Old 12-01-2013, 01:21 PM   #15
86_Otaku
86_Otaku's Avatar
Drives: 2013 BRZ Limited-SWP
J2 engineering exhaust
Warning! I have the dual version of this exhaust setup and I have to tell you, it's no walk in the park for sure.
This is exhaust is turning out to be such a problem.
1. No instructions - I know it's self explanitory but still...
2. The tips were bent.
3. I wanted to attach mine to the factory cat (mid pipe) and the connections with the donut gasket is loose.
The extra .25in lip from the factory front pipe doesn't slip into the J2 pipe. So now I now have a leak .
4. Y section pipe hits car frame.
I like the look and sound but it's going to cost me an extra $$$ and my time to fix it correctly!
I wouldn't be oppose to getting their catless mid pipe and see if that helps with the fitment.
I contacted DNA Motorsport (Vendor of J2 exhaust) and see what they can do.
Off to the muffler shop I go!
86_Otaku is offline   Reply With Quote
Old 12-01-2013, 07:41 PM   #16
boredom.is.me
Custom User Title
boredom.is.me's Avatar
Drives: Asphalt FR-S MT
3. I wanted to attach mine to the factory cat (mid pipe) and the connection to the factory
will not work. The extra .25in lip from the factor mid pipe doesn't slip into the J2 pipe. So now I now have a leak
I wouldn't be oppose to getting there carless mid pipe and see if that helps with the fitment.
I contacted DNA Motorsport (Ventor of J2 exhaust) and see what they can do.
I don't have this exhaust. I also think you have your components labeled wrong.
The front pipe does have an extension. That extension is for a doughnut gasket. From the sound/look of it, you didn't install the d-gasket. If this is the case, next time take the time to learn something before bashing it. No comment on the tips.
Old 12-01-2013, 08:33 PM   #17
jamesm
the j2 front pipe doesn't have the extension. it's actually 2.75" through. you just use a normal gasket instead of the donut.
Old 12-02-2013, 12:10 AM   #18
86_Otaku
86_Otaku's Avatar
I ended up reversing the install and not using any factory exhaust hangers.
I attached the exhaust starting from the mid pipe first. Then I used zip ties to hang the exhaust in place until i can get new hangers.
The mistake i made was watching the install video on youtube. Maybe the video is correct for non catted front pipe install, but for me
Installing in the reverse directions gave me the best fitment.
J2 engineering exhaust review Roberto12 Engine, Exhaust, Transmission 50 11-17-2015 03:01 PM
J2 Engineering Exhaust Systems for BRZ/FRS at Redline360 Redline360 Engine, Exhaust, Bolt-Ons 129 01-13-2015 12:03 AM
Sold J2 Engineering Dual Exhaust pixel67 Engine, Exhaust, Bolt-Ons 4 03-10-2013 09:44 PM
J2 Engineering Exhaust Systems for BRZ/FRS at Redline360 Redline360 Engine, Exhaust, Bolt-Ons 13 01-18-2013 05:51 PM
PPE Engineering plans to develop intake and exhaust Evil86 Engine, Exhaust, Transmission 1 08-10-2012 11:28 AM
