Old 01-26-2013, 04:10 PM   #1
Simmons
Simmons's Avatar
Drives: 2024 GR86/ 2015 FRS
Whiteline 20mm front bar
I installed the Whiteline 20mm front sway bar and end links.
Remove bottom covers
and a clip on the side
Then remove the two frame supports that hold the bar.
Remove the brackets that hold the bar on, instal them on the new bar bushings, remove the nuts holding the end links to the struts, and install evrything in reverse.
It weighs 1.8lbs more total then the stock parts.
Simmons
2024 GR86 71 STR/ 2015 FRS 71 STX
Sponsors Xero-Limit//Karcepts
Simmons is offline   Reply With Quote
The Following User Says Thank You to Simmons For This Useful Post:
Ninjin (01-26-2013)
Old 01-26-2013, 04:49 PM   #2
whataboutbob
AutoX-10/10ths every run
Looks good. I've got the same one on my car. Made a nice difference along with the RCE springs I put on at the same time.
Question, where did you put the washers on the lower endlink mount to the swaybar? I got the Whiteline adjustable ones and the directions were kinda vague. I initially had the washers between the endlink and the bar, with just the nut on the outside. This configuration had problems as the movement would loosen the nut on the driver's side. After about 2 weeks of re-tightening the nut after hearing noises from the front end I moved the washer to the other side of the swaybar behind the nut. No issues so far in this configuration.
Build thread:Here
Old 01-26-2013, 05:04 PM   #3
Simmons
Simmons's Avatar
I have the washer on the link side of the bar. I guess that I will have to keep an eye on it. The nuts have plastic in the end to help from coming loose.
Simmons
Old 01-26-2013, 05:06 PM   #4
whataboutbob
Simmons
Yep. The nuts that I used were nylock too. Mine was making a clunking sound as the suspension articulated through what I think as the zero load point. Let me/us know if you experience this please.
Build thread:Here
Old 01-26-2013, 06:29 PM   #5
ultra
Curious cat.
ultra's Avatar
Drives: 86 GT base M/T - Red
Handling impressions? What's your setup?
2013 Toyota 86 GT M/T
2009 Renault Clio Sport R27 Team F1 Edition (sold)
1991 Mazda MX5 Miata (sold)
2007 Mitsubishi Evo 9 RS (sold)
2006 VW Golf R32 (sold)
ultra is offline   Reply With Quote
Old 01-26-2013, 07:26 PM   #6
Ninjin
Ninjin's Avatar
Drives: SWP BRZ 6MT
Thanks for the post! I have a feeling this will come in handy when I'm installing mine next weekend.
Sent from my Nexus 10 using Tapatalk HD
Old 01-26-2013, 07:59 PM   #7
Simmons
Simmons's Avatar
My normal setup is KW V 3's, Dunlop ZII's in 255's, -4 camber front -2.5 rear.
Right now for the winter I have the stock suspension and tires on, I didn't get a chance to see how it handles with the snow/ crap on the roads.
Simmons
Old 01-27-2013, 08:19 PM   #8
xwd
I've had the Whiteline bar installed as well and the washers were installed on the link side of the bar. I didn't have any problems with those nuts coming loose at all.
I have the Strano bar installed now, I think it's somewhere in the middle of the two settings on the Whiteline bar. I'm still using the WL endlinks with the Strano bar with the same washers/nuts and nothing has come loose after several weeks.
The Following User Says Thank You to xwd For This Useful Post:
whataboutbob (01-27-2013)
Old 01-30-2013, 09:12 PM   #9
funbeatsfast
funbeatsfast's Avatar
Drives: '13 FR-S
Any opinions on this yet? I put mine in a few weeks ago, but haven't had a chance to drive the car hard enough to tell. Weather in the Midwest and all...
funbeatsfast is offline   Reply With Quote
Old 01-30-2013, 09:29 PM   #10
Simmons
Simmons's Avatar
Not yet, crappy weather here too.
Simmons
funbeatsfast (02-03-2013)
Old 11-27-2013, 12:05 AM   #11
SubBrZ
Drives: Crystal black BRZ
No need to support the engine once those support mounts are removed?
SubBrZ is offline   Reply With Quote
Old 11-27-2013, 01:10 AM   #12
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
The engine doesn't sit on those brackets. Those brackets exist solely for the anti-roll bars.
-alex
Old 11-27-2013, 05:19 AM   #13
Zach3794
Drives: 2013 Scion FR-S, Raven, Manual
Indeed, usually engines are supported by strange off worldly objects known to many as "motor mounts". They tend to be made of unobtanium as well.
Zach3794 is offline   Reply With Quote
Whiteline Com-c top mounts sw20kosh Suspension | Chassis | Brakes -- Sponsored by 949 Racing 349 05-27-2015 06:15 AM
Eibach 20mm spacers just put on! SMOKETREES Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 12-18-2013 11:13 AM
Front LCA AVO vs Whiteline Calum Suspension | Chassis | Brakes -- Sponsored by 949 Racing 46 01-08-2013 01:37 PM
Whiteline Front Strut Bar and Rear LCA JoeBoxer Brakes, Suspension, Chassis 3 12-26-2012 02:52 PM
JRP- New Whiteline Suspension for BRZ/FR-S Stav CANADA 0 10-23-2012 07:38 PM
