Rubber smell sometimes on cold start
Anyone else notice a strong rubber smell when starting the car in the morning in cold weather? It happens as soon as I start the car and before I even begin to move. After a minute or 2 of driving, it goes away completely.
Any ideas? I should note that the only mods I have are an Invidia fp, Invidia N1 catback, an AEM intake and a stage 2 FA20Club tune. |
#2 | |
However, I always have an idea (most of which don't work); you might check the serpentine belt tension when it's cold .... before you crank er up. Maybe the tensioner pulley sticks a bit when it's cold .... ![]() humfrz |
| The Following User Says Thank You to humfrz For This Useful Post: | jonbonazza (12-01-2013) |
#3 |
Well, honestly, it wasn't like that from the factory and it didnt start happening until I installed my exhaust and tune (did at about the same time, so not sure exactly when it happened). I can't imagine either of those having anything to do with this, though so I am at a loss.
#4 |
Drives: Whiteout FR-S
I have the same smell! Only when air is on. Not so much rubber as plastic? Mix of the two? I can't figure it out. Had my exhaust on for a couple months now and been fine in other cold-weather. Just today.
#5 |
Hmm... I never really paid attention to if the air was on when it happened...
Sent from my Nexus 4 using Tapatalk |
#6 |
Called a Toyota tech. Said it might be transmission fluid leaking on the exhaust
#7 |
Well, mine definitely doesnt smell like tranny fluid and there are no drips, so that's not the case for me.
#8 |
Drives: Fast
Some new exhaust will smell for awhile until they are broken in. They are covered in a light oil to revent corrosion.
Also, look for plastic on they system, you may have run over a plastic bag and it's melting. |
#9 | |
Drives: 2013 Subaru BRZ
I would lean more towards the tensioner/belt theory. Is there any belt squeal, even just a brief chirp, when the car is started? |
#10 |
Its def not the exhaust oils. I had that for a while, but its gone now. There is 0 squeak or squeel on startup
| Cold start question | retrosmiths | Scion FR-S / Toyota 86 GT86 General Forum | 106 | 11-15-2016 03:14 PM |
| backfire at cold start | FreaQshoQ | Scion FR-S / Toyota 86 GT86 General Forum | 15 | 10-16-2013 07:21 AM |
| White Smoke cold start up in Cold Weather (turbo cars) | whitefrs | Forced Induction | 17 | 09-25-2013 06:05 PM |
| Burnt Rubber smell | Fizzle | Issues | Warranty | Recalls / TSB | 22 | 01-06-2013 10:10 PM |
| Anyone else smell rubber? | pinoyplaya | BRZ First-Gen (2012+) — General Topics | 15 | 09-24-2012 04:40 AM |
