Old 12-11-2013, 06:31 PM   #15
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
Originally Posted by Victor Draken View Post
what is oft dollar i couldn't see any description about it.
From the website
With the purchase of the OpenFlash Tablet you are also rewarded with an equal value ($495) of OFT Dollars. For additional savings, you can apply these OFT Dollars to the purchase of other products for your vehicle. When buying other products, simply click on the purchase link that applies the maximum OFT Dollar discount. Since you can't use all your OFT Dollars credits in one purchase, they will be saved in your customer account for future purchases.
Shiv@Openflash is offline   Reply With Quote
The Following User Says Thank You to Shiv@Openflash For This Useful Post:
Victor Draken (12-11-2013)
Old 12-11-2013, 06:32 PM   #16
Victor Draken
Drives: Toyota Gt86
Originally Posted by shiv@vishnu View Post
It's hard for me to do revisions on international cars/fuel that I don't have access to. We can do some e-tuning support if that is something that you are interested. If so, email me at shiv@vishnutuning.com. It takes some time to dial it in correctly but it's a good option if you are comfortable with making the changes yourself or don't have a local tuner who can do it for you.
Cheers
shiv
are you selling now e-tuning as well with the OFT?
because that would be a big step.
Victor Draken is offline   Reply With Quote
Old 12-11-2013, 06:35 PM   #17
Shiv@Openflash
Drives: 2013 FRS
Originally Posted by Fast_Freddy View Post
What is the procedure for getting one of the OFT generic base tunes corrected for a particular setup? I understand that these base tunes should be in the ball park but obviously they need to be fine-tuned for different setups. Is this supposed to be Shiv or the end-user? What does it cost for each remote tune update from Shiv?
While the OFT maps are open and editable by anyone, we can certain do remote e-tuning if that is what makes you most comfortable. The cost of the job depends on the complexity and is determined on a case by case basis. If you're interested, email me at shiv@vishnutuning.com. Mind you, this service is limited to those who have setups that we have already tuned (so far just NA and light pressure SC kits). We don't expect to do e-tuning high boost turbo kits anytime soon.
Old 12-11-2013, 06:56 PM   #18
Dustin
Twin Screw You
Dustin's Avatar
Drives: 2013 Supercharged Whiteout FR-S
Anything for the Innovate SC in the near future?
Dustin is offline   Reply With Quote
Old 12-11-2013, 07:00 PM   #19
Malt
Drives: 2015 WRX
Shiv,
when comparing the new UEL E85 maps to the old E85 maps it appears you've changed the MAF sensor scaling? Is this intentional?
Malt is offline   Reply With Quote
Old 12-11-2013, 07:15 PM   #20
Shiv@Openflash
Drives: 2013 FRS
Originally Posted by Malt View Post
Shiv,
Yes indeed. There are a lot of changes made in the UEL map (closed loop fueling, VVT, ignition timing, open loop fuel, etc,.) and they are all intentional
The UEL E85 Stage 2 map is probably the most developed map we have ever released. I started developing it 4 weeks ago when I installed the production version of the OpenFlash header. And it's been tested/tweaked every day. It was only last week that I stopped fine tuning and and have been tested long term stability. And it's been pretty great so far. Looking to see more customer data logs
Old 12-11-2013, 07:18 PM   #21
Malt
Drives: 2015 WRX
The UEL E85 Stage 2 map is probably the most developed map we have ever released. I started developing it 4 weeks ago when I installed the production version of the OpenFlash header. And it's been tested/tweaked every day. It was only last week that I stopped fine tuning and and have been tested long term stability. And it's been pretty great! I'll post up another thread with logs for further discussion
OK, just making sure before I flash it. I'll take logs tonight and tomorrow with my borla UEL and hopefully everything will work out fine. Its been dipping down to the mid and high 20's at night so I've been dealing with nasty cold start issues, but I've got them down to one or two cranking attempts with some help from the romraider crew. This is why I love open tunes instead of the other options that are locked down, I can get help from lots of places to fix my own issues.
