Old 12-13-2013, 07:18 PM   #57
OICU812
Just a dude
OICU812's Avatar
Drives: Scion FR-S 2013
92 gas honestly that looks great far better then what I had guesses really. Overall Bob with all kits you've seen and been involved with were you impressed?
Old 12-13-2013, 08:32 PM   #58
jflogerzi
jflogerzi's Avatar
Bob any other mods like an exhaust, headers, ect...
Sent from my SGH-T999 using Tapatalk
2013 Series 10 FRS #553
Old 12-13-2013, 08:33 PM   #59
illmatic
illmatic's Avatar
Drives: BRZ Limited 6MT, 02 AW, 03PSM WRX
2013 FRS / 6MT Transmission
Jackson Racing Supercharger Kit w/ 10 PSI Pulley
STOCK OEM Injectors
STOCK OEM Fuel Pump
OMNI 3 Bar Map Sensor
Drift-Office Custom ECUTEK SPEED DENSITY Calibration
HKS Equal Length Header
J2 Motoring Uncatted Front Pipe
Perrin 2.5 Inch Exhaust
illmatic is offline   Reply With Quote
The Following 5 Users Say Thank You to illmatic For This Useful Post:
Calum (12-13-2013), Drift-Office (12-13-2013), jflogerzi (12-13-2013), kidgogeta (12-14-2013), OjiGeorge (12-14-2013)
Old 12-13-2013, 09:39 PM   #60
Calum
That Guy
Drives: 2013 asphalt FRS MT
That's exactly what I'm looking for. My god that's perfect.
Bob, was there a base line run for this car?
The Following User Says Thank You to Calum For This Useful Post:
CSG Mike (12-13-2013)
Old 12-13-2013, 10:46 PM   #61
Victor Draken
Drives: Toyota Gt86
Originally Posted by Drift-Office View Post
Results are in, customer has taken delivery of his vehicle!
Here's the dyno sheet... and something to keep in mind :
We're running a winter blend of 92 Octane and I'm sure I could squeeze a bit more but given the variables, this is more of a conservative tune. We're also running a custom Speed Density (SD) calibration, and understand that when you do this, you're not looking at some E-Tune or off the shelf map. When going to SD, each car's engine has it's own VE, and there is no one size fits all calibration, at least not for optimization purposes.
Anyone purchasing either of the SC kits should save themselves mucho headaches and head to a local on-site dyno tuner and expect to pay more $$$...
Attachment 59995
And the Youtube Vid :
Have a good weekend Y'all!
Bob @ Drift-Office, LLC
any chance to see the potential of this kit on a normal tune instead of a SD tune?
Victor Draken is offline   Reply With Quote
Old 12-14-2013, 03:08 AM   #62
Drift-Office
Drift-Office's Avatar
Drives: AE86 / FRS / FC3S / GC8 / S14 / R32
JR had said it was possible to tune it off the MAF, though I respectfully disagreed. Not sure how they did it but I couldn't without skewing the MAF values beyond it's intended range... To each his own I guess!
Man - totally forgot about that. Let me see if I can pull up the dyno runs remotely... ah, here it is! Baseline vs HKS EL tuned vs JRSC installed & Tuned...
Name:  Baseline vs HKS EL vs JRSC.jpg
And how about that 100+ WHP gain?
Name:  Baseline vs JRSC.jpg
Cheers!
Drift-Office is offline   Reply With Quote
The Following 5 Users Say Thank You to Drift-Office For This Useful Post:
Calum (12-14-2013), djdnz (12-14-2013), Marchy (06-20-2014), OICU812 (12-14-2013), SirBrass (12-14-2013)
Old 12-14-2013, 06:20 AM   #63
OjiGeorge
OjiGeorge's Avatar
Drives: White 2013 FRS
Those are really good numbers!
OjiGeorge is offline   Reply With Quote
Old 12-14-2013, 06:22 AM   #64
OjiGeorge
OjiGeorge's Avatar
Will there be heating issues if you run this kit with an oil cooler and larger rad for long runs? (5+hours?)
Old 12-14-2013, 07:49 AM   #65
Victor Draken
Drives: Toyota Gt86
are you telling me that the JR S/C is not possible to get tuned without SD?
Because I have no tuner here where I live that could do it... and I don't think SD is achievable via E-Tuning plus I would prefer less power but more flexibility of a MAF tune.
