Old 11-27-2013, 02:39 PM   #127
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
Originally Posted by Ondreiko View Post
Hi Shiv!
I am waiting for the positive results of your investigations that could fix my cal id discrepancy (and will make all possible log scales functional)and for those which will let OFManager to read/download log files from OFT.
Please kindly advice your estimations.
Cheers!
Working on that now. Hoping to have resolution within a day or two. International ROM support is a bit tricky since I don't have access to the cars personally. So I have to take baby steps for safety's sake.
Shiv
Shiv@Openflash is offline   Reply With Quote
Old 11-27-2013, 02:43 PM   #128
Shiv@Openflash
Drives: 2013 FRS
Originally Posted by Grip Ronin View Post
Hey shiv I ran some data logging and at a few odd spots in lower rpm, varying throttle angles its picking up knock correction of 4-6. is that safe assuming the ecu is correcting it or should i pull alittle timing? . its a regular stage 2 gasoline.
Knock correction Learned Value (assuming you are logging with OFT) is actually the amount of timing being added in due to absence of knock. Which is a good thing. In the OTS maps, you will see this value go as high as 6 deg which is what you are seeing.
It's not, IMHO, a well named channel since it sounds like it would represent the amount of timing being retarded due to knock, not the other way around. But I wanted to keep the names consistent among with other tuning software (ecutek, brzedit, etc,.) Maybe I'll rename it to avoid confusion in the future. Call it Ignition Advance Correction perhaps.
Shiv
The Following User Says Thank You to Shiv@Openflash For This Useful Post:
3essess (11-27-2013)
Old 11-27-2013, 03:00 PM   #129
Ondreiko
RWD addicted
Ondreiko's Avatar
Drives: BRZ 6MT OFT OFH
Shiv
Thank you, Shiv. It is clear and i'll be waiting then.
Wish you good luck with my troubles shooting.
Please let me know when fixed if possible.
Cheers!
Ondreiko is offline   Reply With Quote
Old 11-27-2013, 03:46 PM   #130
8686
8686's Avatar
Drives: 86
I feel like my post have been ignored
VOLK LE37 17X7.5, SWIFT Springs, Bilstein B8, HKS intake duct, Cosworth Air Filter, HKS headers, PLM Over Pipe, EVS Down Pipe & Exhaust, FD 4.55, GFB pulleys, Axle-Exchange Drive Shaft, Mishimoto oil cooler, Cusco F&R strut bar, TRD door stabilizer, Innovate SC, Delicious Tuned
8686 is offline   Reply With Quote
Old 11-27-2013, 03:52 PM   #131
Shiv@Openflash
Drives: 2013 FRS
I think I have responded to your email a couple days ago. But I can't tell because I don't know your name, just your forum username.
Shiv
Old 11-27-2013, 03:54 PM   #132
8686
8686's Avatar
Drives: 86
Sorry but I didnt get your email yet
my email is mujahed@haririlife.com
The Following User Says Thank You to 8686 For This Useful Post:
ThisGuy919 (12-09-2013)
Old 11-27-2013, 06:29 PM   #133
Grip Ronin
The Mechanic
Grip Ronin's Avatar
Drives: Civic Turbo,FR-S
Shiv
yes exactly what i was thinking.i thought its pulling back because of knock. this is on oft, before the relaease i would data log on techstream lol. thanx
IG-Joey_Soul
Progress Thread Ported billet 20G
Grip Ronin is offline   Reply With Quote
Old 11-28-2013, 10:04 AM   #134
Malt
Drives: 2015 WRX
Finally had a chance to go out and do a log since the fix. I can tell already this is going to be fun.
Malt is offline   Reply With Quote
Old 12-05-2013, 12:08 PM   #135
TM
TM's Avatar
Drives: DGM BRZ 6MT
ECU tuning and data logging is all very new to me, but I love learning and it interests me. I just got an OpenFlash tablet and have been playing around with it.
I have a couple of questions that I couldn't find clear answers from anywhere.
When I data log my pulls, it should be under WOT in 3rd gear? Does it show me everything I need vs. doing pulls in 2nd or 4th gear?
What happens if I do pulls only in partial throttle? Can I still analyze the data with partial throttle pulls?
I've been reading and learning a lot about ECU tuning and optimizing. Unfortunately, I haven't really found one place that answers it all. If anyone have any resources that are good for learning, it will be much appreciated.
