoxer For This Useful Post:
hmong337 (07-25-2013), Surok (10-01-2012), XTR Performance (10-01-2012), yuli8466 (04-28-2013)
Old 10-01-2012, 02:08 AM   #2
lbroskee
lbroskee's Avatar
Drives: 2023 WRB BRZ (MT)
do u still need the alignment from the new wheels or do u need to do 1 when u install new springs?
lbroskee is offline   Reply With Quote
Old 10-01-2012, 02:11 AM   #3
JoeBoxer
JoeBoxer's Avatar
Alignment after springs, we would have done it but apparantly our Hunter rep didn't update our alignment machine properly. I'm sure it needs it but i drove a hundred miles today easy and it didn't even really feel neccessary but it will be done of course.
Old 10-01-2012, 01:50 PM   #4
armythug
armythug's Avatar
Drives: Pegasus White 86GTS
Looks nice!
Pegasus White 6MT got it. :happy0180:
armythug is offline   Reply With Quote
Old 10-01-2012, 08:22 PM   #5
Turbo Den
Drives: FRS, IS300, 911sc
i also did the H-tech with OEM camber bolts. Agree on the ride quality. It's not too low, it's more like way our sports car should have come from the factory.
Turbo Den is offline   Reply With Quote
Old 10-01-2012, 08:32 PM   #6
XTR Performance
Drives: 2012 WW Evo X
Send a message via AIM to XTR Performance
Looks awesome Joe. I'm glad you kept them!
-Chris
XTR Performance is offline   Reply With Quote
Old 10-01-2012, 09:50 PM   #7
JoeBoxer
JoeBoxer's Avatar
-Chris
Me too and thanks for the hook up i should have mentioned i got them from you. I'm really happy with them.
Old 10-01-2012, 10:00 PM   #8
XTR Performance
Can always add it Your very welcome. Let us know if we can help you with anything else!
-Chris
Old 10-07-2012, 09:54 AM   #9
FRS-HHH
igotthatpurp
FRS-HHH's Avatar
can i ask a dumb ? what are the camber bolts for??
FRS-HHH is offline   Reply With Quote
Old 10-07-2012, 11:01 AM   #10
JoeBoxer
JoeBoxer's Avatar
They give you some adjustment so you can get some negative camber, I would recommend them even without a drop actually. I am running a pretty wide front wheel so the negative camber also keeps them from poking out too much too.
Old 10-07-2012, 06:16 PM   #11
FRS-HHH
igotthatpurp
FRS-HHH's Avatar
ahhh gracias
Old 10-17-2012, 12:55 AM   #12
Ad8707
Ad8707's Avatar
Drives: 2013 frs whiteout
So with the drop from h tech, do I need to adjust the rear camber...is it necessary or alignment would just be find..and if i do, what would be my option
Ad8707 is offline   Reply With Quote
Old 10-17-2012, 01:03 AM   #13
JoeBoxer
JoeBoxer's Avatar
My camber was over 1 degree more negative on the right rear than the left after installing these springs. This will vary on a car by car basis though i'm pretty sure mine was out of spec from the factory. You can get the Whiteline rear camber bushing($150) or an adjustable rear lower control arm which is what i got from SPC($280). The lower control arm is much easier to install and adjust but you have to pay twice as much.
digital assassin is running some H&R camber bolts in the rear but i'm not sure what was required to set it up in this way, nobody else seems to be running that.
The Following User Says Thank You to JoeBoxer For This Useful Post:
Ad8707 (10-17-2012)
Old 11-12-2012, 10:51 AM   #14
dj petey
dj petey's Avatar
Have these settled any lower since first installing them?
dj petey is offline   Reply With Quote
Frs on Tein S-Tech springs Juanito08 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 75 10-22-2015 11:19 PM
TEIN S-TECH AND H-TECH FOR 2013 FRS & BRZ IN STOCK!! genometuning Brakes, Suspension, Chassis 7 10-13-2013 09:49 PM
TEIN S-Tech Lowering Springs zex Suspension | Chassis | Brakes -- Sponsored by 949 Racing 22 07-18-2012 07:50 PM
