Old 11-21-2013, 10:02 PM   #85
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
Originally Posted by krulux View Post
Happy customer here. Wow. Huge grin on my face tonight. !!!
I ordered the OFT 2 days ago. It was delivered about an hour ago. After eating I downloaded the software, installed and patched win8.
I walked outside and Read the stock ecu map from the car. Came back in and and plugged the OFT into my machine. Opened the manager and it updated in a snap.
I pointed the Manager to my previously downloaded 1.34 Stage1 map and uploaded to the OFT.
Walked back outside and plugged the OFT in, followed the on-screen directions, and let it Write to the ecu. Total time was about 15min tops.
I started the car and let it idle for about 1.5 mins. Eased out onto the road and drove gently for about 10mins and let the temperature rise to normal.
By then I was out in the sticks/backroads. Long graceful curves for miles. I opened the throttle to full for several 3/4/5 gear pulls and I still can't get the grin off my face.
Sweet Mother - my little FRS pulls like a banshee now. Very nice rasp from 4K to 6.5k sweetening up to 7Kish gear shift with an excellent exhaust growl at the top.
I want to give you guys at Vishnu a round of well-earned applause .
Fantastic job!!!
The OFT tablet looks to easily be the best upgrade my lil Whiteout FRS has seen thus far. I am very happy with my purchase. Extremely happy.
Thanks guys!
I'm you are enjoying the OFT. We love seeing reviews like this. Thanks for taking the time to write it!
Shiv@Openflash is offline   Reply With Quote
Old 11-21-2013, 10:13 PM   #86
yuicebox
Drives: Asphalt FRS
I feel the exact same way. I'm still a bit disconcerted by the rasp /rattle noise right around 4k under hard acceleration. any thoughts on this @shiv@vishnu ?
Sent from my SAMSUNG-SM-N900A using Tapatalk
yuicebox is offline   Reply With Quote
Old 11-21-2013, 10:18 PM   #87
Shiv@Openflash
Drives: 2013 FRS
At 3800rpm, there is a big swing in VVT exhaust timing. It goes from 15deg to 40deg over the span of just 200rpm. This is to minimize the torque dip. And it can sound a little raspy during the changeover. Nothing to worry about though.
The Following 5 Users Say Thank You to Shiv@Openflash For This Useful Post:
Boofneenee (11-22-2013), DAEMANO (11-22-2013), normancw (11-21-2013), YMAA (11-21-2013), yuicebox (11-21-2013)
Old 11-21-2013, 10:25 PM   #88
yuicebox
Drives: Asphalt FRS
@shiv@vishnu once again your customer service is amazing man. Thank you so much. I'll have a proper review soon and I'll also put up a tutorial on launch control
The Following User Says Thank You to yuicebox For This Useful Post:
Garrett@Openflash (11-22-2013)
Old 11-21-2013, 10:42 PM   #89
jeebus
I like the sound. It gives the car some attitude
jeebus is offline   Reply With Quote
Old 11-21-2013, 11:15 PM   #90
krulux
Drives: 2013 Scion FRS
I like the sound of it... I feel an aggressive tune is much closer to the way the engineer(s) who designed the FA20 intended for it to run. It is music to my ears.
That said... I hope we get the thumbs up from Shiv soon for E85 use with the stock header. I'm sitting at about 1/2 tank of 93octane currently.
I'm about 20mins away from a station with E85 (at $2.85gal) and I am really looking forward to the difference the corn juice makes.
krulux is offline   Reply With Quote
Old 11-22-2013, 01:31 AM   #91
overlookedx
overlookedx's Avatar
Drives: 2015 WRB Limited
Ok so my tank is finally low enough that I can try the corn juice tomorrow. Only concern I have is for when I want to switch back to regular gas. Any suggestions for how to do that safely?
Superfast Jellyfish
overlookedx is offline   Reply With Quote
Old 11-22-2013, 01:46 AM   #92
Hanni_0176
Hanni_0176's Avatar
Drives: 2013 Scion FR-S 10 Series MT
Drive the car down until the low fuel light comes on, shut the car off, and reflash to the non-e85 map. Proceed to fill up with 93 (or 91 if you live in Cali).
EDIT: Just checked and you do live in Cali, so yea, 91.
Mods: K&N Air Filter - Open Flash Tablet (Stage 1 v1.55) - more to come!
Hanni_0176 is offline   Reply With Quote
The Following User Says Thank You to Hanni_0176 For This Useful Post:
overlookedx (11-22-2013)
Old 11-22-2013, 09:15 AM   #93
Boofneenee
Go-Kart Enthusiast
Boofneenee's Avatar
Drives: Toyota Scion FRS
Talking
Raspy? I am pretty sure you mean sexy
FRS
Current mods: K&N air filter, OFT, OFH, berk high flow cat front pipe, Q300 exhaust, lighter wheels
Boofneenee is offline   Reply With Quote
Old 11-22-2013, 09:25 AM   #94
R2
Just a quick note to everyone trying to drain their tanks down to get the highest E-85 concentration. We have 50L fuel tanks and of that I can confirm at least 45L of that is usable. When the gas light first comes on there is almost exactly 10L left in the tank (in my experience). So on 5L you should be able to comfortably go ~50km or 30mi.
I suspect there is more usable fuel than 45L but I haven't pushed past that yet so take caution.
R2 is offline   Reply With Quote
The Following User Says Thank You to R2 For This Useful Post:
normancw (11-22-2013)
Old 11-22-2013, 10:16 AM   #95
bee_are_zee
bee_are_zee's Avatar
Drives: GBS BRZ
So this thread has brought me out of lurking! I have had my OFT since they first came out and can say I love the thing. I can't wait to put the corn maps on (hopefully this afternoon). I'm running completely stock engine and exhaust so I will report what numbers I see. Also, any update on when we will have downloadable logs and not just live readings?
bee_are_zee is offline   Reply With Quote
The Following User Says Thank You to bee_are_zee For This Useful Post:
Old 11-22-2013, 10:21 AM   #96
bfrank1972
Drives: 2013 FR-S Argento
Also you can keep a spare fuel can in your trunk on your 'switch' trips to the fuel station. Good to have an E85 one and a gasoline one, that way if you over-do it you're not stranded.
The Following User Says Thank You to bfrank1972 For This Useful Post:
Old 11-22-2013, 11:33 AM   #97
jeebus
Downloadable logs are available as of yesterday.
The Following User Says Thank You to jeebus For This Useful Post:
Old 11-22-2013, 11:57 AM   #98
bee_are_zee
Drives: GBS BRZ
I was so busy trying to burn off all my gas that I didn't even notice. You have effectively made my motivation to stay at work drop to 0.
OpenFlash Tablet Rombinhood@OpenFlash Software Tuning 1838 07-29-2023 06:35 PM
Openflash Tablet v1.31 beta maps (including Stage 2!) now available for download Shiv@Openflash Software Tuning 354 02-08-2015 05:23 PM
Is Openflash tablet detectable? Boofneenee Software Tuning 25 05-02-2014 10:03 PM
OpenFlash Tablet Stage 1 v1.2 maps available for download Shiv@Openflash Software Tuning 31 10-31-2013 08:45 PM
WTB Openflash Tablet Vlady Want-To-Buy Requests 0 10-25-2013 12:10 AM
