CANADA Canada
Old 11-22-2013, 09:37 AM   #85
Suberman
Drives: Subaru BRZ Sport Tech Satin White
Originally Posted by daftpunk View Post
Would anybody be able to advise me if these winter tires are too worn to run the FRS?
I have a set of Gislaved Nordfrost 5s sitting at home (my dad's old winters) and a quick toonie test showed about 70% tread on two of em, and about 50% with the other two. Budget is tight currently, and if I could avoid buying new winters for at least this winter, it would help. I commute between Sauga and Oakville so I don't usually encounter too much snow on the ground.
You need 5-6 mm of tread remaining to get any grip in snow. That's about 7/32.
For packed snow or ice you can still get decent grip down to 4 mm or 5/32 but then they're worn out.
50% tread remaining would be just barely enough. Put those on the front.
If the snows are five years old they're junk no matter how much tread is left because they won't grip on ice. The rubber goes too hard after about five years on the car or in the garage.
However, even old worn out snow tires are better than leaving summers on.
Suberman is offline   Reply With Quote
The Following User Says Thank You to Suberman For This Useful Post:
daftpunk (11-22-2013)
Old 11-22-2013, 05:02 PM   #86
Captain Stall
OK, here we g...oh, wait
Captain Stall's Avatar
Drives: '13 Hot Lava 6M
Originally Posted by TONYpepperon1 View Post
OK well then can someone recommend a set of snow tires for cheap?
TireRack.com has Goodyear Ultra Grip Winter (205/55R16) for $87 each, with a $40 MIR on a set of 4. Their cheapest in OEM size is the General Altimax Arctic at $114 each.
HTH. Best of luck this winter.
Captain Stall is offline   Reply With Quote
The Following User Says Thank You to Captain Stall For This Useful Post:
TONYpepperon1 (11-23-2013)
Old 11-23-2013, 11:44 AM   #87
Suberman
General is another Continental company. Great tires.
The Following 2 Users Say Thank You to Suberman For This Useful Post:
TONYpepperon1 (11-23-2013), ZionsWrath (11-23-2013)
Old 11-23-2013, 09:13 PM   #88
daiheadjai
daiheadjai's Avatar
Drives: 2003 S2000, 2008 Fit
Can we actually get Tire Rack stuff here?
Seems like once you factor in shipping and taxes, it might not be the same picture.
I'm on 16s now - for those on 17s/stock size, how are you finding it?
I noticed a little bit of squirm when rolling out, and the sidewall height definitely does not inspire cornering confidence (in the dry)
daiheadjai is offline   Reply With Quote
Old 11-23-2013, 09:43 PM   #89
Captain Stall
I actually had to rewrite my post when I clued in to his location being NJ. At first I suggested prices from PMCtire.com.
Old 11-23-2013, 09:54 PM   #90
VirUzxZ
Drives: Black on Black on Black
and thus the winter driving begins... lol fishtailed out of my drive way and turned back around and parked, just ordered food instead lols
VirUzxZ is offline   Reply With Quote
Old 11-23-2013, 10:07 PM   #91
1Cor10:23
1Cor10:23's Avatar
Drives: '13 Whiteout FR-S (M/T)
Can't wait to get out there tonight...
Sent from my SGH-I317M using Tapatalk
1Cor10:23 is offline   Reply With Quote
Old 11-24-2013, 12:04 AM   #92
aSaki
I was out, and on my way home it started snowing like MAD lol I was still on my stock tires because I'm storing my car, I didn't know the snow would hit just like that! Man this car is tail happy indeed, i slowly get into 2nd gear at 2k rpm and i would still go side ways a lil, going into a right turn at like 15km and giving a lil gas u can start drifting lol
aSaki is offline   Reply With Quote
Old 11-24-2013, 12:20 AM   #93
Kazuya
Kazuya's Avatar
Drives: Takumi
brb going to empty parking lot tonight.
Kazuya is offline   Reply With Quote
Old 11-24-2013, 12:41 AM   #94
chenshuo
chenshuo's Avatar
Drives: WRB BRZ
it's not that our cars are tail happy, it's the stock summer tires. I got my Blizzak tire and today after some snow i purposely tried to slide but i couldn't. Blizzak worked like a champ in today's dump of snow.
chenshuo is offline   Reply With Quote
Old 11-24-2013, 12:45 AM   #95
daiheadjai
daiheadjai's Avatar
Wink
One suggestion: GO Train parking lots.
Old 11-24-2013, 12:47 AM   #96
daiheadjai
daiheadjai's Avatar
I have to say that TCS and VSC work great to keep the car safe and drama-free.
Even sudden mid-corner throttle stabs in 2nd-gear didn't get it out of shape.
Old 11-24-2013, 04:52 AM   #97
congee
congee's Avatar
Drives: SSM BRZ
Good to hear! Have a set of blizzak's ws70 that I still need to install.
Was driving around markham on residential roads and the tail would give out at 15-20kmph... It was fun and surprisingly easy to control.
Going on a main road with fresh layers of snow however was a different story. Won't be taking her out when it snows.
congee is offline   Reply With Quote
Old 11-24-2013, 11:15 AM   #98
Suberman
You're not trying hard enough. Try cranking a bit of lock on and then sneeze, you'll be 180 in no time.
I assume you have traction control fully off?
If traction control is on you'll just hit everything nose on....
7thgear rulz, kryptonite allergy, suberman cant drive
winter driving jmaryt Scion FR-S / Toyota 86 GT86 General Forum 88 11-11-2013 12:15 PM
Winter Driving Tip. NOHOME Scion FR-S / Toyota 86 GT86 General Forum 22 03-06-2013 06:38 PM
Practice winter driving 4U-GSE Scion FR-S / Toyota 86 GT86 General Forum 4 01-26-2013 11:29 AM
How many are planning on winter driving? NV Auto CANADA 109 01-11-2013 10:30 PM
winter driving paraguin BRZ First-Gen (2012+) — General Topics 25 08-03-2012 06:26 PM
