#141 |
Drives: Pavement MT GR86
Well I've done 2 logs....
Noticed after having to abort a pull.... Didn't realize people were going 45 on the freeway. My adv multi is .76 instead of 1.0 Must have saw some knock somewhere. Guessing since its so cold out
GR86 MT premium
#142 |
I'm quite sure the Italian added at least 5hp.
#143 | |
Drives: UK GT86
Cold shouldn't be a reason for knock. Where does the IAM start at? Sometimes it's low RPM high load, like 5th/6th gear at low speed, where the engine can knock and cause IAM to drop. My log procedure was to spend a few mins simulating all types of normal driving. Pulling away, short shifting 1st-2nd-3rd and cruising etc and then do WOT pulls when oil temp is up to scratch. This should then allow you to see any areas of weakness across any areas of the map. Is load logged as well?
.: Stealth 86 :.
#144 |
iam dropping is always bad. it means your ecu entered rough correction, which means it detected serious knock multiple times in a row. you can read up on the parameters required for this to happen, but trust me it's bad for your engine.
but hey, at least your iam works. most of the e-tunes i've seen just effectively disable it. in any case, i'd get that resolved sooner rather than later. |
#145 | |
Drives: UK GT86
Have you assumed that his IAM starts at 1? If it started at 0.7 and hadn't noticed then seeing 0.76 isn't a bad thing.
.: Stealth 86 :.
#146 |
#147 |
Drives: UK GT86
Thought so. I know most are set to 1 but I believe Shiv's aren't out of the box as they're a little conservative.. That's not to say that people don't change it.
.: Stealth 86 :.
#148 |
Drives: '13 DGM BRZ Limited
#149 |
Drives: FRS
There is nothing wrong with adv multiplier moving around with Vishnu's tunes. From what I understand, it's actually to be expected with the pump gas maps. It's also possible but far less likely on the e85 maps. It's only when adv mult starts to consistently drop low (below 0.5) should you consider making the mapping less aggressive. Short of that, let it do what it wants to do. That's what coarse learning is there for. This general guideline applies to NA applications moreso than boosted ones though.
#150 | |
Drives: 2013 FR-S Argento
https://docs.google.com/viewer?a=v&p...dlMWVkYjI1Njg4 Rough correction pulls timing back everywhere and is typically said to be a sign of an 'unhappy ecu'. I am no expert, so correct me if I'm wrong, but you don't want rough correction - say your timing advance curve is peachy until 6000 rpm where it gets into severe knock (due to how advance is set), if rough correction kicks in it will pull timing everywhere (i.e. lower rpms where you don't need it), correct? Maybe the new ECU calculates timing differently than what's illustrated in the 'subie newbie' guide? Thx |
#151 | |
Drives: FRS
#152 |
Maybe it's a generational thing, or maybe even a Marine thing, but I would REALLY like to have a written manual for this stuff, especially the tablet setup and ECU flash process.
#153 | |
Drives: FRS
![]() [ame]http://youtu.be/MWjdC3TEWyk[/ame] |
#154 | |
I took a quick look at the logs and while i'm still unfamiliar with how that program works i can say the pulling of timing was after the pull. so my guess is low rpm high load freeway driving. (there is a pretty steep hill right after i tried to log and was cut off. 6th gear 65mph going to 70) also i just started the car and the multiplier moved to .89 from .76 (Both logs show 1 ) I'm at 4500 ft its dry and about 15°F outside and 91 Oct. Perrin filter, silicone inlet.....removed the expansion things off the intake.
GR86 MT premium
| OpenFlash Tablet | Rombinhood@OpenFlash | Software Tuning | 1838 | 07-29-2023 07:35 PM |
| Openflash Tablet v1.31 beta maps (including Stage 2!) now available for download | Shiv@Openflash | Software Tuning | 354 | 02-08-2015 06:23 PM |
| Is Openflash tablet detectable? | Boofneenee | Software Tuning | 25 | 05-02-2014 11:03 PM |
| ***VISHNU OpenFlash Tablet IN STOCK*** | Garrett@Openflash | Engine, Exhaust, Bolt-Ons | 15 | 12-17-2013 02:30 PM |
| WTB Openflash Tablet | Vlady | Want-To-Buy Requests | 0 | 10-25-2013 01:10 AM |
