Old 12-05-2013, 10:34 PM   #141
StormTrooper
StormTrooper's Avatar
Drives: Pavement MT GR86
Well I've done 2 logs....
Noticed after having to abort a pull.... Didn't realize people were going 45 on the freeway.
My adv multi is .76 instead of 1.0
Must have saw some knock somewhere. Guessing since its so cold out
GR86 MT premium
StormTrooper is offline   Reply With Quote
Old 12-06-2013, 12:39 AM   #142
Tromatic
Originally Posted by shiv@vishnu View Post
And yes, the ECU info section is still written in Italian. There is a new update coming out which will provide the ability to store more than 2 maps in the OFT. The language bug will be sorted out then since it's not really an urgent fix at this time. Shiv
I'm quite sure the Italian added at least 5hp.
Old 12-06-2013, 04:35 AM   #143
Kodename47
Kodename47's Avatar
Drives: UK GT86
Cold shouldn't be a reason for knock. Where does the IAM start at? Sometimes it's low RPM high load, like 5th/6th gear at low speed, where the engine can knock and cause IAM to drop.
My log procedure was to spend a few mins simulating all types of normal driving. Pulling away, short shifting 1st-2nd-3rd and cruising etc and then do WOT pulls when oil temp is up to scratch. This should then allow you to see any areas of weakness across any areas of the map. Is load logged as well?
.: Stealth 86 :.
Kodename 47 DJ:
Old 12-06-2013, 08:54 AM   #144
jamesm
iam dropping is always bad. it means your ecu entered rough correction, which means it detected serious knock multiple times in a row. you can read up on the parameters required for this to happen, but trust me it's bad for your engine.
but hey, at least your iam works. most of the e-tunes i've seen just effectively disable it. in any case, i'd get that resolved sooner rather than later.
Old 12-06-2013, 11:44 AM   #145
Kodename47
Kodename47's Avatar
Drives: UK GT86
Have you assumed that his IAM starts at 1? If it started at 0.7 and hadn't noticed then seeing 0.76 isn't a bad thing.
.: Stealth 86 :.
Kodename 47 DJ:
Old 12-06-2013, 11:46 AM   #146
jamesm
yes. good call. so used to setting initial to 1 lol.
Old 12-06-2013, 11:51 AM   #147
Kodename47
Kodename47's Avatar
Drives: UK GT86
Thought so. I know most are set to 1 but I believe Shiv's aren't out of the box as they're a little conservative.. That's not to say that people don't change it.
.: Stealth 86 :.
Kodename 47 DJ:
Old 12-06-2013, 12:20 PM   #148
cnk
Drives: '13 DGM BRZ Limited
If he's using the 1.34 Stg1 map, then the IAM is set at 1. I just verified it on the ROM.
Old 12-06-2013, 12:30 PM   #149
Rombinhood@OpenFlash
Drives: FRS
There is nothing wrong with adv multiplier moving around with Vishnu's tunes. From what I understand, it's actually to be expected with the pump gas maps. It's also possible but far less likely on the e85 maps. It's only when adv mult starts to consistently drop low (below 0.5) should you consider making the mapping less aggressive. Short of that, let it do what it wants to do. That's what coarse learning is there for. This general guideline applies to NA applications moreso than boosted ones though.
Rombinhood@OpenFlash is offline   Reply With Quote
Old 12-06-2013, 12:45 PM   #150
bfrank1972
Drives: 2013 FR-S Argento
Hmmm that's not what I read in this:
https://docs.google.com/viewer?a=v&p...dlMWVkYjI1Njg4
Rough correction pulls timing back everywhere and is typically said to be a sign of an 'unhappy ecu'. I am no expert, so correct me if I'm wrong, but you don't want rough correction - say your timing advance curve is peachy until 6000 rpm where it gets into severe knock (due to how advance is set), if rough correction kicks in it will pull timing everywhere (i.e. lower rpms where you don't need it), correct? Maybe the new ECU calculates timing differently than what's illustrated in the 'subie newbie' guide?
Thx
Old 12-06-2013, 12:50 PM   #151
Drives: FRS
Thx
There is also a fine learning correction that can offset the retard induced by the coarse adjustment. So even though Adv mult drops, you don't get into a situation where you are running unnecessarily conservative in some load/rpm points while too aggressive in others. Of course much of this depends on where the tuner sets the load/rpm fine learning breakpoints. In the oft maps, they been adjusted to be far more useful in NA applications.
Old 12-06-2013, 01:14 PM   #152
Tromatic
FYI, the guys at Vishnu are working on a nice video tutorial on how to conduct, view and analyze datalogs.
Maybe it's a generational thing, or maybe even a Marine thing, but I would REALLY like to have a written manual for this stuff, especially the tablet setup and ECU flash process.
Old 12-06-2013, 01:26 PM   #153
Drives: FRS
I agree that a written doc would be a good idea. But you'd be surprised how many people don't read docs and would rather watch a video instead. This is why they have been so involved with video tutorials. Seems to get the job done better than written docs for most people. But I do see your point and agree 100%
[ame]http://youtu.be/MWjdC3TEWyk[/ame]
Old 12-06-2013, 03:37 PM   #154
StormTrooper
iam droppingremays bad. it means your ecu entered rough correction, which means it detected serious knock multiple times in a row. you can read up on the parameters required for this to happen, but trust me it's bad for your engine.
I took a quick look at the logs and while i'm still unfamiliar with how that program works i can say the pulling of timing was after the pull. so my guess is low rpm high load freeway driving. (there is a pretty steep hill right after i tried to log and was cut off. 6th gear 65mph going to 70)
also i just started the car and the multiplier moved to .89 from .76 (Both logs show 1 )
I'm at 4500 ft its dry and about 15°F outside and 91 Oct.
Perrin filter, silicone inlet.....removed the expansion things off the intake.
GR86 MT premium
OpenFlash Tablet Rombinhood@OpenFlash Software Tuning 1838 07-29-2023 06:35 PM
Openflash Tablet v1.31 beta maps (including Stage 2!) now available for download Shiv@Openflash Software Tuning 354 02-08-2015 05:23 PM
Is Openflash tablet detectable? Boofneenee Software Tuning 25 05-02-2014 10:03 PM
***VISHNU OpenFlash Tablet IN STOCK*** Garrett@Openflash Engine, Exhaust, Bolt-Ons 15 12-17-2013 01:30 PM
WTB Openflash Tablet Vlady Want-To-Buy Requests 0 10-25-2013 12:10 AM
