Old 12-01-2013, 08:50 PM   #15
Suberman
Drives: Subaru BRZ Sport Tech Satin White
Does the FI system return excess fuel to the tank?
If so then heating of the fuel may be the problem.
Suberman is offline   Reply With Quote
Old 12-02-2013, 06:16 AM   #16
ntron1
Sarcastic Bastard
Drives: '13 DGM BRZ, '13 Mini, 1999 Blazer
I never (well almost never) fill up until the light has come on. Always (well almost always) run to 400 miles before fuelling. I am well aware of the theories about junk in the bottom of the tank but am not concerned in the least.
ntron1 is offline   Reply With Quote
Old 12-02-2013, 06:33 AM   #17
slicktop
Drives: 2013 Raven FRS 2JZ-GTE/V160 swapped
I've always been told to worry about contaminates if the fuel is too low.
My personal opinion is if you're pinching pennies trying to save a few lbs for performance.... Upgrade. Don't risk starving/contaminating your engine for 20lbs~ of fuel weight savings.
-slicktop
2013 Scion FRS
2JZ-GTE/V160 Swap Build Thread
slicktop is offline   Reply With Quote
Old 12-02-2013, 12:27 PM   #18
BRZfan
BRZfan's Avatar
Drives: 2013BRZ Premium St Silver Metallic
1..Try running your fuel tank to almost empty or whenever you normally refuel.
2... Put about 100 additional pounds of dead weight in the rear (13 gallons X about 8 lbs/gallon).
3.. See if it feels the same as if you had filled up the tank.
Originally Posted by TIsbell34 View Post
I don't know if it's a performance loss or anything but I've noticed the car definitely feels better after filling it up if the tank was previously on E
BRZfan is offline   Reply With Quote
Old 12-02-2013, 12:32 PM   #19
SeanBlader
Drives: Suburu BRZ Limited, black
That's why we have fuel filters. I've run out my '85 MR2 several times, and given the age of the tank, and that it's probably on it's first or maybe second fuel filter, I can promise you that any in tank contaminants are not going to make it to the injectors. I just pour in a gallon and drive off. In a brand new car, and with today's fuel refinement processes, you shouldn't worry about particulates, and if you're going to worry about anything it's getting stuck blocking traffic.
SeanBlader is offline   Reply With Quote
Old 12-03-2013, 12:54 PM   #20
bdbx18
Drives: Present MDX, Civic Hybrid, BRZ
It's psychological. I recently (accidentally) ran my BRZ on gas fumes and I was praying for it not to stall or suck up particles before I can get to a station. So naturally, I gently drove it like it had no brakes, very gingerly and going to neutral every sec I could. Performance wasn't on my mind then.
Current: 07 MDX, 06 Civic Hybrid, 13 BRZL
Past: 03 M3 SMG, 99 540i, 01 X5 4.4, 01 X5 3.0, 03 MDX, 92 NSX, 89 Maxima, 86 Integra, 88 Odyssey, 88 Legend, Supra, MR2T, Pathfinder, MirageT, Accord
bdbx18 is offline   Reply With Quote
Old 12-03-2013, 12:55 PM   #21
TIsbell34
I believe that's the case
TIsbell34 is offline   Reply With Quote
Accelerated Performance's Fuel System Fix for the BRZ/FRS/GT86 Visconti Forced Induction 103 12-01-2013 11:50 AM
Fuel level GeeTee86 Issues | Warranty | Recalls / TSB 6 05-21-2013 05:57 AM
High performance and race engine oil tests Kamran Tracking / Autocross / HPDE / Drifting 16 02-10-2013 12:06 PM
Check Engine light after: Major service (Fuel pump, ECM, and 7500 miles oil change) R2RO Issues | Warranty | Recalls / TSB 3 02-04-2013 10:06 PM
High compression engine fuel requirements Ben_G Engine, Exhaust, Transmission 3 01-16-2013 11:44 AM
