Old 11-25-2013, 12:16 AM   #1
ahaghshenas
ahaghshenas's Avatar
Drives: Subaru BRZ
Coilover spring diameter vs OEM
Got myself new wheels and tires (18x8.5 48offset - 245/35/r18) and my calculations were all wrong, the front wheels rest against the front spring.
How much space will I regain if I was to install coilovers?
ahaghshenas is offline   Reply With Quote
Old 11-25-2013, 12:49 AM   #2
hanabie
hanabie's Avatar
Drives: WRB LMTD '13
plenty! whats ur offset?
hanabie is offline   Reply With Quote
Old 11-25-2013, 03:50 AM   #3
ahaghshenas
Drives: Subaru BRZ
The offset is 48
Old 11-25-2013, 06:56 AM   #4
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
Why would fitting coilovers alter the wheel clearance?
Old 11-25-2013, 08:01 AM   #5
86•BRZ
86•BRZ's Avatar
Drives: 86 GTS
because the wheels sit directly next to them... and they touch if the wheels are too big or if there is too much positive offset.
86•BRZ is offline   Reply With Quote
Old 11-25-2013, 08:36 AM   #6
ahaghshenas
Drives: Subaru BRZ
I measured the diameter of the OEM front spring it was about 12cm. The diameter of aftermarket coilover springs are significantly smaller, which should give more clearance.
With stock wheels the gap from the OEM spring is just under 20mm. The wheel setup I choose has moved the tire innerwall around 15mm closer and it touches.
I know I could use spacers and it will be sorted, but there not that cheap and I plan to get coilovers eventually. If the coilovers will sort out the issue I will order them now, but dont want to buy them to find out I still need spacers??
Any input welcome
Old 11-25-2013, 09:45 AM   #7
neurokinetik
neurokinetik's Avatar
Drives: 2013 Scion FR-S Firestorm
On the KWs, I gained at least 10, if not 20mm of clearance over the stock pieces. With 17x9 wheels, 42 offset, and 245/40 Hankook RS3s, I only had only about enough room to fit a credit card between the spring perch and the tire. Obviously, adding any camber at all would put the tire up against the perch. Due to the width and offset difference of our wheels, you should in theory have about 6mm more clearance than I did with the stock springs and struts.
neurokinetik is offline   Reply With Quote
Old 11-25-2013, 10:53 AM   #8
BlueDubbinTDI
BlueDubbinTDI's Avatar
Drives: 2013 FR-S, 2012 MCS
Get wheel spacers
The Following User Says Thank You to BlueDubbinTDI For This Useful Post:
hanabie (11-25-2013)
Old 11-25-2013, 11:12 AM   #9
hanabie
hanabie's Avatar
Originally Posted by BlueDubbinTDI View Post
Get wheel spacers
What he said. Try 10mm.
Sent from my SGH-T999 using Tapatalk
Old 11-25-2013, 12:32 PM   #10
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
Roughly this much:
-alex
The Following 2 Users Say Thank You to mav1178 For This Useful Post:
Captain Snooze (11-25-2013), jmark (01-29-2018)
Old 11-25-2013, 01:26 PM   #11
djdnz
1337
Drives: 2013 BRZ WRB S/C
It's a pretty huge difference. With my wheels I had about 1-3mm clearance with stock suspension. With my RCE T0's (mostly the same as KW V1) I can fit my hand sideways between the wheel and the coils now.
djdnz is offline   Reply With Quote
The Following User Says Thank You to djdnz For This Useful Post:
jmark (01-29-2018)
Spring/Coilover advice canuckbrz Suspension | Chassis | Brakes -- Sponsored by 949 Racing 11 06-16-2013 08:09 PM
Coilover Spring Length Tirewarmer Suspension | Chassis | Brakes -- Sponsored by 949 Racing 4 05-17-2013 01:39 PM
To coilover or spring? That is the question... Knightmare Suspension | Chassis | Brakes -- Sponsored by 949 Racing 21 01-13-2013 11:34 PM
Front Spring Diameter Captain Snooze Suspension | Chassis | Brakes -- Sponsored by 949 Racing 2 12-17-2012 01:06 PM
