Old 12-11-2013, 07:21 PM   #197
post_break
Professional Smartass
post_break's Avatar
Drives: White Out FRS
On a related note. Heuberger Subaru in Colorado can go fuck themselves. I placed an order for the correct oil cooler bolt over the phone two days ago. They had 3 in stock at that exact moment. I called today and they don't have my order. So I gave someone there my credit card info, they either wrote it down or faked it, and now they don't have any more in stock.
Whoever else ordered your bolts from them you lucked out. I just ordered the bolt from ebay.
post_break is offline   Reply With Quote
Old 12-11-2013, 07:23 PM   #198
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
Originally Posted by mav1178 View Post
vs
http://www.ft86club.com/forums/attac...1&d=1386805180
By eyeballing I see the STi bolt as ~4 5/16". That translates to around 10mm longer than the Forester bolt that I measured.
-alex
Old 12-11-2013, 11:12 PM   #199
CARNZ
CHECK ENGINE
Drives: 2004 STi
Update on Parts Availability:
21311AA170 - Backorder ETA Jan-04-2014
14050AA970 - Backorder ETA Dec-12-2013 (this has changed daily so IDK whats going on.)
21328AA220 - Immediate Availability
99078AB330 - Immediate Availability
21317AA070 - Backorder ETA Dec-17-2013
i don't cry about crickets
CARNZ is offline   Reply With Quote
Old 12-12-2013, 08:57 AM   #200
post_break
post_break's Avatar
21317AA070 Is in stock on ebay, that's how I was able to get mine.
Old 12-12-2013, 09:23 AM   #201
CARNZ
CHECK ENGINE
Drives: 2004 STi
Cool, just going by Subaru's online parts inquiries, currently zero in the warehouses
Old 12-19-2013, 07:35 PM   #202
kmbkk
First 86 Driver Baby!
kmbkk's Avatar
Drives: FR-S, Flex
I'm interested in doing this. Is the original parts list list in post #1 still accurate or are there more options? Yes I've read through the entire thread, just wanted to clarify.
kmbkk is offline   Reply With Quote
Old 12-19-2013, 08:03 PM   #203
CARNZ
CHECK ENGINE
Drives: 2004 STi
Yes it is still accurate!
There are other ways to substitute the water pipe, but if you want to do it like I have in the instructions, then follow the parts list.
Old 12-20-2013, 09:42 AM   #204
kmbkk
kmbkk's Avatar
Drives: FR-S, Flex
Thanks! I want it to look as OEM as possible, so I'll probably go your route.
Old 01-03-2014, 01:29 AM   #205
Turkish
Serial Cone Killer
Turkish's Avatar
Drives: '14 BRZ - WRB Premium 6MT
In addition to being oemish, this looks like it will have zero space issues with a TRD intake which likes to FILL up that space in front of the engine. That would be a certain win for a lot of people looking to cool/warm their oil who are using that intake (like me).
For those who hear him call...
... his name is...
C'THULHU
Turkish is offline   Reply With Quote
Old 01-12-2014, 01:27 PM   #206
Doborder
Godzilla Konvert
Doborder's Avatar
Drives: DMG BRZ Limited 6MT 2013
can someone post a final list of all the parts needed. I just read through all of it and there appears to be parts added and parts not used. I wanted to order all of the parts and have someone work on this for me. Thanks in advance!!!
2013 Subaru BRZ Limited MT (DMG)
CO>CA Cartel
Doborder is offline   Reply With Quote
Old 01-12-2014, 01:46 PM   #207
that_guy
Dances with Cones
that_guy's Avatar
Drives: 2013 Scion FR-S Raven
Originally Posted by Kostamojen View Post
The 2014 Forest XT oil cooler is so far the only one specifically made for the top mounted oil filters on the FB/FA motors.
Its also the same one used on the STI concept:
This oil cooler looks to have different inlets/outlets on it. The routing of lines also looks different. Notice how the inlet side doesn't route down the front of the block, but rather over the back?
I'd be interested in knowing more about what setup they've employed on the STI really. Also like to see a vendor here take on the task of redesigning the lower/rear hard-line so that this becomes more of a plug and play solution.
2013 Scion FR-S - Raven
2011 Scion tC - Cement - SOLD
that_guy is offline   Reply With Quote
Old 01-13-2014, 08:47 PM   #208
CARNZ
CHECK ENGINE
Drives: 2004 STi
If you want to do it the way I did, then follow the parts list on the first page.
Old 01-13-2014, 09:55 PM   #209
TIE Pilot
TIE Pilot's Avatar
Drives: TIE interceptor; BRZ13
+1 to what that guy said.
"Speed has never killed anyone. Suddenly becoming stationary, that's what gets you." Jeremy Clarkson
TIE Pilot is offline   Reply With Quote
Old 01-16-2014, 02:39 AM   #210
kbye
kbye's Avatar
Drives: 2014 FR-S
I don't think it requires too much of a re-design, is it not already plug and play? The issue is that the pipe bends on the forester instead of straight on the brz, no? Would it be possible to just cut it up and re-weld it back on straight?
kbye is offline   Reply With Quote
brz, fxt, oil, oil cooler
OEM Oil cooler from the 2.0 DIT Forester Kostamojen Engine, Exhaust, Transmission 119 09-10-2019 05:28 AM
Bought a 2014 Subaru Forester EAGLE5 Other Vehicles & General Automotive Discussions 10 10-02-2013 12:54 PM
2014 Forester key fob - nicer than BRZ Turbowned Cosmetic Modification (Interior/Exterior/Lighting) 3 04-17-2013 03:35 PM
BRZ 2.0L Turbo in 2014 Forester Sleeperz BRZ First-Gen (2012+) — General Topics 37 03-21-2013 06:42 PM
Review after test driving a 2013 WRB BRZ and 2014 Forester in Okinawa, Japan… 2013GTRNate BRZ First-Gen (2012+) — General Topics 12 02-01-2013 12:29 PM
