FullBlown
Old 12-13-2013, 08:26 PM   #15
Frs300
Frs300's Avatar
Drives: Pile of junk
v161
First gear: 3.724:1
Second gear: 2.246:1
Third gear: 1.541:1
Fourth gear: 1.205:1
Fifth gear: 1:1
Sixth gear: 0.818:1
Frs300 is offline   Reply With Quote
The Following User Says Thank You to Frs300 For This Useful Post:
SirBrass (05-15-2014)
Old 12-13-2013, 09:42 PM   #16
taylork057
Drives: 2013
Why not just buy a quaife at this point. Only a few more dollars and a sequential trans. And why not base it off a much cheaper and easier trans to locate.. T56?
taylork057 is offline   Reply With Quote
Old 12-13-2013, 09:50 PM   #17
diss7
Drives: AE86, 2x GT86, TE27
You've obviously never driven a sequential. They're brutal.
Also, a quaife is no where near as strong or as streetable as a v16x.
A v16x conversion kit is a welcome product in my eyes. The box we're running isn't exactly going to be cheap to replace. I would wager you could find a v16x cheaper. Question is do you do it before or after blowing a box. If you do it before, you can always swap it back before selling the car.
I've never seen the point in intentionally blowing something up, when you're going to replace it. Pull the good unit out first and store/sell it.
diss7 is offline   Reply With Quote
The Following 4 Users Say Thank You to diss7 For This Useful Post:
B L U E S L A T E (12-15-2013), cf6mech (12-15-2013), Joveen (11-05-2018), SirBrass (05-15-2014)
Old 12-13-2013, 10:01 PM   #18
slicktop
Drives: 2013 Raven FRS 2JZ-GTE/V160 swapped
@FullBlown - is there no required firewall modifying? V160 is a big bitch
-slicktop
2013 Scion FRS
2JZ-GTE/V160 Swap Build Thread
slicktop is offline   Reply With Quote
Old 12-13-2013, 10:23 PM   #19
KAR
Drives: Whiteout 6spd
Oh nice, now if I dont find a use for my spare sup trans, it will go on the FRS
KAR is offline   Reply With Quote
Old 12-13-2013, 10:40 PM   #20
taylork057
Drives: 2013
I owned a S2000 quaife back when i had my car time attack car.. I know them very well (and service them). For the price of that kit and trans, Id rather spend a few more $$ and have the sequential. My .02.
The Following User Says Thank You to taylork057 For This Useful Post:
leicaboss (01-14-2014)
Old 12-14-2013, 12:20 AM   #21
SmsAlSuwaidi
Boosted
SmsAlSuwaidi's Avatar
Drives: Not a supra....yet
I know that the tunnel needed " massaging to fit a 2j w/ a v160 so maybe this case is simmilar.
Old 12-14-2013, 12:37 AM   #22
RRnold
2 wheel member
RRnold's Avatar
Drives: JZA80, 997.1, Taco
That's bad ass!!
Not to add insult to injury but there is a guy on SF who just rolled his Soup and selling the entire car (has about 156K) for 10K; engine, tranny, diff, axle etc. I told him he's smoking crack if he want's 10K b/c who knows what the condition of the internals are in.
He's ok but the car is done. The guy is up in Sac and if anybody is interested, I can PM you his number.
Old 12-14-2013, 01:06 AM   #23
Hanni_0176
Hanni_0176's Avatar
Drives: 2013 Scion FR-S 10 Series MT
How much more does the V160 weigh compared to our stock trans?
Mods: K&N Air Filter - Open Flash Tablet (Stage 1 v1.55) - more to come!
Hanni_0176 is offline   Reply With Quote
The Following User Says Thank You to Hanni_0176 For This Useful Post:
SnapOv3st3r (12-16-2013)
Old 12-14-2013, 01:57 AM   #24
Poodles
Drives: 2015 Series.Blue
Hmmm.. so theoretically you could bolt up an R154 with a 1JZ bellhousing as well...
For those that don't know, the R154 is the MKIII Supra Turbo 5-speed. Yeah, you'd lose a gear, but 5th is actually a better highway gear than the 6th in the V160 because of the ratios. Plus the tranny is FAR cheaper than a V160.
Old 12-14-2013, 02:00 AM   #25
SmsAlSuwaidi
Boosted
This ! I used both , the v160 is far superior but price is an issue. Plus the gears are SO long on a r154
Sent from my IBrick
Old 12-14-2013, 02:02 PM   #26
FullBlown
FullBlown's Avatar
Drives: Scion FRS
Originally Posted by Dipstik-sportech View Post
So does this mean I won't destroy 4th gear anymore......? Curious how the starter and clutch will work
The bell housing will have to be modified to fit the starter, clutch will be a twin disc
we shouldn't have to mod the tunnel.
Not sure what the stock one weighs, the v160 weighs roughly 115lbs
Yes, you could run the R154
Sent from my IBrick
If you look hard enough, you can find them for around $3500. Not cheap but a gearset for this trans will end up costing just as much if not more.
FullBlown is offline   Reply With Quote
Old 12-15-2013, 01:04 AM   #27
SilverSkyline210
SilverSkyline210's Avatar
Drives: WRB BRZ
from what i remember in BRZ class, our manual trans weighs about 95 lbs
SilverSkyline210 is offline   Reply With Quote
Old 12-15-2013, 02:45 AM   #28
cf6mech
Drives: FRS Silver LS1 swapped.
Our Aisin in the FRS/BRZ cost $4.800.00 to $5,000.00 last time I checked and rated to only 210ftlbs of torque,....if your FI this is something you will definitely have to consider. Kudos to Full Blown and Don at Accelerated Performance for addressing this weak link.
cf6mech is offline   Reply With Quote
The Following User Says Thank You to cf6mech For This Useful Post:
nickw14 (07-18-2016)
BEST HID Conversion Kit out there?? VADER Cosmetic Modification (Interior/Exterior/Lighting) 29 03-30-2017 07:50 AM
E85 conversion ender2664 Engine, Exhaust, Transmission 6 09-15-2013 10:58 PM
Engine Speed vs Vehicle Speed for 6MT DetroitJake Engine, Exhaust, Transmission 22 04-27-2013 06:56 PM
jdm conversion here it is jdmboss86 Cosmetic Modification (Interior/Exterior/Lighting) 2 06-28-2012 02:26 AM
LED Conversion [M] Cosmetic Modification (Interior/Exterior/Lighting) 38 06-18-2012 08:44 PM
