Old 12-03-2013, 10:45 AM   #57
Mikem53
Drives: FR-S 6MT
We sell our lowering springs with a very mild drop (less than an inch) and we include replacement bumpstops front and rear. We wouldn't do it any other way.
Yes to get a lot of travel you need coilovers.
- Andy
Does your lowering springs cause any issues with the half shaft CV angles to where they are compromised in durability?
Also when you go with coilovers, does this situation with the half shaft angles get worse? Or is there a way to correct or adjust the angles so that isn't an issue... Spindles?, etc.. Newbie question on this.. Thanx..
Mikem53 is offline   Reply With Quote
Old 12-03-2013, 11:28 AM   #58
ZDan
ZDan's Avatar
Drives: '23 BRZ
May seem nit-picky, but...
Originally Posted by 7thgear View Post
- A spring has a rate, this rate determines the speed at which weight transfer occurs, the stiffer the spring, the faster the weight transfer.
This is a better description of damping. Springs (and also sways in cornering) determine how much total roll or pitch you'll get under fully developed cornering or braking, dampers play a bigger role in how fast you'll get there.
- Many things can act as a spring… or an energy absorbing device, if you will
Springs *store* energy and give it back with very little lost or absorbed. Dampers *absorb* kinetic energy, turning it into heat.
Old 12-03-2013, 11:32 AM   #59
bfrank1972
Drives: 2013 FR-S Argento
Just to continue the pursuit of knowledge, found this series of suspension articles pretty interesting:
http://www.initialdave.com/cars/tech.htm
Touches on the mini suspension (incidentally says it's non-hydrolastic), as well as hydrolastic, hydragas, etc. Neat stuff, makes me think why more manufacturers don't use rubber springs vs metal coil springs?
Old 12-03-2013, 11:42 AM   #60
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
well, we can nitpick further and say that roll is a function of geometry..
we could theoretically build a car that does not roll, or rolls with the turn and the springs wouldn't have a thing to do with it.
Old 12-03-2013, 12:54 PM   #61
No issues with CV angles. Our springs are one of the more mild drops out there.
Coilovers generally go much lower but I wouldn't expect problems unless you really slam the car.
- andy
Old 12-04-2013, 12:37 AM   #62
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
Originally Posted by DarkSunrise View Post
Interesting. Will you be switching to coilovers?
Yes, I plan on upgrading the dampers to adjustable coilovers. These springs and cut bumpstops were to tide me over until then.
Never thought of having the suspension 'ride' on bumpstops during compression to effect handling characteristics. Always thought of them as a safety. Something for the shock to bounce off of to prevent damage to the assembly.
Intent > Content
Old 12-04-2013, 08:03 AM   #63
DarkSunrise
DarkSunrise's Avatar
Yeah I think that's the traditional thinking, but more and more, I'm reading about cars that integrate the bumpstops into the suspension design.
If/when you upgrade to coilovers, post up your impressions
2022 BRZ Build
2013 FR-S Build
Old 12-04-2013, 10:56 AM   #64
ZDan
ZDan's Avatar
Drives: '23 BRZ
Yes, roll center height does play a role, and most cars will have some anti-roll geometry (roll center above ground). Designing a production car for zero roll or "anti-roll" (leaning into corners) would be an extraordinarily bad idea, suspension would basically lock up in cornering. Throwing away mechanical grip = bad idea unless you're trading it for even more aero grip (high downforce race cars).
Any case, my point remains valid: Dampers determine roll and pitch rates much more than spring rates do, while spring rates (along with geometry of course) determine how much total roll you get. So yer welcome for that
Old 12-04-2013, 10:57 AM   #65
Suberman
Drives: Subaru BRZ Sport Tech Satin White
Roll transfers "weight" (momentum forces actually) by the reaction of the springs on the suspension geometry. Reverse roll or zero roll suspension can and has been designed. It fails to work because of sensory limits in the driver. The car would be quicker with reverse roll but undrivable except by a non human computer. Mind you both McLaren and Mercedes Benz are working on computer controlled zero roll or at least minimal roll suspensions but they are not geometry based. They rely on gas and oil springing systems controlled by computers. Williams F1 did the same in the early 90's. That way the geometry still signals to the driver so he can actually avoid cornering so fast the car leaves the road abruptly.
Since suspension geometry on your BRZ is fixed for practical purposes the reduction in roll is effected by increasing total spring rate: tires, bushings, roll bar rates, spring rates, bump stop rates and position and any gas springing effect in the shock absorbers.
Suberman is offline   Reply With Quote
Old 12-04-2013, 10:59 AM   #66
ZDan
ZDan's Avatar
Drives: '23 BRZ
Not all adjustable coilover dampers are going to be an upgrade over stock dampers. Choose wisely!
Old 12-04-2013, 12:36 PM   #67
solidONE
solidONE's Avatar
Will do!
Intent > Content
Old 12-04-2013, 06:11 PM   #68
mike156
Drives: EVO
A decent way to approach bumpstop selection might be an energy balance. Load up a stock strut/spring/bumpstop and chart out force vs displacement. Integrate for total energy storage.
Design your replacement system to accommodate the same total energy by balancing shock gas pressure, spring rate, and bumpstop design to give the force vs. displacement curve you desire.
Although, this doesn't account for the dynamic forces associated with the damper. After all, the damper is the major source for force reaction to bumps so the energy balance method above would allow accommodate a steady state energy balance.
mike156 is offline   Reply With Quote
Old 12-05-2013, 12:04 AM   #69
solidONE
solidONE's Avatar
You are saying this as if there are actual different choices to "select" from. Aside from the higher end dampers, I don't these there is much on the market to "select" from. Even then I dont think there is much of a selection to choose from. Most cases we are stuck with the factory bumpstops or modifying them (cutting factory bumpstops or torching them ).
Intent > Content
Old 12-05-2013, 01:22 AM   #70
Turdinator
Señor Member
Turdinator's Avatar
http://www.koniracing.com/bumpstops.cfm
1974 TA22 Celica
2013 86 GT
question about front travel on coilovers uncivilised Suspension | Chassis | Brakes -- Sponsored by 949 Racing 6 08-26-2013 05:33 PM
FS: Standard Suspension R7TA coilovers with extra springs theGonz Brakes, Suspension, Chassis 7 07-18-2013 10:39 AM
STD Standard Suspension R3 Coilovers knocking FutureFT86 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 2 05-07-2013 01:49 PM