The Following User Says Thank You to Malt For This Useful Post:
Shiv@Openflash (12-11-2013)
Old 12-11-2013, 07:36 PM   #22
enwave
That headunit though...
enwave's Avatar
Drives: 2013 Subaru BRZ Limited SSM
Do those of us who purchased an OFT early still get OFT dollars credited to our account?
2013 BRZ Limited SSM 6AT
Phantom ESC 1.5Dump + E85 + OFH + Q300
Eibach Pro-Kit + Michelin PSS (stock size)
enwave is offline   Reply With Quote
The Following 5 Users Say Thank You to enwave For This Useful Post:
3essess (12-12-2013), Boofneenee (12-11-2013), cjsporl1996 (12-11-2013), pjpetrozelli (12-11-2013), StormTrooper (12-12-2013)
Old 12-11-2013, 07:46 PM   #23
Shiv@Openflash
Drives: 2013 FRS
Of course! Just as long as we have you in our customer records as an OFT buyer, you get the same OFT dollar discounts
The Following 6 Users Say Thank You to Shiv@Openflash For This Useful Post:
3essess (12-12-2013), cjsporl1996 (12-11-2013), enwave (12-11-2013), mkivsoopra (12-12-2013), normancw (12-11-2013), YMAA (12-12-2013)
Old 12-11-2013, 07:51 PM   #24
Shiv@Openflash
Drives: 2013 FRS
That's great to hear. If you let me know what your cold start settings are, I can test them myself and perhaps integrated them into the OTS maps for everyone else
fstlane (12-11-2013)
Old 12-11-2013, 07:52 PM   #25
FRSFirestorm
Red is Fastest
FRSFirestorm's Avatar
Drives: 13 FRS 6MT Firestorm
Might have to try me a tank of E85 with my new EL header. Couldn't run it all the time it would be a hassle running across town to get. Another nice thing about OFT, having the ability to swap on the fly when I want.
FRSFirestorm is offline   Reply With Quote
The Following User Says Thank You to FRSFirestorm For This Useful Post:
Old 12-11-2013, 08:23 PM   #26
8686
8686's Avatar
Drives: 86
I am intrested in e-tuning. Just sent you an email.
Cheers
shiv
VOLK LE37 17X7.5, SWIFT Springs, Bilstein B8, HKS intake duct, Cosworth Air Filter, HKS headers, PLM Over Pipe, EVS Down Pipe & Exhaust, FD 4.55, GFB pulleys, Axle-Exchange Drive Shaft, Mishimoto oil cooler, Cusco F&R strut bar, TRD door stabilizer, Innovate SC, Delicious Tuned
8686 is offline   Reply With Quote
Old 12-11-2013, 08:35 PM   #27
Shiv@Openflash
Drives: 2013 FRS
Ok. We should have the options for custom e-tuning on the website either tomorrow or day after.
Old 12-11-2013, 09:00 PM   #28
CamryDS
Drives: 2003 Camry Blue | 2013 FR-S White
I cannot exaggerate this enough when I say "YOU SIR ROCK!!!"
Thank you for the continuing support and work on this car!!!
CamryDS is offline   Reply With Quote
The Following 2 Users Say Thank You to CamryDS For This Useful Post:
enwave (12-11-2013), Shiv@Openflash (12-11-2013)
OpenFlash Tablet Rombinhood@OpenFlash Software Tuning 1838 07-29-2023 06:35 PM
Openflash Tablet v1.31 beta maps (including Stage 2!) now available for download Shiv@Openflash Software Tuning 354 02-08-2015 05:23 PM
OpenFlash Tablet E85 (and gasoline) Maps now available Shiv@Openflash Software Tuning 401 08-13-2014 11:14 PM
OpenFlash Tablet Stage 1 v1.2 maps available for download Shiv@Openflash Software Tuning 31 10-31-2013 08:45 PM
WTB Openflash Tablet Vlady Want-To-Buy Requests 0 10-25-2013 12:10 AM
