Old 12-03-2013, 12:44 PM   #71
Anthonytpt
Anthonytpt's Avatar
Drives: '13 Argento 6MT FR-S
Yessums, my 17x8s appear "flat," but I love them. When I saw @CSG Mike's 17x9s, they appeared to have more curvature. The 17x8s in the photo linked by @df.dima are mine.
Anthonytpt is offline   Reply With Quote
The Following User Says Thank You to Anthonytpt For This Useful Post:
CSG Mike (12-03-2013)
Old 12-03-2013, 01:01 PM   #72
df.dima
Drives: FR-S and Mazda 3 Sky
Originally Posted by OICU812 View Post
Ya that kinda answered.."nothing"?
I am sorry I did not satisfy your with my answer, sir.
I was hoping the pictures are self explanatory, because 8" and 9" are sitting side by side and at a good angle.
Would you like a CAD drawing of the side profiles so you can compare the concavehz?
I have gone over a dozen of pics of 8 sv 9 and in my research, that picture was most helpful to realize see the diff.
df.dima is offline   Reply With Quote
Old 12-03-2013, 01:05 PM   #73
CSG Mike
CSG Mike's Avatar
I could probably arrange to shoot the 17x8 and 17x9 side by side, courtesy of @Anthonytpt
OICU812 (12-03-2013), suaveflooder (02-23-2014)
Old 12-03-2013, 01:05 PM   #74
OICU812
Just a dude
OICU812's Avatar
Drives: Scion FR-S 2013
The more important part is if folks are using spacers when lowered some...??
Trying to Invision this 17x8(42) in regards to how flush or rather sunk in it'd be when lowered an inch and brought in with at least say -1 camber.
Anyhow ya pics are hard to tell as far as concave goes but thx to all who have explained the difference in that regards. Sounds that really not much diff for concave.
Old 12-03-2013, 01:21 PM   #75
df.dima
Based on my non-scientific measurement with 3/4 piece of wood put to the stock wheel, with 1" low and 1.25 camberz, x8 will sit close to flush up front, but tiny bit inward. The back would be more inward, so for flush - spacer. For small amount of camber, x8 should be fine, but it won't be hella cool yo. x9 with this little camber will look a bit silly poking imo. You probably need closer to 1.6-2 degrees to make it look good up front. The back should be fine.
I am holding out until next year to decide, but I've been between 8 vs 9 in my mind dozens of time. If I go 9, got to add more camber up front. At the same time I don't feel like I really need 245 sized tires...
Moar evidence:
http://www.ft86club.com/forums/showthread.php?p=677299
http://i23.photobucket.com/albums/b3...560849F7CF.jpg
Right now i am running mild camber being -2 front -1.5 rear
So it looks like -2 is pretty much what it has to be.
The Following User Says Thank You to df.dima For This Useful Post:
Old 12-03-2013, 01:44 PM   #76
OrbitalEllipses
Drives: Attitude
I'm lowered 20mm and have around -1 to -1.5 degree of camber in the front. It doesn't poke, it's pretty flush to the top of the fender less a few mm.
Here's a picture I have of the fronts, at stock height without camber correction. Add -1 camber and they'll poke more at the bottom and tuck more in the top. I run these without spacers at -1 camber up front and lowered 20mm without ANY problems.
Old 12-03-2013, 02:01 PM   #77
OICU812
Just a dude
OICU812's Avatar
Interesting honestly figured a spacer would be needed in rear at least. Thx!
Old 12-03-2013, 02:50 PM   #78
Anthonytpt
Anthonytpt's Avatar
If the masses want it, I certainly wouldn't mind.
Old 12-03-2013, 02:55 PM   #79
OrbitalEllipses
Drives: Attitude
Plenty of inboard and outboard clearance at 8"+42.
Old 12-03-2013, 05:21 PM   #80
OICU812
Just a dude
OICU812's Avatar
Your backs are not too sucked in there? Fronts look about perfect indeed!
Old 12-03-2013, 05:29 PM   #81
Anthonytpt
Anthonytpt's Avatar
I think this is subjective and a matter of personal preference.
Old 12-03-2013, 05:33 PM   #82
OICU812
Just a dude
OICU812's Avatar
Totally realize that, just trying to understand how much its tucked in rear without spacers here is all. WANT to purchase a light track/spare set this winter and trying to nail down firm options. I hadn't considered the 8" weds till seen this thread actually.
Old 12-03-2013, 05:42 PM   #83
OrbitalEllipses
Drives: Attitude
They're tucked a bit.
Old 12-03-2013, 05:43 PM   #84
OICU812
Just a dude
OICU812's Avatar
Thx Orbital!
Wheel Directory: SSR Competition 17x8.0 +38 Enigmus Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 25 08-07-2015 06:38 PM
WEDSSPORT TC105N - 17x8.0 +42 / 17x9.0 +35mm 5x100 ~ 15 Lbs Per Wheel RavSpec Wheels and Tires 72 12-04-2012 03:58 PM
Wheel Directory: Advan RG II 17x8.0 +45 DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 10-11-2012 07:28 PM
17x8 +35, will it rub? switchlanez Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 8 07-31-2012 03:26 AM
Pre Order TC105N vividracing Wheels and Tires 27 07-30-2012 03:28 AM
