Old 12-13-2013, 11:46 PM   #1
LtS720
LtS720's Avatar
Drives: Whiteout Scion FR-S
Gauges for supercharger?
I know that a AFR wideband is recommended, what others though are y'all using?
LtS720 is offline   Reply With Quote
Old 12-14-2013, 01:04 AM   #2
raytrix
Drives: Series 10 FR-S
A smile gauge so you can measure how many times you'll be smiling when your boosting.
raytrix is offline   Reply With Quote
Old 12-14-2013, 01:06 AM   #3
onefitz
Drives: 13 GBS BRZ
Is that kinda like the top-down-o-meter on convertible mini coopers?
onefitz is offline   Reply With Quote
The Following User Says Thank You to onefitz For This Useful Post:
ftc~brz (12-25-2013)
Old 12-14-2013, 01:54 PM   #4
Frs32907
Drives: Asphalt grey, manual Fr-S
If you have an android device download torque and get a blue tooth obd2 adapter it shows afr and boost might save ya a few bucks
Frs32907 is offline   Reply With Quote
Old 12-14-2013, 03:24 PM   #5
jamesm
if i were doing it again i'd go for the p3cars obd2 gauge. it looks clean and gives you everything you need. the downside is it's obd2 so you have to leave it plugged in there and if you use brzedit it probably won't work, as most obd2 things don't (i know my innovate ot-2 doesn't). when i get back on romraider i'm definitely going to pick one up.
Old 12-14-2013, 03:30 PM   #6
OICU812
Just a dude
OICU812's Avatar
Drives: Scion FR-S 2013
+1
Check my build journal I have a few videos and pics/info of P3 in action etc...
Old 12-14-2013, 06:43 PM   #7
SmsAlSuwaidi
Boosted
SmsAlSuwaidi's Avatar
Drives: Not a supra....yet
Isnt it not the most accurate thing to be reading afr from an obd2 ?
Like isnt a o2 senor way better ?
Old 12-14-2013, 06:54 PM   #8
jamesm
the p3cars gauge has one (maybe two?) 0-5v inputs you can use with a wideband
Old 12-14-2013, 09:01 PM   #9
wrxgoose
WUB WUB
Drives: 2013 Firestorm
I'm probably going to be putting in a boost gauge, as well as AFR
wrxgoose is offline   Reply With Quote
Old 12-16-2013, 06:06 PM   #10
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Boost and AFR are the two most important things to monitor. I would want a way to easily monitor both while still looking out the windshield as things happen quickly during a boosted 3rd gear pull.
LtS720 (12-18-2013)
Old 12-16-2013, 07:07 PM   #11
SmsAlSuwaidi
Boosted
This ^ during pulls they're crucial. A wise man that got me into tuning swears by EGTs too, he always says you need to know your egts
Sent from my IBrick
The Following User Says Thank You to SmsAlSuwaidi For This Useful Post:
LtS720 (12-18-2013)
Old 12-23-2013, 12:15 PM   #12
Bl1tzkr1eg
Drives: Toyota 86
On Vortech SC
Mine are:
AEM wideband failsafe AFR gauge
D1-Spec Oil and Water Temp gauge
D1-Spec Boost gauge
Bl1tzkr1eg is offline   Reply With Quote
The Following User Says Thank You to Bl1tzkr1eg For This Useful Post:
LtS720 (12-26-2013)
Old 12-23-2013, 12:24 PM   #13
jamesm
how do you see any of the other gauges? there is a coolant temp gauge blocking your other coolant temp gauge .
Old 12-23-2013, 12:31 PM   #14
Danny86
Danny86's Avatar
Drives: 2013 Scion FRS Raven Black M/T
^ and who needs to know how much gas the car has anyhow?
Sent from my SCH-I545 using Tapatalk
Danny86 is offline   Reply With Quote
Cyberstork gauges ANREX Cosmetic Modification (Interior/Exterior/Lighting) 53 08-11-2016 06:07 PM
In dash gauges Shinjae Cosmetic Modification (Interior/Exterior/Lighting) 15 01-19-2015 06:29 AM
WTB: Gauges AtlasMick Engine, Exhaust, Bolt-Ons 2 03-29-2013 12:04 AM
Software Gauges shirouxkamui Electronics | Audio | NAV | Infotainment 1 08-12-2012 10:30 AM
Gauges CyberFormula Scion FR-S / Toyota 86 GT86 General Forum 45 07-24-2010 06:26 PM
