Old 06-10-2013, 11:17 PM   #1
gatorbushmen
Amateur Drifter
gatorbushmen's Avatar
Drives: '13 FRS
Anyone with Eibach Sportlines
I know there are plenty of you guys running the Eibach Sportlines, could you provide any feedback, i.e. if you blew any struts, or if they have been perfect for you.
I know the drop is a little extreme for the stock strut....
Anyways, I'm in the market for some lowering springs (coilovers will come eventually) and I would love to hear your experience with the Sportlines.
gatorbushmen is offline   Reply With Quote
Old 06-11-2013, 05:45 AM   #2
Pitman
Living the dream
Pitman's Avatar
Drives: Fensport AVO Turbo GT86
I have them fitted to my car. Although it is early days, only about 1000 miles with them, I certainly have no regrets. The ride is just as good as with the standard springs. I also had the wheel alignment re-done after having them fitted.
Here is how my car looks with them:
Pitman is offline   Reply With Quote
Old 06-11-2013, 04:09 PM   #3
gatorbushmen
Amateur Drifter
Drives: '13 FRS
Thanks! Great looking car btw.
Rota grids?
Old 06-11-2013, 04:38 PM   #4
suaveflooder
These wheels 8.5's up front?
suaveflooder is offline   Reply With Quote
Old 06-12-2013, 03:36 AM   #5
Pitman
Living the dream
Pitman's Avatar
Thank you for the nice comment, gatorbushmen
Rims / tires are
Rota Grid 18 X 8.5 ET44 Fronts
Roto Grid 18 X 9.5 ET38 Rears
Goodyear F1 Asym. 2 225/40 front, 245/35 rear
As well as the Eibach Sportlines, I also have had fitted
Whiteline 16mm adjustable anti-roll bar
Summit Swave Rear Adjustable Toe Control Arm Set
Summit Swave Rear Adjustable Camber Control Arms
Fensport Front Camber Adjust Bolts
Whiteline Offset top mounts
Summit Swade Front Strut Bar
Beatrush brake master cylinder brace
Old 06-12-2013, 12:50 PM   #6
gabeg86
gabeg86's Avatar
Drives: 2013 Raven FR-S
I have had mine for about a month now and love them. I don't know about anyone else, but the ride is definitely a little more firm and less forgiving with bumps, etc., but nothing extreme. Stock struts still intact
Perrin (LWCP) - Blox (shift knob) - HID Powerhouse (LED's and HID's) - Eibach (sportlines) - Muteki (lugs) - SPL (LCA's) - Rays Engineering (57dr's) - Dunlop Direzza ZII (tires) - Greddy (Evo3) - Full Race (turbo kit) - Ecutek (tuned)
gabeg86 is offline   Reply With Quote
Old 06-12-2013, 06:19 PM   #7
Speed Element
Speed Element's Avatar
Drives: FR-S, Evo X, IS-F, 335i, STi, LS460
Send a message via AIM to Speed Element
We've had customers with them and they love it as it's just a tad bit more aggressive than stock, but with a nice drop.
Speed Element is offline   Reply With Quote
Old 06-12-2013, 09:56 PM   #8
ihaskrayon
The Comedian
Drives: SWP BRZ Limited
Will I have any problems with 18x9.5 +44 with 245/40/18 in the rear?
I'm debating on if I should get these or the pro kit.
ihaskrayon is offline   Reply With Quote
Old 12-11-2013, 11:08 PM   #9
kALMIGHTY
Drives: TRD Ultramarine '13
Reviving an old thread, but I have a few questions about these.
I'm considering getting the Sportlines because frankly, I'm getting tired of waiting for TRD to release their springs for our cars.
Now, I'm 90% sure I won't be getting new wheels or tires when the snow melts like I was planning too but I do want to drop the car a bit. BUT I know dropping the car is going to suck in those wheels and I hate that look so I'm thinking of getting spacers for the stock wheels and tires.
What do you recommend? Is it doable with JUST the Sportlines and spacers? Or will I need more things, like camber bolts, LCAs and what not?
Old 12-12-2013, 12:58 AM   #10
FT-86 SpeedFactory
FT-86 SpeedFactory's Avatar
You'll need camber bolts up front. If you're fine with -1 to -1.5 rear then nothing out back is needed.
The by the book method is to do springs with camber bolts and camber arms. Can you get away with less? Sure, but you can only make that call.
And spacers make everything look better.
FT-86 SpeedFactory is offline   Reply With Quote
Old 12-12-2013, 01:18 AM   #11
kALMIGHTY
My idea set up as far as the stock tires and wheels goes is flush with the fender because I don't like how far in they are in the fender wells stock, but also I don't want any camber. I really don't like the look of it. Will camber arms help that?
Old 12-12-2013, 01:39 AM   #12
FT-86 SpeedFactory
Yep you will need arms then when lowered in the rear to fix it.
Old 12-12-2013, 01:44 AM   #13
kALMIGHTY
Do you sell them? Just thinking of starting to compile a list of things to see how much it'll all cost me so I can decide if I'd rather just save up for wheels without a drop lol.
What spacers would you recommend to get them flush with Sportlines?
Old 12-12-2013, 01:55 AM   #14
FT-86 SpeedFactory
We do. Hit our site. Best bet is 10mm spacers.
Wheel Directory: Work Emotion CR Ultimate "Kiwami" 18x8.5 +38 / 18x9.5 +38 f0rge Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 14 01-16-2015 02:57 AM
FS: Stock Struts w/Eibach Sportlines OmarGC Brakes, Suspension, Chassis 4 06-09-2013 05:52 PM
NY: F/S Eibach Sportlines delusional Brakes, Suspension, Chassis 7 04-26-2013 12:35 PM
eibach sportlines clunking.. frsguy707 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 16 10-24-2012 11:42 AM
Eibach Sportlines Finally Available! PRO Import Tuners Brakes, Suspension, Chassis 1 08-22-2012 07:42 PM
