Old 12-13-2013, 09:50 PM   #2339
troek
troek's Avatar
Drives: 2012 Toyota 86
man that torque band!
troek is offline   Reply With Quote
Old 12-14-2013, 05:45 PM   #2340
CK_Bladesmith
CK_Bladesmith's Avatar
Drives: Raven FR-S
Received my supercharger the other day. Right off the bat I checked to see if the fittings in the back were loose and as soon as I touched it the brake booster connection snapped clean off......gonna pull the rest out and replace with brass fittings instead. Hopefully nothing else messes up. Glad I've got mechanic friends that can help me with this kind of stuff
Raven FR-S mods: Unichip, Ground Control street coilovers with camber plates and strut tower brace, SPC Lca's, Drag DR-38 wheels with Dunlop Direzza DZ101s, Perrin CAI and silicone inlet tube, Perrin 3" resonated catback, Perrin high flow catted front pipe, Rev Works UEL header.
CK_Bladesmith is offline   Reply With Quote
Old 12-15-2013, 09:28 AM   #2341
wrxgoose
WUB WUB
Drives: 2013 Firestorm
Another belt down. This time I didn't have to cut it off. It pulled off the first thread of the belt. Need to figure out WHY it's doing this really.badly.
Sent from my VS840 4G using Tapatalk
wrxgoose is offline   Reply With Quote
The Following User Says Thank You to wrxgoose For This Useful Post:
Calum (12-15-2013)
Old 12-15-2013, 10:07 AM   #2342
digital_assassin
digital_assassin's Avatar
Drives: 2013 FR-S Matte Orange
Out of curiosity, how much do you guys pay for belts. The belt for the KWSC is $75 but it's for cogged pulleys.
digital_assassin is offline   Reply With Quote
Old 12-15-2013, 11:10 AM   #2343
tech4pdx
Make love
tech4pdx's Avatar
Drives: H8R.. Not really
I would suggest you find a good Subaru tuner shop in your area and have them diagnose. The problem is obviously pulley and/or tensioner related. Do you have any visible wobble in your pulley system? Are you using the Gates belt? I've been beating on mine for awhile and no slippage.
tech4pdx is offline   Reply With Quote
Old 12-15-2013, 11:38 AM   #2344
wrxgoose
WUB WUB
No visible pulley wobble, but the tensioner is visibly loose if I squeeze the belt
Old 12-15-2013, 12:00 PM   #2345
whataboutbob
AutoX-10/10ths every run
I think the last std belt I bought at O'reillys was around $43.
Build thread:Here
The Following User Says Thank You to whataboutbob For This Useful Post:
digital_assassin (12-15-2013)
Old 12-15-2013, 12:01 PM   #2346
tech4pdx
Make love
tech4pdx's Avatar
Replace it with a new OEM assembly. That's what I'd do. It's fairly inexpensive from Village Scion parts online.
Old 12-15-2013, 12:24 PM   #2347
wrxgoose
WUB WUB
If I've lost 3 belts from the OEM, I really think I should try an aftermarket one. Also, probably gonna try a little bit smaller belt
Old 12-15-2013, 12:40 PM   #2348
sw20kosh
Drives: 2013 Black FR-S
Check the alignment of the supercharger pulley (70mm) itself. Does it rotate true and straight
Old 12-15-2013, 12:42 PM   #2349
wrxgoose
WUB WUB
I'm running the 75mm still. And it seems to be running straight. Later tonight I'll get a vid of the belt going, see if y'all can see anything.
Old 12-16-2013, 10:11 AM   #2350
DarrenDriven
NW Region Moderator
DarrenDriven's Avatar
Drives: FR-S No More
Originally Posted by DriftEm View Post
I'm assuming that is your car? Should I update page one?
Old 12-16-2013, 11:05 AM   #2351
Calum
That Guy
Drives: 2013 asphalt FRS MT
Sorry to hear about you loosing another belt, man. How much did it cost to get the wiring fixed the last time?
I'm anxious to see the vid, can you also post a pic of the broken belts?
How sharp/high are the ridges on the pulleys? They shouldn't be long enough to touch to valleys in the belt.
Old 12-16-2013, 11:07 AM   #2352
wrxgoose
WUB WUB
cost about $40 to get everything fixed, but that's because i work at a Pep Boys. I completely forgot to get a vid yesterday.
Innovative ideas to increase interior storage capacity? swift996 Cosmetic Modification (Interior/Exterior/Lighting) 0 01-30-2013 10:45 PM
AVO vs Innovative diss7 Forced Induction 32 01-21-2013 06:15 PM
Technical topic sub-forums OrbitalEllipses Site Announcements / Questions / Issues 1 07-17-2012 11:38 PM
