Old 12-06-2013, 01:35 AM   #29
Ondreiko
RWD addicted
Ondreiko's Avatar
Drives: BRZ 6MT OFT OFH
Originally Posted by jeebus View Post
Running a bit on the rich side...what is the octane of the fuel in Moscow? Also, how friggen cold is it?
The fuel in here is 98 octane locally measured, it suppese to be equal to 93 AKI
fuel that you have in US. The temperature outside is around 0 degrees C.
My intake is stock, but snorkel is cut and Perrin foam air filter dropped in.
Ondreiko is offline   Reply With Quote
Old 12-06-2013, 01:58 AM   #30
Ondreiko
RWD addicted
Ondreiko's Avatar
Originally Posted by Rombinhood@OpenFlash View Post
Most likely a difference in fuel formulation. Stock intake/MAF housing?
As written above, inlet tube and airbox are stock, while the snorkel is cut and foam filter dropped in.
What am i suppose to do to make the mixture leaner a bit?
Old 12-06-2013, 02:48 AM   #31
the.big.kahoona
the.big.kahoona's Avatar
Drives: 2013 Raven 86
PM sent!
Sent from my SM-N9005 using Tapatalk
the.big.kahoona is offline   Reply With Quote
Old 12-07-2013, 01:13 AM   #32
Burn
Slack Bum
Burn's Avatar
Drives: FT86
Managed to do first 3 pulls ..http://datazap.me/u/burn/first-3-gea...-2-7-8-9-10-12 My AFR was about 11.37 on 3rd gear pull which makes me wonder if this is a bit too rich..
Burn is offline   Reply With Quote
Old 12-07-2013, 03:23 AM   #33
nlowell
nlowell's Avatar
Drives: 2013 Scion FRS
Ondreiko - I'm running the same map and getting the same results (11.25 AFR) on 91 pump in California. I'm going to switch to E85 and the associated map this weekend and see where that puts me.
nlowell is offline   Reply With Quote
Old 12-07-2013, 03:56 AM   #34
Kodename47
Kodename47's Avatar
Drives: UK GT86
Surely step 1 is to scale the MAF?
.: Stealth 86 :.
Kodename 47 DJ:
Old 12-07-2013, 05:02 AM   #35
Ondreiko
RWD addicted
Ondreiko's Avatar
Hi!
Let us know how your AFR changed on E85.
I can't test the same due to E85 absence in my area.
What does your Adv. Multiplier show on WOT pull?
Old 12-07-2013, 12:07 PM   #36
nlowell
nlowell's Avatar
My Adv. Multiplier is a solid 1 on all of my logs
Old 12-07-2013, 01:35 PM   #37
Ondreiko
RWD addicted
Ondreiko's Avatar
Great! Then i may suggest that rich mix was not caused by knock what means we should have it made leaner somehow.
My Adv multiplier logging feature is not available yet so i may just suggest that i have the same picture as you.
Old 12-07-2013, 09:05 PM   #38
akyp
Drives: 2012 86
@Rombinhood@OpenFlash @shiv@vishnu My car seems to be running rich as well: http://www.datazap.me/u/akyp/oft-sta...ll?1-8-9-10-11
G series ROM (ZA1J700G) and 98 RON fuel. Everything stock.
akyp is offline   Reply With Quote
Old 12-07-2013, 10:57 PM   #39
nlowell
nlowell's Avatar
Filled up with 10 gallons of E85 - flashed stage 2 e85 tune - drove 5 miles - ate dinner - drove another 5 miles - logged this pull in 3rd gear.
Adv. Multiplier was 1.0 the whole time - I'm pretty happy with the results but it does appear to be running a little rich with the AFR still coming down into the 11's (11.6 at 7k)
Old 12-08-2013, 01:37 AM   #40
Ondreiko
RWD addicted
Ondreiko's Avatar
Can someone advise what should we do to make the mixture leaner?
Should we wait untill Shiv updates the tables or can we try to fix it ourselves (don't actually figure the way how)?
Seems it's not only G-series ROMs feature since @nlowell is from US and is also running rich.
I have no idea what to start with - would someone suggest possible actions from an experts side?
Here is my WOT pull:
http://datazap.me/u/ondreiko/3-4-5-g...ll-wot?1-7-8-9
Old 12-08-2013, 02:57 AM   #41
Tromatic
I'm no expert, but from what I have been reading running a bit rich with the tunes provided is a built-in protection for the engine. Running lean can cause detonation and other more unpleasant problems.
Old 12-08-2013, 11:14 AM   #42
Ondreiko
RWD addicted
Ondreiko's Avatar
Yes, but not as rich as 11.25? I was thinking it should be within 12-12.5 AFR rate. Seems that just a few people have WOT AFR below 11.5.
Most of these people sofar running G-series ROMs.
What are other peoples readings for AFR rate on WOT?
Quick Review-OpenFlash (Dyno Test) - Stock vs. Vishnu Stage 1.0 vs. Vishnu Stage 1.1 FRSTEVE Software Tuning 105 08-04-2017 04:48 AM
Openflash Tablet v1.31 beta maps (including Stage 2!) now available for download Shiv@Openflash Software Tuning 354 02-08-2015 05:23 PM
Now Available: OpenFlash Datalog Viewer and DataZap! Shiv@Openflash Software Tuning 36 12-31-2014 05:59 PM
Top Gear Solutions| OpenFlash Tablet Tune| Stage 1 Tune, Stage 2, Custom and E85 TopGearSolutions Engine, Exhaust, Bolt-Ons 90 04-14-2014 08:15 PM
OpenFlash Tablet Stage 1 v1.2 maps available for download Shiv@Openflash Software Tuning 31 10-31-2013 08:45 PM
