#169 |
Drives: vrooom...
Amazon carries [ame="http://www.amazon.com/Techflex-PTN0-50BK25-General-Purpose-Braided/dp/B004UHQNUU/ref=sr_1_6?s=electronics&ie=UTF8&qid=1385495013&sr =1-6"]Techflex[/ame]
| The Following User Says Thank You to M1K3 For This Useful Post: | autobrz (11-27-2013) |
#170 |
Professional Smartass
Drives: White Out FRS
Well the Oil Cooler Connector is back ordered to eternity.
I just talked to Shawn over at Subarupartswarehouse.com and ordered the STI bolt from a 2008 model. He said if it doesn't work I can send it back for a full refund which is badass. I'll update if it does in fact work, there were more in stock too. Last edited by post_break; 11-27-2013 at 11:02 AM. |
#171 |
Drives: Mazda 3
Has anyone logged oil temps on the track with this oil cooler?
^^ my dealer is also still waiting on the oil cooler and connector. Last edited by autobrz; 11-27-2013 at 11:14 AM. |
| The Following User Says Thank You to autobrz For This Useful Post: | CxG (04-25-2016) |
#172 |
Track Junkie
Drives: Argento Scion FR-S
I'm going to record my track logs this weekend
Sent from my SGH-T889 using Tapatalk |
#173 |
CHECK ENGINE
Drives: 2004 STi
If the 08 STi oil cooler connector works let me know and I will add it to the list on the first page as an alternate piece.
i don't cry about crickets
| The Following User Says Thank You to CARNZ For This Useful Post: | CxG (04-25-2016) |
#174 |
#175 |
CHECK ENGINE
Drives: 2004 STi
Once a 2015 wrx makes it to our dealer, I am going to look it over and see if their water pipe will be a better fit than the FXT one.
#176 |
#177 |
CHECK ENGINE
Drives: 2004 STi
the cooler is probably the same part number as the FXT since its basically the same engine. I just wanna see that water line since some people have expressed concerns about the current FXT solution
#178 |
Track Junkie
#179 |
Drives: vrooom...
#180 |
Track Junkie
#181 |
Drives: 2022 Subaru BRZ
The OEM oil cooler looks great for track use. A manual by-pass valve for closing off the oil cooler when driving on the street might be beneficial to prevent oil temperatures from being too cold.
#182 |
Track Junkie
no need for it, the cooler cooler acts as a oil warmer for faster warm ups, while cruising to the track, my oil temps tend to be 6-8 degrees above my water temp.
just to add as well, it was 40 degrees outside when i went to the track that morning. |
| Tags |
| brz, fxt, oil, oil cooler |
| OEM Oil cooler from the 2.0 DIT Forester | Kostamojen | Engine, Exhaust, Transmission | 119 | 09-10-2019 05:28 AM |
| Bought a 2014 Subaru Forester | EAGLE5 | Other Vehicles & General Automotive Discussions | 10 | 10-02-2013 12:54 PM |
| 2014 Forester key fob - nicer than BRZ | Turbowned | Cosmetic Modification (Interior/Exterior/Lighting) | 3 | 04-17-2013 03:35 PM |
| BRZ 2.0L Turbo in 2014 Forester | Sleeperz | BRZ First-Gen (2012+) — General Topics | 37 | 03-21-2013 06:42 PM |
| Review after test driving a 2013 WRB BRZ and 2014 Forester in Okinawa, Japan… | 2013GTRNate | BRZ First-Gen (2012+) — General Topics | 12 | 02-01-2013 12:29 PM |
