Old 11-26-2013, 10:08 PM   #127
charged86
charged86's Avatar
Jealous. :/
INSTAGRAM @Rcf_700 www.youtube.com/boostindub
Old 11-26-2013, 10:40 PM   #128
OrbitalEllipses
Drives: Attitude
Originally Posted by Turbowned View Post
Damn, I've been sitting on my '13 Brembos for a month now, no $$ for powdercoat or rotors/pads Probably because I bought another car... lol
I swear every time you post it's "I bought this car, sold that car, my 4age blacktop" lol!
Old 11-27-2013, 12:48 PM   #129
Turbowned
Turbowned's Avatar
Yep, I have automotive ADD; bought 4 cars in the past 12 months and sold 2 of them. TL/DR it goes lke this: I owned an MR2 already, bought a 318is, bought a BRZ, sold 318is, bought an STi, sold the STi, bought an RS 6.
Old 11-27-2013, 05:23 PM   #130
SkAsphalt
Ridge Racerrrrrrrrr
SkAsphalt's Avatar
Just rolling in Swag
Old 11-27-2013, 05:35 PM   #131
chanomatik
Snow Don't Hurt!
chanomatik's Avatar
Blah. Took me long enough to find this thread. Some good stuff in here.
Old 11-27-2013, 05:55 PM   #132
OrbitalEllipses
Drives: Attitude
...you could have texted me, noob.
Old 11-27-2013, 05:56 PM   #133
chanomatik
Snow Don't Hurt!
chanomatik's Avatar
I wasn't actively looking. I was searching for TOM'S clear lens and this thread came up. I was like, "WTF?" so checked it out. Found you fools in here, so decided to join!
Old 12-15-2013, 11:16 AM   #134
mixcorp
Drives: brz
Nothing WRONG, but it's not right. Easier for most people to get 5x100 rotors then get rotors drilled. Anyhow, most good STI rotors are dual-drilled except trusty Centric blanks.
Some minor notes:
04-current for front caliper. The shape hasn't changed in 10 years.
04 rotor if you don't want to drill, 05-current if you're okay getting it drilled (as I said most STI rotors will be dual-drilled anyhow).
IF I GET 08 STI FRONT AND REAR CALIPER AND ROTOR- DRILLED TO 5X100- ITS OK?
mixcorp is offline   Reply With Quote
Old 12-15-2013, 11:23 AM   #135
Vten
Drives: Too heavy
^ YES ITS OKEY !!
Vten is offline   Reply With Quote
The Following User Says Thank You to Vten For This Useful Post:
OrbitalEllipses (12-15-2013)
Old 12-15-2013, 09:03 PM   #136
OrbitalEllipses
Drives: Attitude
Originally Posted by Vten View Post
^ YES ITS OKEY !!
Indeed.
Old 12-31-2013, 02:14 PM   #137
Figo
Figo's Avatar
Drives: Vortech Supercharged FR-S
Anyone know what brake line I should get for 08+ front brembo?
Stoptech told me that the FR-S/BRZ lines are 5'' longer that STI 08 lines.
So I can use both.
But Which one that you guys recommend?
lol
I'd rather lose by a mile because I built my own car,
than win by an inch because someone else built it for me.
Your car is your story, so don't let someone else write the book.
( White Tiger ) - FiGo's 車誌.
Figo is offline   Reply With Quote
Old 12-31-2013, 02:32 PM   #138
Vten
Drives: Too heavy
I believe the 08+ are basically the same as the 04-07s .
I use the stoptech lines , they're barely long enough, but works just fine .
Old 12-31-2013, 02:47 PM   #139
OrbitalEllipses
Drives: Attitude
Use BRZ lines, that's what I'd do.
chanomatik (01-01-2014)
Old 01-02-2014, 09:52 AM   #140
swift996
swift996's Avatar
I wish I knew this kit was this easy, I still might go to it down the road. The pad surface area you can get out of this kit is ridiculous compared to most other kits out there.
Just to make sure I have this correct:
Fronts:
Rotors: 328x30mm (Pads: 132mm x 78mm)
Rears:
Rotors: 316x20mm (Pads: 77mm x 62mm)
Front Pads:
Rear Pads:
It also looks like there are quite a few pre-drilled 5x100/5x114 rotors available. It seems like going two piece would easily fix that issue too. I saw a road test (believe by motor trend) that had the STI stopping from 60-0 in 109ft. That's pretty solid and a 600lb heavier car. I'd love to feel the force of these on a BRZ/FRS with track pads/ss lines. I've been impressed by my set up and very impressed by the AP Racing kit. This STI swap seems like a nice option for the price point.
2010 Cadillac CTS-V Sedan M6 w/550whp (Build Thread)
swift996 is offline   Reply With Quote
will the sti brembos fit fr-s/brz? driver01 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 51 04-12-2014 02:25 PM
Those Brembos, fixed caliper? Or not? [Patent inside!] madfast Suspension | Chassis | Brakes -- Sponsored by 949 Racing 155 12-08-2011 02:06 PM