Old 12-14-2013, 08:35 AM   #66
ecko04
Seems Legit
ecko04's Avatar
Drives: Toyota
No, that's not what he said.
What he said was while JR told him it is possible to tune the vehicle with a MAF based tune he noticed, while trying to do so, that the MAF ended up reading outside of it's efficiency range (i.e. during WOT pulls the MAF was not reading consistently).
The inconsistency of the MAF could lead to skewed fuel trims, and thus a skewed tune, once the dyno tune is complete and client gets the car back and does some driving. To prevent these types of issues that could throw off the trim Bob decided a speed density based tune would be ideal in this situation. He did not say that another tuner wouldn't be able to create a MAF only tune. Just from his experience that it isn't the best route to go with.
Now, you don't have to run a tune based solely on MAF or Speed Density. It's very likely that you could run a hybrid tune of both. You can run MAF and the map would switch over to MAP for speed density as the MAF reaches the point where it's becoming unstable and thus unreliable.
With that being said, Bob @Drift-Office stated and I wholeheartedly agree, "Anyone purchasing either of the SC kits should save themselves mucho headaches and head to a local on-site dyno tuner and expect to pay more $$$..."
He further goes on to say, "...and understand that when you do this, you're not looking at some E-Tune or off the shelf map. When going to SD, each car's engine has it's own VE, and there is no one size fits all calibration, at least not for optimization purposes."
So yes, it can be done. Will it be optimal? No.
If that doesn't answer your question, I don't know what will.
No build thread. I don't want to be reminded of how much money I spent.
[insert profound quote here]
ecko04 is offline   Reply With Quote
The Following User Says Thank You to ecko04 For This Useful Post:
Drift-Office (12-14-2013)
Old 12-14-2013, 08:42 AM   #67
Victor Draken
Drives: Toyota Gt86
I got it now but It goes back to what I wrote before, what if I don't have any dyno shop?
Is it possible to tune the JR for LESS whp/tq and so use the MAF instead of a SD tune?
I see lots of S/C around that don't have to use SD tune, so is It something related to this supercharger or is something related of trying to get every whp possible out of the kit?
Old 12-14-2013, 08:52 AM   #68
ecko04
Seems Legit
ecko04's Avatar
Drives: Toyota
The tune isn't about extracting every whp possible. Tuners target reliability and driveability.
Some setups lend themselves more towards SD or a hybrid tune as opposed to MAF based. It's in the design of the system. The intake's and diameter as well as MAF placement and other variables can pose difficulties with a MAF only tune, this is where the hybrid and SD tune comes in.
@Drift-Office stated if you're looking into one of these you should find a shop to dyno tune instead of eTuning. You should heed that advice. I drove 10 hrs on cruise control for a proper dyno tune in 2007. Other members of this forum have had their cars towed to a shop for a proper dyno tune. I cannot stress enough how important that is.
The Following 2 Users Say Thank You to ecko04 For This Useful Post:
B L U E S L A T E (12-19-2013), Drift-Office (12-14-2013)
Old 12-14-2013, 10:12 AM   #69
jamesm
You maxed out the maf? What's the diameter of the maf tube on the kit? I'm running 14psi on a gtx2867r and just approaching 4.9v, with I believe a 3" tube.
Old 12-14-2013, 12:37 PM   #70
digital_assassin
digital_assassin's Avatar
Drives: 2013 FR-S Matte Orange
I think placement of the MAF on both of the rotrex kits is the reason MAF tune was ruled out. Bob may have some suggestions if you want to fabricate new parts to make MAF tune doable
digital_assassin is offline   Reply With Quote
280 whp, maybe the next day, rotrex, some day soon
Drift Office Tune vs Visconti Tune mechaghost Engine, Exhaust, Transmission 109 07-03-2014 12:57 AM
Jackson Racing supercharger NoppyNop Forced Induction 241 06-26-2014 03:05 PM
Drift-Office : Phantom Supercharger - Tuned! Drift-Office Forced Induction 67 10-25-2013 09:51 AM
Drift-Office N/A tune zuldajin Engine, Exhaust, Transmission 14 07-09-2013 08:38 PM
Drift-Office Stage 1, 92 Oct tune BRZranger Engine, Exhaust, Transmission 15 01-07-2013 09:40 PM
