Old 11-27-2013, 01:09 PM   #127
BunnyRZed
BunnyRZed's Avatar
Drives: BRZ Limited [37J]
Originally Posted by zoth View Post
200 miles so far no crickets. Crossing my fingers. Some have luck on the new pumps could it be a technicians fault? For not doing the job right.
Sent from my SM-N900T using Tapatalk
Or worse, the technician think it's the same pump that he's been replacing and still causing a problem so he don't bother to change it out.
BunnyRZed is offline   Reply With Quote
Old 11-27-2013, 01:10 PM   #128
zoth
zoth's Avatar
Drives: 2013 BRZ Premium Dark Gray Metallic
That theory is so dark, scary part is it can be true.
KraftWerks SuperCharger C30=HB-Waterless Coolant-(Mishi)Racing Thermostat & Oil Can
Tomei EL-PLM Overpipe-HKS Dual Resonated Front Pipe-Invidia N1
DR31 18x9+38 Square w/ 255/40r18 PT-722, TRD Quickshifter, ACT Streetlite Kit
Moto-East Flex-Fuel Kit (Almost running 100% E85 all the time)
DW 700 cc Injectors-Tune by (Moto-East)-KW Oil Cooler
zoth is offline   Reply With Quote
Old 11-27-2013, 06:58 PM   #129
pche
Guy on internet
Drives: Slowly
Originally Posted by brianhj View Post
50 miles lol
500 now
Doubt it, pretty straight forward job. Pays an hour to do. I could tell the physical differences by looking at both pumps. The cricket comes from within the pump assembly. The HPFP has two pieces, the base which contains the lifter, and the pump itself. The bulletin only calls for the replacement of the pump, which leaves the base and lifter untouched.
pche is offline   Reply With Quote
Old 11-27-2013, 07:22 PM   #130
zoth
zoth's Avatar
Originally Posted by pche View Post
500 now
I saw the work order from my dealer and took them 3.5 hours. Maybe thats why it's job done right, I won't miss them that's for sure.
Old 11-27-2013, 07:40 PM   #131
pche
Guy on internet
Drives: Slowly
That actually might mean that it was the very first one your dealer's service department has performed. That's why they didn't know what to pay the tech. My first one paid 2.8 hours.
Also might mean that the job was performed before the revised pump came out on 10/28/13 (give or take a day, don't feel like looking it up). The revised bulletin now had labor time posted at one whopping hour.
Old 11-27-2013, 08:25 PM   #132
355rockit
Drives: Sci FR-S, Fer F355, Toy Highlander
I am at 1,150 miles with no crickets.
355rockit is offline   Reply With Quote
Old 11-27-2013, 09:48 PM   #133
AznBRZer
Drives: 16 CBS WRX Limited
Did anyone have a problem with a persistent smell of gas after they got their pump swapped?
The dealership says there's no leak, but it shouldn't smell like there's an open bucket of gas.
AznBRZer is offline   Reply With Quote
Old 11-27-2013, 09:49 PM   #134
zoth
zoth's Avatar
Not here.
Old 11-28-2013, 03:44 AM   #135
fistpoint
Drives: Supercharged Golf Cart
I'm pretty sure at least one FR-S caught fire from a botched fuel pump replacement. I'm trying to find the thread...
it was a BRZ:
http://brzcrash.com/2013/01/brz-catc...to-the-ground/
fistpoint is offline   Reply With Quote
Old 11-28-2013, 04:21 AM   #136
Andrew025
Andrew025's Avatar
Drives: Neptune GR86
Funny there's a site dedicated to BRZ/FRS crashes/destruction.
Old 11-28-2013, 10:03 AM   #137
FRiSson
Drives: FR-S MT
I have one of the first FR-S's. I have a sound coming from the engine compartment. It sounds a bit like worn tappets on an OHV motor. It sounds like crickets, but doesn't have the high frequency chirp that youtube videos on the problem sound like. Is this a normal sound, or is it the same problem?
FRiSson is offline   Reply With Quote
Old 11-28-2013, 10:19 AM   #138
SpectreRT
SpectreRT's Avatar
Drives: Subaru BRZ
I got the new part number fuel pump. So far no crickets have returned after a few hundred miles. Extremely happy (finally).
I hope it lasts.
SpectreRT is offline   Reply With Quote
Old 11-28-2013, 12:49 PM   #139
AznBRZer
it was a BRZ:
I saw that thread when it happened. The service manager and the tech said that a little spilt fuel could stink up the car for a few days, but it should dissipate over time. They were telling me this while we were standing in front of the engine bay with the hood open and a heavy smell of gas coming coming from it, which they acknowledged. It sounds like bullshit to me because when you spill a bit of gas when you're filling the tank, it doesn't smell like that for days. Today will be a week. And all this is after the fact that they said that the smell was gone before I picked it up.
I'm guessing that most people that had their pump replaced didn't have this issue or else there'd be far more complaints about it and the only post similar to mine is about a car burning to the ground. I have a longish drive later today and I'll see how it goes. If I don't notice a difference by tomorrow morning when I run some errands, I'm taking it back to the dealer in the afternoon. I already have a case through corporate and frankly, I'm surprised as hell that they had even bothered to send me a survey after having me wait 7.5 hours at the dealership with no loaner. I'm already not a happy camper and they're going to need to make this right. I need to be compensated for the 3 hours/150 miles worth of traveling because they screwed it up at the very least.
Old 11-28-2013, 01:04 PM   #140
mid_life_crisis
Drives: FR-S 10 #103 AT
That's not crickets. This must be your first engine with direct injection. That's normal.
“Sex is like Bridge. If you don't have a good partner, you'd better have a good hand.” - Mae West
Papa said, "son there's a lot of evil temptations out there. Best to try 'em all so you know which ones to avoid."
mid_life_crisis is offline   Reply With Quote
Cricket Type Noise From Inside buddy32 Issues | Warranty | Recalls / TSB 5 03-27-2014 01:25 PM
Took my car to the dealership concerning the cricket noise. Ludacrits Issues | Warranty | Recalls / TSB 6 10-14-2013 03:18 AM
Chirping/Cricket Fix Out? deeranged Issues | Warranty | Recalls / TSB 15 10-02-2013 05:43 PM
Cricket TSB [deleted] Southern California 25 06-05-2013 06:01 PM
New trans, window, and cricket fix! foney_email Issues | Warranty | Recalls / TSB 11 03-14-2013 05:35 PM
