Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > Marketplace > Commercial Classifieds > Exterior Parts - Lighting
Old 09-26-2013, 05:00 PM   #1
TopGearSolutions
TopGearSolutions's Avatar
Drives: C6 Corvette Z06
TGS| BC Tail Lights | LED's for Fog's, Reverse, Front LED Switchbacks & Interior
Buddy Club LED Tail Lights BC08-TLZN6-01, 2013 Subaru BRZ / Scion FR-S
$495
Also known as the Buddy Club Arrow LED Tail Lamps these tail lights are sure to set your Subaru BRZ or Scion FR-S apart from the rest.
These full LED tail lights bundle the latest style and technology all in one affordable and attractive package. U.S. DOT compliant, the Buddy Club LED Tail Lights feature a sequential blinker pattern that cascades from inside to out when using your turn indicator or hazard signals. With an effortless flick of a switch located on the backside of the tail light, the sequential feature can be turned off for a solid illuminated indicator. The U.S. version will feature a clear lens with all red LED design where as Asian and European markets will feature a clear lens with red running lights and amber blinkers.
Key features of the Buddy Club Tail Lamps: Buddy Club enlisted the help of a top lighting manufacturer to develop these unique full replacement tail lamps Buddy Club tail lamps are built to the strictest requirements ensuring a high quality lamp that meets OE standards. Buddy Club wanted to improve the appearance as well as the lighting output when designing these lamps. These are very bright and highly visible. Buddy Club tail lamps are SAE & DOT approved.
*Due to popularity of this item please inquire within for availability*
BRZ / FR-S 32 LED Fog Light Kit
$59.99
Upgrade your Subaru BRZs dull and dim looking fog lights with these Ultra High Output PSX24W LED bulbs!
With 32 super bright white high power LEDs these Subaru BRZ PSX24W LED bulbs are brighter then anything else on the market today. The extremely efficient and super bright LEDs used in these bulbs are the result of new LED technology developed in 2013 making them brighter then typical LEDs. The new technology reduces power consumption in these Subaru BRZ PSX24W LED bulbs while increasing output. The new design also includes light deflectors that help distribute the light more evenly around the reflector of the housings they are used in also increasing the efficiency and reducing the speckled look often seen when using PSX24W bulbs with multiple LEDs.
Sold as a set of 2 PSX24W LED bulbs
Bulb color: 6000K brilliant white
Application: PSX24W, 2504
These Subaru PSX24W LED bulbs do not get hot like halogen or HID bulbs so there is no risk of melting your housings
32 LEDs per bulb, with focusing lens on top of bulb to project a tighter beam from the top of the bulb
Warranty: 1 year
Great choice for matching 6000K HID headlights
Subaru PSX24W Ultra High Output White LED bulbs (2 bulbs)
*Compare to the competition in our second image*
Subaru BRZ Front LED Turn Signals, Rear LED Turn Signals w/ Flasher Module Kit
$69.99
This Subaru BRZ LED Turn Signal Kit will upgrade your front turn signals to white or amber LEDs, (your choice of color) your Rear turn signals to amber LEDs and includes a replacement LED flasher module to replace the factory thermal flasher model. The LED Flasher module will eliminate the hyper flash caused by using LEDs!
All the Subaru BRZ LEDs and the LED Flasher Module are direct replacements for the factory bulbs and Flasher module and plug directly into the factory connectors. The front and rear LED Turn signals are the same size as the factory bulbs so they will install without issue as will the LED Flasher Module, it is a direct replacement for the factory thermal flasher module.
Kit Includes the following:
2 front 7440 LED bulbs (your choice of Amber or White (6000K)
2 rear 7440 Amber LED bulbs
1 LED Flasher Module
Instructions
1 year warranty against failure
Scion FR-S LED Switchback Front Turn Signals, LED Rear Turn Signal and LED Flasher Module Kit
$69.99
This Scion FRS LED Switchback Turn Signal Kit will upgrade your front turn signals to LED Switchbacks (white parking light/amber turn signal) your Rear turn signals to amber LEDs and includes a replacement LED flasher module to replace the factory thermal flasher model. The LED Flasher module will eliminate the hyper flash caused by using LEDs!
All the Scion FR-S LEDs and the LED Flasher Module are direct replacements for the factory bulbs and Flasher module and plug directly into the factory connectors. The front LED Switchback Turn Signals may require a small amount of material to be removed from the hole the bulb inserts into. The LED Switchback are 2mm larger in diameter then the factory bulb so fitment will be tight to get the top of the LED bulb through. The rear LED Turn signals are the same size as the factory bulbs so they will install without issue as will the LED Flasher Module, it is a direct replacement for the factory thermal flasher module.
