Old 12-06-2013, 08:54 PM   #43
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Originally Posted by CSG David View Post
No weight saving measures have been performed...even the spare tire and jack are left in the car...(please don't do this when you go out on track).
I'm too lazy to remove mine too so my jack/etc are almost always left in as well. Only on longer trips when i bring a full size spare do I remove it (because I don't bolt it down).
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
The Following User Says Thank You to Dave-ROR For This Useful Post:
CSG David (12-09-2013)
Old 12-09-2013, 11:08 AM   #44
industrial
Add lightness!
industrial's Avatar
Drives: 17' WRX
So what I'm getting from you guys is....a 400 pound weight reduction is not significant on this platform. Neither are NA engine mods. Not sure I buy that this is all there is to the story but ok.
industrial is offline   Reply With Quote
Old 12-09-2013, 01:58 PM   #45
mike156
Drives: EVO
Different driver...#1 mod in racing.
Weight removal makes the car faster. If the driver can extract those gains is a whole different story. I know Robi is no amateur, but that could be the difference.
Could also be the willingness of the driver to turn that fine-tuned machine into a ball of recycled steel.
mike156 is offline   Reply With Quote
Old 12-11-2013, 03:22 AM   #46
CSG David
CSG David's Avatar
Somewhat off topic since the OP wants to save weight in the brakes and I feel this is a fairly dangerous to do especially since the OP cares about performance. For repeatable performance, proper braking system is required. While 400lbs makes a difference, I wouldn't take weight out of the brakes. The importance of this topic lies in saving weight at the brakes. We can fade the stock brake caliper and rotors with race pads on a downhill canyon runs. If you can do the same, then perhaps running smaller and lighter brakes is not the proper setup to go with.
If you were to do a drag race between Robispec's car and our car, you won't see very much difference. If you want to smoke someone, running FI is the best way to go.
Old 12-11-2013, 03:51 AM   #47
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
http://farnorthracing.com/autocross_secrets3.html
Old 12-11-2013, 04:54 AM   #48
diss7
Drives: AE86, 2x GT86, TE27
I have no idea how you are getting fade in the rear brakes. I have the lower spec non US spec rear brakes, solid discs, run TRD pads and I can't even get the damn things to wear. That's on semi slicks as well.
diss7 is offline   Reply With Quote
Old 12-11-2013, 09:10 AM   #49
Malt
Drives: 2015 WRX
I don't know your driving ability or experience but I'm going to guess it has something to do with the link posted above. Its obvious that this car offers way more performance than most people can extract and I've seen plenty of videos of BRZ's with minimal mods keeping up with caymans on track days. Obviously the cayman is a faster car so the difference must come from somewhere. If you think that brake setup is right for you, then go for it, personally I don't think its the best place to lose weight.
Malt is offline   Reply With Quote
Old 12-11-2013, 12:56 PM   #50
CSG David
CSG David's Avatar
Fading rear brakes might be a little difficult to feel, but looking at the braking system as a package, you can improve braking performance and longevity (small benefit) by utilizing the same braking compound front and rear. For example, running Carbotech XP12 front and rear, not just the front. With excessive front bias, getting the car to rotate during trail braking takes a little more effort to achieve properly. Even with the pedal dance, it is still not ideal.
This is utilizing Hankook RS3 + Project Mu 999 front and rear will give you, which is proper braking at all 4 corners. My right front rotor cracked right after this shot.
Old 12-11-2013, 01:04 PM   #51
OrbitalEllipses
Drives: Attitude
I still prefer a higher cf rear pad.
Old 12-11-2013, 01:42 PM   #52
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
:o even I don't go there!
Many S2K people thought I was loco for running higher rear tire pressures than the front for autocross and track use.
According to them I should have spun the car multiple times. For the record, it never spun.. ever. It needed more rotation
With S2K stock aero though I'd *guess* that a more agressive rear pad and high speed braking would be... interesting. BRZ would be a lot better though but I've found equal pads to work out pretty well so far.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 12-11-2013, 03:04 PM   #53
Captain Snooze
Drives: Red Herring
Fading rear brakes might be a little difficult to feel, ................... My right front rotor cracked right after this shot.
That is an awesome pic!
Old 12-11-2013, 03:12 PM   #54
Captain Snooze
Drives: Red Herring
[rant]
It annoys/amuses/intrigues me how Nürburgring times always say "this car did it in x minutes and y seconds" and rarely mention the driver.The drivers posting those lap time are not your average driver cruising about town. No car is going anywhere without the driver.
[/rant]
wparsons (12-11-2013)
Old 12-11-2013, 03:23 PM   #55
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
That's not evidence of anything. In a novice run group I could keep up with a Cayman in a stock Yugo on snow tires.
Ok maybe not, but the point is, driver talent varies so much that a BRZ with OEM sized brakes keeping up with "faster" cars isn't evidence of the cars performance.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 12-11-2013, 03:30 PM   #56
Malt
Drives: 2015 WRX
I think I either presented my comments poorly or I'm being misunderstood. Either way I agree with you, the driver plays a much larger role in a cars performance than modifications.
BUDDY CLUB Lightweight Racing Wheels - JDM, lightweight, low pricetag | 18x8.5" GuerillaRacing Wheels and Tires 116 01-20-2015 06:32 PM
WTB: REAR window top Brake Light (just top half with leds) or full rear deck Kayzer Soze Exterior Parts (Aero, Lighting, Etc.) 1 08-31-2013 02:23 PM
Rear Parking Brake Guard Rub (Meaty Rear Tires) console_cowboy Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 7 08-13-2013 02:39 PM
rear brake pads donutfilling Suspension | Chassis | Brakes -- Sponsored by 949 Racing 8 04-05-2013 10:43 PM
Secondary Rear Brake Caliper for drifting or parking brake?? (pics) Axel Scion FR-S / Toyota 86 GT86 General Forum 20 02-25-2010 10:28 AM
