Old 12-13-2013, 11:16 AM   #43
DAMotorsports
Drives: 2013 Scion FRS "Raven"
Originally Posted by mike the snake View Post
I had read that the rods were angled at the big end for ease of construction. I assumed aftermarket rods would be normal.
My car is getting turboed, with methanol injection, on 91 gas. I'm going for as much safe power as I can get on the stock block and 91.
I am however also getting bigger radiator, oil cooler, clutch, and I'm hoping my engine will handle track days and still be reliable. If it blows I'll definitely get a built block though.
All of the current rods have the same design. As far as ease of construction it's similar to all subi motors. But the clearance are tighter then the EJ
DAMotorsports is offline   Reply With Quote
Old 12-13-2013, 06:00 PM   #44
Jason@DSG
Jason@DSG's Avatar
Drives: 1997 Eagle Talon TSi AWD
No stroker possible for safe clearances (or a negligible stroker kit). Also, a stroker would really be useless IMO as they create lower end torque. These are already drift-y burnout type cars that can be out of hand, you don't want to throw another unnecessary 80wtq at 2200 rpm lol (exaggeration...)
Most important, engine/head components which we have en-route, testing soon as well.
These engines are screaming for high revs and high boost applications.
Jason@DSG is offline   Reply With Quote
The Following 4 Users Say Thank You to Jason@DSG For This Useful Post:
chiefshayan (12-14-2013), Shinobi (12-20-2013), Team STILLEN (12-13-2013), xDanger_208x (12-13-2013)
Old 12-13-2013, 06:01 PM   #45
Jason@DSG
Jason@DSG's Avatar
Plus, there's the full SSP line up for the AT guys looking to go big!
The Following User Says Thank You to Jason@DSG For This Useful Post:
Old 12-13-2013, 06:11 PM   #46
xDanger_208x
xDanger_208x's Avatar
Drives:
I think 250 whp NA would be killer!
xDanger_208x is offline   Reply With Quote
Old 12-13-2013, 06:14 PM   #47
Team STILLEN
Mark @ STILLEN
Team STILLEN's Avatar
Drives: 2015 Subaru BRZ
I don't think you're gonna see that out of a 2.0 without super high rpms and cams that ruin street driving. Stroker would just make the engine less stable at higher rpms.
| Mark Dorman | Performance Specialist | markd@stillen.com| IG @Mark_STILLEN | www.STILLEN.com
Team STILLEN is offline   Reply With Quote
The Following User Says Thank You to Team STILLEN For This Useful Post:
Jason@DSG (12-13-2013)
Old 12-14-2013, 12:00 PM   #48
xDanger_208x
Drives:
I guess I have high expectations. I suppose I'd settle for 220-230.
Old 12-14-2013, 12:30 PM   #49
Team STILLEN
Mark @ STILLEN
FRS stroker kit?
220-230 Wheel or Crank HP?
Old 12-14-2013, 12:31 PM   #50
xDanger_208x
Drives:
Wheel
Old 12-14-2013, 12:35 PM   #51
Team STILLEN
Mark @ STILLEN
230 wheel horsepower would still be damn impressive out of a 2.0L engine (assuming you still wanted it to be easily streetable and have a decently smooth idle).
Old 12-15-2013, 05:47 PM   #52
kroyoftheempire
Drives: 2013 Firestorm FR-S
Really? so i guess s2000's and those all motor 300whp k series cars are not streetable at all eh?
There is a market for N/A in this car however i believe people are too lazy to find it, or the parts are still way in experimental/development stage. it is true the going fi is cheaper but n/a cars will always feel better, be simpler to work on, have better response, and of course will be more expensive lol
kroyoftheempire is offline   Reply With Quote
The Following User Says Thank You to kroyoftheempire For This Useful Post:
wparsons (12-19-2013)
Old 12-15-2013, 08:00 PM   #53
Snake
Drives: ADM Toyota 86 GT
The reason a 300kw K series engine is still streetable is because they have V-tec which is 2 camshaft profiles on the one cam. This allows a nice streetable low lift profile for low revs, then a crazy high lift, long duration cam for high revs. In other non-Honda products, this is called a variable lift camshaft which is significantly different to a variable timing camshaft which only allows the camshaft timing to be adjusted.
On a car without variable lift, getting the engine to make a huge amount of power at high revs will sacrifice low end driveability because it requires very high lift, long duration cams which don't work at low revs.
If you were able to get this motor to run while making 300kws, it would be undriveable on the street.
Snake is offline   Reply With Quote
The Following User Says Thank You to Snake For This Useful Post:
Team STILLEN (12-19-2013)
Old 12-19-2013, 05:04 PM   #54
DAMotorsports
So as we have post we are testing cams for the FA20. I am still tied as to what information I can provide at this time be we are strapped on the dyno and will post some numbers and as much information the company will allow
The Following 6 Users Say Thank You to DAMotorsports For This Useful Post:
chiefshayan (12-19-2013), Mathewgzlz (12-19-2013), Stevo22 (12-19-2013), TRD_07 (12-20-2013), Turdinator (12-19-2013), xDanger_208x (12-19-2013)
Old 12-19-2013, 05:52 PM   #55
DAMotorsports
Well the rev Limit had to be raised and the motor is flowing better...... More to come
The Following 5 Users Say Thank You to DAMotorsports For This Useful Post:
Hallucin8 (12-20-2013), Snake (12-19-2013), Stevo22 (12-19-2013), TRD_07 (12-20-2013), Turdinator (12-19-2013)
Old 12-19-2013, 05:55 PM   #56
Freeman
Freeman's Avatar
Drives: 2013 Ultramarine FR-S
Hopefully a bump in low end torque also!
sent from my locker... help!
Freeman is offline   Reply With Quote
The Following User Says Thank You to Freeman For This Useful Post:
DAMotorsports (12-19-2013)
dyno with no proof, never ever cams
HKS Premium Day 2013: FA20 stroker kit and cams cyde01 Engine, Exhaust, Transmission 33 06-18-2014 03:03 AM
Any stroker kits yet? HighLife Engine, Exhaust, Transmission 26 01-29-2014 04:16 PM
Toda headers + stroker kit in development diss7 Engine, Exhaust, Transmission 2 08-09-2013 07:55 AM
Stroker Kit for the love of god!!! FAER Engine, Exhaust, Transmission 24 08-03-2013 05:54 PM
FS: Murdered Out 1994 Caprice 383 Stroker husker741 Cars for Sale/Trade 0 04-15-2013 11:49 PM
