Old 11-27-2013, 10:59 PM   #1
GarageBRZTuning
GarageBRZTuning's Avatar
Drives: 2013 Subaru BRZ Limited Silver MT
NEED HELP!! Reverse Lights Are Not Working!
I recently installed new LED light bulbs for the reverse lights on my 2013 BRZ. At first when the lights weren't working I just flipped them to see if that worked and it didn't... I then checked the reverse light fuze and that seems to be working properly. I checked the connectors to the reverse lights in the trunk and nothing seemed to be broken or cut. I put the old bulbs in and those stopped working also! I don't know what happened.. PLEASE HELP!!
GarageBRZTuning is offline   Reply With Quote
Old 11-27-2013, 11:35 PM   #2
kALMIGHTY
Drives: TRD Ultramarine '13
How do you know if the reverse light fuze is working properly? Maybe try replacing it anyway just to see if it's blown?
Old 11-28-2013, 12:13 AM   #3
Yep, I would suspect the fuse. It just might be "defective".
Next, I'd use a tester to see if you have power at the socket. IF not, just work your way back.
I hope you get er fixed so you don't back over any turkeys, trying to escape ....
**PHASTEK** HID Headlights, Reverse Lights, Fog Lights (FR-S / BRZ) PhastekSport Exterior Parts - Lighting 18 07-09-2014 08:42 PM
TGS| BC Tail Lights | LED's for Fog's, Reverse, Front LED Switchbacks & Interior TopGearSolutions Exterior Parts - Lighting 116 06-18-2014 12:56 PM
help! reverse light not working nab335 Cosmetic Modification (Interior/Exterior/Lighting) 4 10-14-2013 06:59 PM
Parking/fog lights not working THEWAKLER Cosmetic Modification (Interior/Exterior/Lighting) 2 10-09-2013 09:26 PM
FR-S smoked tail lights and reverse lights jjdrivesajazz Cosmetic Modification (Interior/Exterior/Lighting) 43 02-21-2013 09:38 PM
