#71 | |
i'm sorry, what?
Drives: Canada
not true.. the recently released whiteline correction kit composed of a ball-joint and tie-rod end is pretty neat as is the standard correction that can be done by the combination of camber plates at the top and bolts at the up-right elongated control arms for the front aren't out of this world either... on my old 2001RS I installed control arms (front and rear) from an 04 STi, they pushed the wheels out, giving me a lot of negative camber, I then adjusted at the up-right by dialing in what would otherwise have been positive camber... and balanced it out track was increased, strut to control arm angle was decreased, camber was around -2? all for 150 bucks. I've always wondered whether any of the suspension components from STis could be transferred.....
#72 |
Drives: Subaru BRZ Sport Tech Satin White
I meant the stock suspension.
The aftermarket stuff you refer to won't change roll characteristics because they don't change the roll axes. Roll rates may change but the weight transfer will ultimately be the same. |
#73 |
Drives: '13 BRZ Ltd
Here's a variety of bumpstops - with dynos included.
http://store.resuspension.com/home.php?cat=328 One thing I'm wondering is if they have more internal damping than something like a spring. |
#74 | |
Drives: FR-S Whiteout
Intent > Content
cowardice is the mother of cruelty. |
#75 | |
Drives: EVO
Knew there was lots out there, just hadn't been able to find a decent source. |
#76 |
I would love to throw a set of these on my stock struts with lowering springs:
http://store.resuspension.com/produc...cat=328&page=1 ![]() about 2" tall (shorter than stock) Gives you .9" of 'smoosh' before it starts ramping up the rate past 100 lb/in, then a gradual ramp up the next .3" of 'smoosh' to 300 lb/in. Too bad the hole diameter looks to be smaller than 1". possibly too small... should have measured the size of the bumpstops when I had them out.
Intent > Content
#77 |
Drives: EVO
That's not lbs/in. Thats total load. 1036lbs @ ~1.38" of travel with more then half of that load being developed in 0.050" of travel.
I'd look for something that builds force faster and more linear. Kind of cool what you can do with their system though of stacking multiple ones together.
#78 | |
1. I'm assuming the ability for the driver (myself) to sense increase in rates soon after engaging the bumpstop. before the first half inch of compression. Then, you have the next half inch of compression where it gradually increases, letting the suspension ride on the next half inch under heavy cornering loads. The more gradual increase in force will give the driver more control than if it suddenly increases. 2. The lower initial rates will allow the damper and springs to do more of the work the first inch of compression. I'm counting on the dampers and springs to do a better job on road surface irregularities than a rubber foam tube can. This is all hypothetical... I think I found the next modification I'm doing to my suspension.
Intent > Content
#79 | |
Drives: 2013 FR-S Argento
Standard Suspension Bump Travel
Sent from my iPad using Tapatalk - now Free |
#80 | |
#81 |
Drives: 2014 Subaru BRZ Limited 6MT SSM
Bump from the dead...
Is there any advantage to trimming the rear bump stop, say, half an inch? On stock suspension. |
#82 | |
Or you can email this guy and see what he thinks. http://www.fatcatmotorsports.com/FCM_bump_stops.htm
Intent > Content
#83 | |
Drives: 2013 Subaru BRZ
#84 | |
| question about front travel on coilovers | uncivilised | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 6 | 08-26-2013 05:33 PM |
| FS: Standard Suspension R7TA coilovers with extra springs | theGonz | Brakes, Suspension, Chassis | 7 | 07-18-2013 10:39 AM |
| STD Standard Suspension R3 Coilovers knocking | FutureFT86 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 2 | 05-07-2013 01:49 PM |