2 front 7443 LED switchback bulbs with 60 LEDs (30 LED white parking light/30 LED Amber turn signal)
Instructions
*Modification Required for Front Turn Signal Opening to Accommodate Switchbacks*
BRZ / FR-S LED Interior Kit
Starting $14.99
Brighten up your Subaru BRZ interior with our LED interior light kit. Using the brightest high quality LEDs the BRZ Interior LED Kit is easy to install and will make a huge difference in the light output.
With optional colors like Red Blue and Amber for the BRZ LED Interior Lights you can have a unique look that is sure to get you noticed! Using the same high quality and super bright LEDs the kit will not burn out, fade brightness or change color over time like many low quality LED do.
The optional BRZ License Plate LEDs will give your exterior a clean modern look, with the same license plate lights found on many new high end vehicles.
The optional BRZ LED Reverse Lights are very bright and brilliant white (6000K) and will increase the light output, improve visibility, during the day and increase nighttime visibility and give your reverse lights a clean modern look!
Kit includes the following:
Fitment: 2013 + Subaru BRZ
One 12 High Power LED Panel for front dome light (White is 240 Lumen output)
One 12 LED high power bulb for trunk (White is 240 Lumen output)
Two 5 LED high power bulbs for the door courtesy lights
(Optional select above) Two 5 LED high power brilliant white bulbs for License plate light
(Optional select above) two 5 LED High Power 7.5 Watt Brilliant White Reverse Lights
One year warranty against failure.
Subaru BRZ Interior LED Lighting Kit
*Generic Image. Please send us your images*
BRZ / FR-S 7.5Watt LED Reverse Lights
$19.99
Subaru BRZ / Scion FR-S LED Reverse Lights (7.5 Watt High Powered)
Now Available for your Subaru BRZ and Scion FR-S are the 7.5 Watt High Powered Reverse LED's.
Increase rear visibility while backing up
Improve the look of your Subaru BRZ / Scion FR-S
Uses less power then your stock factory bulbs and is up to 4x brighter!
Bright White 6000K Color
Plug and Play
Direct Fit
No Modification Required
Application: 2013-2014 Subaru BRZ and Scion FR-S
TopGearSolutions is offline   Reply With Quote
Old 09-27-2013, 06:23 PM   #2
TopGearSolutions
PM's replied!
Old 09-28-2013, 10:53 PM   #3
TopGearSolutions
Orders processed! Please send us your pictures!
Old 10-01-2013, 12:36 AM   #4
TopGearSolutions
PM's replied
Old 10-02-2013, 12:30 AM   #5
TopGearSolutions
Pm's replied!
Old 10-02-2013, 10:37 PM   #6
TopGearSolutions
Orders processed!
Old 10-03-2013, 10:37 PM   #7
TopGearSolutions
Switchbacks shipped!
Old 10-07-2013, 12:37 PM   #8
TopGearSolutions
All BRZ LED Lighting on sale!
Old 10-08-2013, 04:17 PM   #9
TopGearSolutions
LED Interior Kit Shipped with license plate LED and reverse LED.
Old 10-09-2013, 10:48 PM   #10
TopGearSolutions
BRZ LED!
Old 10-10-2013, 07:13 PM   #11
TopGearSolutions
PM's replied
Old 10-11-2013, 08:15 PM   #12
TopGearSolutions
Tracking sent
Old 10-12-2013, 11:54 PM   #13
TopGearSolutions
PM's replied
Old 10-13-2013, 11:32 PM   #14
TopGearSolutions
PM's replied
Toms tail lights with Valenti bumper reverse light? Phaedrus29 Cosmetic Modification (Interior/Exterior/Lighting) 41 02-16-2016 04:45 AM
TOM'S Racing JDM LED Tail Lights , Spyder LED Tail Lights, and JDM Side Markers!! Evasive Motorsports Exterior Parts - Lighting 94 12-18-2015 01:19 PM
**PHASTEK** HID Headlights, Reverse Lights, Fog Lights (FR-S / BRZ) PhastekSport Exterior Parts - Lighting 18 07-09-2014 07:42 PM
Interior LED + Reverse backup package? Intake Scion FR-S / Toyota 86 GT86 General Forum 1 07-12-2013 11:46 AM
FR-S smoked tail lights and reverse lights jjdrivesajazz Cosmetic Modification (Interior/Exterior/Lighting) 43 02-21-2013 08:38 PM
