Drives: BRZ Limited WRB MT
Door does not trigger dome light
As the title stated: (2013 BRZ)
Upon opening driver, or passenger door the dome light does not turn on. Proximity key does not turns the dome light on neither. It works when switched to "On". Both doors lower the windows and the lights on the door pockets turn on too. Checked fuses (found 2 in the owners manual) in the engine bay. Measured the voltage on the dome light and it only outputs 3 volts... Disconnected the battery for an hour. Any other fuses I need to hunt down? Have a dealer appointment on Wednesday for an oil change, just want to make sure I do not get the "run around" at the dealer.
KartBoy SS | BlackVue DR550GW | Valentine1 GrimmSpeed MC Brace | GrimmSpeed Hood Struts OEM Armrest | OEM STI Badges | 20% Tint Rydeen duo | Halo's as DRL Rexpeed Wide Mirrors |
#2 |
it's a 3 way switch, did you leave it in the middle?
#3 |
i'm sorry, what?
Drives: Canada
/thread
**i actually always leave it in the off position so as to not bring attention to myself when entering a car at night. Ninja mode.
#4 |
#5 |
i'm sorry, what?
Drives: Canada
well that..
and nothing says "i'm not paying attention and my door is open" like a bright light (not to mention it blinds you to your surroundings). petty thieves are thieves of convenience, i know if i was a thief i'd be praying on these people no problem, snatch and run like a boss. might sound paranoid but safety first
#6 |
Yep, middle setting (Says "door"
#7 |
#8 |
#9 | |
Drives: br zed
#10 |
Well, Looks like a new BIU Controller.
Part is on order and have an appointment for January 6th. Dealer wanted a full day, (with the Holidays and all) so he has plenty of time, seems like the car needs to be reprogrammed too. They just wanted to know if I "cut" any wires or added LED's... (None were added or wires cut)
KartBoy SS | BlackVue DR550GW | Valentine1 GrimmSpeed MC Brace | GrimmSpeed Hood Struts OEM Armrest | OEM STI Badges | 20% Tint Rydeen duo | Halo's as DRL Rexpeed Wide Mirrors Last edited by modena; 12-24-2013 at 12:13 PM. |
#11 |
Drives: SWP BRZ
this happened on my previous car as well.
ever since that i don't use LEDs for interior |
#12 |
Drives: '13 Argento 6MT FR-S
I just leave mine in the 'off' position since 'door' just dims the LED panel in the dome.
#13 | |
Old Mechanic
Drives: 2013 Limited BRZ
it worked correctly before i went all modified on it... |
#14 | |
Please let me know if they get yours up and running. Good luck!
| Map/Dome Light Dis-assembly/Phastek Performance LED Dome Light | F1point4 | DIY (Do-It-Yourself) Guides | 9 | 03-25-2014 09:39 PM |
| OEM Dome Light Bulb? | ScionFR-S | Interior Parts (Incl. Lighting) | 4 | 12-09-2013 11:33 AM |
| FS: Cool White LED Lighting (dome, door, and trunk lights) | fourvalleys | Interior Parts (Incl. Lighting) | 0 | 11-18-2013 06:55 PM |
| Interior Dome Light in DOOR mode works in reverse! | shaoster | Cosmetic Modification (Interior/Exterior/Lighting) | 1 | 04-07-2013 01:37 AM |
