Old 11-22-2013, 10:11 AM   #57
tiz22
tiz22's Avatar
Drives: 2013 Scion FR-S (Raven) MT
I want to connect these to the PARKING wire instead of the power outlet wire....Does any one know where this wire is located? Everyone mentions it as an alternative but doesn't explain which wire it is.
My Car Journal: Raven FR-S w/ TRD Flavour
Click for my AVIC Z150BH Head Unit DIY Install
tiz22 is offline   Reply With Quote
Old 11-22-2013, 10:30 AM   #58
FR-Shadow
FR-Shadow's Avatar
Drives: 2013 Scion FRS
Its the side markers..Just look for the wiring from the side marker and tap into the power. There should only be 2 wires there, power and ground.
Originally Posted by kALMIGHTY View Post
Reviving an old thread, but if I want these to be on high power at all times, I only need to connect the red wire right? Is there a ground wire somewhere I still need to connect?
yes there should be a ground that you need to connect and yes for high power at all times only connect red
Also, where did you get the overlays for the LED's? I'll probably want to go stealth with mine as well.
Overlays as like tint overlays? Your best bet is to get in contact with bluebatmobile
FR-Shadow is offline   Reply With Quote
The Following User Says Thank You to FR-Shadow For This Useful Post:
tiz22 (11-22-2013)
Old 11-22-2013, 01:30 PM   #59
tiz22
tiz22's Avatar
And just for clarification, one DIY said to remove the 5amp fuse from the red power wire? I'm assuming this is terrible advice?
Old 11-22-2013, 01:34 PM   #60
FR-Shadow
FR-Shadow's Avatar
You caaaannnn do it. Just dont be pissed if you either blow fuses a lot if more than one thing is using that power or worse...you short the wiring.
So yes keep the fuse
tiz22 (11-22-2013)
Old 11-22-2013, 07:36 PM   #61
tiz22
tiz22's Avatar
Thanks...One last question - how do you access the side marker wiring from inside the engine bay? do you have a pic of it?
Old 11-23-2013, 09:44 AM   #62
FR-Shadow
FR-Shadow's Avatar
I dont think you can. You may be able to stick your hand down there but i dont know. The easiest way to probably do it is to pop out the sidemarker from outside the car.
Old 12-16-2013, 12:26 AM   #63
Knickstape
Knickstape's Avatar
Drives: '13 FR-S (Asphalt)
So I can't get them to power on at all. Do you think Toyota would be a good place to have them install
Opti-Guard, 35% Tint, Perrin 2" Antenna, Helix Side Markers, Valenti Tails, Carsmo Armrest, LED DRL Strip // UniChip, Perrin CAI & Inlet Tube, Perrin Cat-Back Exhaust, Grimmspeed Super-Loop Header.
Knickstape is offline   Reply With Quote
Old 12-16-2013, 12:59 AM   #64
Knickstape
Knickstape's Avatar
I forgot to quote you
Old 12-16-2013, 07:44 AM   #65
FR-Shadow
FR-Shadow's Avatar
Did you test them first by just touching power and ground to the battery? Maybe its a faulty set. But maybe some dealers are different than others. Doesnt hurt to ask. They will kill you with how much itll probably cost.
Knickstape (12-16-2013)
Old 12-16-2013, 03:32 PM   #66
Knickstape
Knickstape's Avatar
Didn't think about that for some reason haha. Do I just touch the power wire to positive and the ground to negative on the battery?
Old 12-16-2013, 03:55 PM   #67
FR-Shadow
FR-Shadow's Avatar
yes sir
Old 12-16-2013, 04:04 PM   #68
Knickstape
Knickstape's Avatar
yes sir
Thanks a ton. I don't wire much
Old 01-13-2014, 02:32 PM   #69
thien
Drives: Scion FRS
Thanks for all the help everyone! I had some trouble getting this to work, but if I had to do another one, it'd be 10x easier! I hooked the red wire to turn signal. Its probably easier than going through the glove compartment.
If you plan to go through the firewall, a quick tip for you is to tape the wire to the screwdriver and push the screwdriver through.
If you plan to do the signal wire, splice into the green wire if you want it on when you turn on parking lights. Tap into the pink wire if you want your drls to blink with the signals...
thien is offline   Reply With Quote
The Following User Says Thank You to thien For This Useful Post:
Parappa (09-10-2014)
Old 04-04-2014, 11:30 PM   #70
Chaetagnath
Drives: Whiteout FRS
Originally Posted by enouf View Post
Only one problem that I saw after the install was done - if I wanted to listen to the radio or connect the air compressor (from the tyre kit), then the DRL's stay on since the glovebox outlet turns on at ACC. Not too fussed since I don't listen to radio when parked but just a heads up to anyone thinking of tapping into the glovebox outlet.
So after having these on the car for a year, I decided I don't like having the lights on while I am just sitting in the car with the radio on. I installed it originally like the OP describes, and had tapped into the cigarette lighter behind the glove box. So, I hooked up a relay attached to the parking brake wire which interrupts the power to the led lights when the brake is engaged.
This is the wire I hooked into, it is just under the ebrake.
Here is the wiring diagram for what I did is attached
As you can see, there are several diodes and inline fuses. It may be overkill, but I am paranoid about shorting things out. Basically, when you pull up the ebrake negative signal allows the coil to be energized, which switches the power from 87a to 87, interrupting the power to the lights. Put the brake down, the coil loses energy and flips back to 87a, powering the lights again. It works like a charm. The diode there with the yellow wires prevents a spike when the coil collapses.
Chaetagnath is offline   Reply With Quote
