Gauges for supercharger?
I know that a AFR wideband is recommended, what others though are y'all using?
A smile gauge so you can measure how many times you'll be smiling when your boosting.
If you have an android device download torque and get a blue tooth obd2 adapter it shows afr and boost might save ya a few bucks
if i were doing it again i'd go for the p3cars obd2 gauge. it looks clean and gives you everything you need. the downside is it's obd2 so you have to leave it plugged in there and if you use brzedit it probably won't work, as most obd2 things don't (i know my innovate ot-2 doesn't). when i get back on romraider i'm definitely going to pick one up.
Check my build journal I have a few videos and pics/info of P3 in action etc... |
Like isnt a o2 senor way better ? |
I'm probably going to be putting in a boost gauge, as well as AFR
Boost and AFR are the two most important things to monitor. I would want a way to easily monitor both while still looking out the windshield as things happen quickly during a boosted 3rd gear pull.
This ^ during pulls they're crucial. A wise man that got me into tuning swears by EGTs too, he always says you need to know your egts Sent from my IBrick |
On Vortech SC
Mine are: AEM wideband failsafe AFR gauge D1-Spec Oil and Water Temp gauge D1-Spec Boost gauge http://i847.photobucket.com/albums/a...psa7930e8c.jpg |
how do you see any of the other gauges? there is a coolant temp gauge blocking your other coolant temp gauge ;).
^ and who needs to know how much gas the car has anyhow? :D
Sent from my SCH-I545 using Tapatalk |
| All times are GMT -4. The time now is 07:19 PM. |
User Alert System provided by
