Drives: 2024 GR86/ 2015 FRS
Whiteline 20mm front bar
I installed the Whiteline 20mm front sway bar and end links.
Remove bottom covers ![]() and a clip on the side ![]() Then remove the two frame supports that hold the bar. ![]() ![]() Remove the brackets that hold the bar on, instal them on the new bar bushings, remove the nuts holding the end links to the struts, and install evrything in reverse. ![]() ![]() It weighs 1.8lbs more total then the stock parts. Simmons
2024 GR86 71 STR/ 2015 FRS 71 STX
Sponsors Xero-Limit//Karcepts |
| The Following User Says Thank You to Simmons For This Useful Post: | Ninjin (01-26-2013) |
#2 |
AutoX-10/10ths every run
Looks good. I've got the same one on my car. Made a nice difference along with the RCE springs I put on at the same time.
Question, where did you put the washers on the lower endlink mount to the swaybar? I got the Whiteline adjustable ones and the directions were kinda vague. I initially had the washers between the endlink and the bar, with just the nut on the outside. This configuration had problems as the movement would loosen the nut on the driver's side. After about 2 weeks of re-tightening the nut after hearing noises from the front end I moved the washer to the other side of the swaybar behind the nut. No issues so far in this configuration.
#3 | |
Simmons
#4 | |
#5 |
Curious cat.
Drives: 86 GT base M/T - Red
Handling impressions? What's your setup?
2013 Toyota 86 GT M/T
2009 Renault Clio Sport R27 Team F1 Edition (sold) 1991 Mazda MX5 Miata (sold) 2007 Mitsubishi Evo 9 RS (sold) 2006 VW Golf R32 (sold) |
#6 |
Drives: SWP BRZ 6MT
Thanks for the post! I have a feeling this will come in handy when I'm installing mine next weekend.
Sent from my Nexus 10 using Tapatalk HD |
#7 |
My normal setup is KW V 3's, Dunlop ZII's in 255's, -4 camber front -2.5 rear.
Right now for the winter I have the stock suspension and tires on, I didn't get a chance to see how it handles with the snow/ crap on the roads. Simmons
#8 |
I've had the Whiteline bar installed as well and the washers were installed on the link side of the bar. I didn't have any problems with those nuts coming loose at all.
I have the Strano bar installed now, I think it's somewhere in the middle of the two settings on the Whiteline bar. I'm still using the WL endlinks with the Strano bar with the same washers/nuts and nothing has come loose after several weeks. |
| The Following User Says Thank You to xwd For This Useful Post: | whataboutbob (01-27-2013) |
#9 |
Drives: '13 FR-S
Any opinions on this yet? I put mine in a few weeks ago, but haven't had a chance to drive the car hard enough to tell. Weather in the Midwest and all...
#10 | |
Simmons
| The Following User Says Thank You to Simmons For This Useful Post: | funbeatsfast (02-03-2013) |
#11 |
Drives: Crystal black BRZ
No need to support the engine once those support mounts are removed?
#12 |
Drives: 2005 Toyota Camry
#13 |
Drives: 2013 Scion FR-S, Raven, Manual
Indeed, usually engines are supported by strange off worldly objects known to many as "motor mounts". They tend to be made of unobtanium as well.
| Whiteline Com-c top mounts | sw20kosh | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 349 | 05-27-2015 06:15 AM |
| Eibach 20mm spacers just put on! | SMOKETREES | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 10 | 12-18-2013 11:13 AM |
| Front LCA AVO vs Whiteline | Calum | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 46 | 01-08-2013 01:37 PM |
| Whiteline Front Strut Bar and Rear LCA | JoeBoxer | Brakes, Suspension, Chassis | 3 | 12-26-2012 02:52 PM |
| JRP- New Whiteline Suspension for BRZ/FR-S | Stav | CANADA | 0 | 10-23-2012 07:38 PM |
