Old 12-01-2013, 09:36 PM   #169
Ryan86
Road Warrior
Ryan86's Avatar
Drives: Toyota 86 Satin Pearl White
Originally Posted by Lawnik View Post
@Ryan86 Great numbers and congrats on beating the vortech.
Just curious, are you running any cooling mods? Oil cooler or upgraded rad
No additionall cooling, we tested in temps of 35 deg Celsius and my oil temp max was 126 and coolant 104 deg C.
even doing 0 - 100 off line pulls in 40 deg C, the car just kept pulling hard, I was extremely impressed and temps both on oil and coolant remained under the max figures above.
My clutch was taking strain, so that may be something to keep an eye on.
Ryan86 is offline   Reply With Quote
The Following User Says Thank You to Ryan86 For This Useful Post:
Lawnik (12-01-2013)
Old 12-01-2013, 09:39 PM   #170
Ryan86
Road Warrior
Ryan86's Avatar
Originally Posted by Kodename47 View Post
Have your IAT compensation tables been adjusted correctly? I wouldn't advise disconnecting the IAT sensor. Where is yours, MAF or MAP? TBH the MAF sensor temperature won't be accurate for the air temperature entering the engine anyway.
Yes Bill sent a new file after I removed the IAT.
There was 2 wires loose so I had too remove the harness. I would like to see a test done before and after install, to see exactly what this sensor does.
Old 12-01-2013, 11:01 PM   #171
Ryan86
Road Warrior
Ryan86's Avatar
@xxscaxx I will get you a pic.
The screw is near the bottom of the manifold where the lamina fits into.
Old 12-02-2013, 03:53 AM   #172
Kodename47
Kodename47's Avatar
Drives: UK GT86
The IATs on the stock car pretty much monitor the air temp going into the cylinders and there is a table that retards the timing at set temperature ranges.
Here's what I found in the stock OFT maps:
I've no idea what the top right table is though.
Obviously the temperatures post charger will be much higher due to the compression so you would need to rescale these tables to take this into account if your IAT sensor is in the MAP sensor. If you're using the MAF sensor, the temperatures you are seeing are no relation to air temps in the cylinder anyway so the timing will be manually configured.
.: Stealth 86 :.
Kodename 47 DJ:
Old 12-02-2013, 07:34 AM   #173
Ryan86
Road Warrior
Ryan86's Avatar
the screw on the manifold under the grey pipe is where i connected to get boost.
Old 12-02-2013, 05:01 PM   #174
xjohnx
Grip>Slip
xjohnx's Avatar
what size threads are they? what fitting did you use?
Old 12-02-2013, 07:04 PM   #175
Ryan86
Road Warrior
Ryan86's Avatar
This is what I got from Sprintex
For a boost reading, there is a 5mm plug in the back of the plenum on the right hand side, that can be removed and replaced by a standard pneumatic ‘push’ fitting (Legris, SMC or similar) for 4mm Teflon hose.
We did not have 5mm so the technician bored out and fitted a 8mm.
Old 12-02-2013, 08:42 PM   #176
xjohnx
Grip>Slip
xjohnx's Avatar
Interesing. Don't think i've ever used a fitting like that before. guess i'll have to do some research.
Old 12-03-2013, 12:56 AM   #177
Ryan86
Road Warrior
Ryan86's Avatar
Really was not difficult took 10 mins.
Here are pics with gauge fitted.
Old 12-03-2013, 07:33 AM   #178
xjohnx
Grip>Slip
xjohnx's Avatar
Hopefully somebody will chime in with a link to the part and tubing needed.
I ordered some metal hose fittings to replace the plastic ones like you (or someone else) posted since mine seem to be a little loose. Is it possible to replace those while the manifold is on the car? or should i wait until i'm doing my IC install?
Old 12-03-2013, 07:52 AM   #179
Ryan86
Road Warrior
Ryan86's Avatar
You can turn the pipe while the back is on. either remove the back or wait till you install charger.
I'll see is I can get you a pic of the bolt.
Old 12-03-2013, 08:46 AM   #180
Ryan86
Road Warrior
Ryan86's Avatar
This is very simular to what I used. we only have 8mm, hence we drilled the hole bigger and tappered the screw in.
http://www.legris.com/Legris_ecom/Re...deLangue=en_GB
Old 12-03-2013, 03:44 PM   #181
xjohnx
Grip>Slip
xjohnx's Avatar
Awesome, thanks.
Old 12-03-2013, 07:41 PM   #182
sw20kosh
Drives: 2013 Black FR-S
Uh is that anything like a NPT?
Also, how did you guys seal those intercooler nipples that were leaking? DId you use any glue or anything? Bill @DeliciousTuning is saying that I should check the rubber O-ring seals and glue them in.
Innovate Motorsports Twin Screw Supercharger System, NOW SHIPPING! Innovate Motorsports Forced Induction 577 10-15-2014 12:49 AM
Innovate Motorsports BRZ/FR-S/GT86 Supercharger System Available from Moto-East! Xero-Limit Forced Induction 12 03-10-2014 08:56 PM
Innovate Motorsports FR-S/BRZ traction control state modifier module... mines13 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 20 09-13-2013 01:06 PM
Innovate Motorsports Twin Screw Supercharger Kit for FR-S/BRZ Innovate Motorsports Forced Induction 1987 03-13-2013 09:14 PM
FS: Innovate Motorsports OT-2 pixel67 Engine, Exhaust, Bolt-Ons 0 01-05-2013 10:13 AM