TM is offline   Reply With Quote
Old 12-05-2013, 01:40 PM   #136
StormTrooper
StormTrooper's Avatar
Drives: Pavement MT GR86
Nasioc has a good section...written years ago so It's been looked over.
The targets won't be same but the method and what to look for and monitor should be. No boost but otherwise it's the same style ecu and the same people are tuning the cars.
GR86 MT premium
StormTrooper is offline   Reply With Quote
The Following User Says Thank You to StormTrooper For This Useful Post:
TM (12-05-2013)
Old 12-05-2013, 01:54 PM   #137
Rombinhood@OpenFlash
Drives: FRS
FYI, the guys at Vishnu are working on a nice video tutorial on how to conduct, view and analyze datalogs. Their existing video tutorial on the subject was BMW specific (but still useful):
[ame]http://youtu.be/wlEfyKIlWdg[/ame]
This new one will be specific to the GT86. So it should help those who are absolutely new to this kind of stuff. I'll post it up when it is ready
Rombinhood@OpenFlash is offline   Reply With Quote
The Following 2 Users Say Thank You to Rombinhood@OpenFlash For This Useful Post:
TM (12-05-2013), Tromatic (12-06-2013)
Old 12-05-2013, 07:02 PM   #138
StormTrooper
Anyone know what the target wot AFR is for stg1?
I seem to be about 11.7-12.2 which seems on the rich side but idk.
Also if KC learned is adding timing how do I tell if it's pulling say fine knock learning or something??
GR86 MT premium
Old 12-05-2013, 08:46 PM   #139
Sterling Doc
Drives: 2002 911 Targa
Did my first datalogging data zap today.
I am not tech geek, and it was easy.
1)Hit "start" while in the OFT realtime datalogging window
2)Run through the gears at WOT
3)Hit "stop"
4)Connect OFT to OF Manager
5)Open datalogging
6)Click Export
7)Go to Datazap website & upload file
8)Graph shows up with RPM only
9)Click on the labels to add that parameters you want to see (AFR, LTFT, etc.)
10) Click the little page icon in the upper right corner of the graph to save the current screen as a pic
11)Upload to your preferred photosite for hosting
12)Link photo to here to post it up
Stage 2 E85 run on stock car:
Overall, my car looks pretty happy with AM at 1.0 & KC learned in 5's. The AFR's are rich - lower mid 11's. It's 21 degrees out, and my only mod is a K&N filter - so it my car my not be flowing quite enough air for the stage 2 E85. I would think the LTFT would go more negative with it running rich?
Sterling Doc is offline   Reply With Quote
The Following 4 Users Say Thank You to Sterling Doc For This Useful Post:
normancw (12-09-2013), Rombinhood@OpenFlash (12-05-2013), Tromatic (12-06-2013), zc06_kisstherain (12-11-2013)
Old 12-05-2013, 09:41 PM   #140
Kodename47
Kodename47's Avatar
Drives: UK GT86
@StormTrooper to be able to compare you need to do a couple of consecutive 3rd gear pulls or higher over the flattest run you can find. This is done to generate decent loading on the engine. Watch the overall ign timing or knock learned value, if at any point it's not consistent then it's pulling timing slightly. If the values are perfectly consistent in every run then there's no timing being pulled.
Remember that the ECU wont pull the IAM down unless it sees repeated knock conditions. The consistency of ign timing on decently loaded WOT pulls is a much better indicator. This isn't so easy to indicate partial throttle issues though.
@Sterling Doc don't forget that the LTFT's are not added to when running open loop (ie. WOT). They are only affected by consistent STFT during closed loop conditions.
.: Stealth 86 :.
Kodename 47 DJ:
The Following 2 Users Say Thank You to Kodename47 For This Useful Post:
normancw (12-09-2013), Sterling Doc (12-05-2013)
OpenFlash Tablet Rombinhood@OpenFlash Software Tuning 1838 07-29-2023 06:35 PM
Openflash Tablet v1.31 beta maps (including Stage 2!) now available for download Shiv@Openflash Software Tuning 354 02-08-2015 05:23 PM
Is Openflash tablet detectable? Boofneenee Software Tuning 25 05-02-2014 10:03 PM
***VISHNU OpenFlash Tablet IN STOCK*** Garrett@Openflash Engine, Exhaust, Bolt-Ons 15 12-17-2013 01:30 PM
WTB Openflash Tablet Vlady Want-To-Buy Requests 0 10-25-2013 12:10 AM
