Old 11-18-2013, 04:06 PM   #1
mid_life_crisis
Drives: FR-S 10 #103 AT
question: how to remove rear seatback?
I'm sure this is written up somewhere as part of a bigger write up, but I can't find it. Can someone please point me to it?
“Sex is like Bridge. If you don't have a good partner, you'd better have a good hand.” - Mae West
Papa said, "son there's a lot of evil temptations out there. Best to try 'em all so you know which ones to avoid."
mid_life_crisis is offline   Reply With Quote
Old 11-18-2013, 06:59 PM   #2
TylerLieberman
TylerLieberman's Avatar
Drives: '24 GR86
Fold down seat, pull bottom part of carpet covering the back of the seat up and discover a bracket with a bolt on it on each side. I belie it's a 10mm or 12mm. Unbolt them. Then pull the brackets off the metal tab you see next to the bolts and it'll come right off.
The bottom of the seats come off with the one bolt on each side and a metal clip to unhook which is super easy.
I just did this over the weekend and it took no more than 5 minutes from beginning to end.
The Following User Says Thank You to TylerLieberman For This Useful Post:
mid_life_crisis (11-19-2013)
Old 11-19-2013, 09:00 AM   #3
mid_life_crisis
Thanks. How do the snaps holding the carpet down work? They aren't popping free easily and I'm a little leery about breaking something.
Old 11-19-2013, 08:35 PM   #4
TylerLieberman
Drives: '24 GR86
They'll come off. Pull harder lol
Old 11-20-2013, 07:18 PM   #5
mid_life_crisis
Now how does the center portion of the seat come out?
Old 11-21-2013, 09:29 AM   #6
infinite012
Drives: 13 DGM BRZ Ltd
Center portion of the seatback is integrated into the seatback. You can't remove it.
If you're talking about the divider between the seat bottoms, you can't remove it. It's the transmission tunnel.
infinite012 is offline   Reply With Quote
Old 11-21-2013, 06:04 PM   #7
mid_life_crisis
How thick is the pad? It looks worth taking out if you want to do something in that area.
Old 11-21-2013, 08:56 PM   #8
infinite012
You will need to clarify your questions more if you want help. Pictures would also help.
Old 11-21-2013, 09:27 PM   #9
mid_life_crisis
The piece that sits on top of the transmission tunnel. I want to take it out. I knew how to get the buckets out, now I know how to get the seatback out. Last bit is the piece sitting on the transmission tunnel.
Old 11-21-2013, 09:52 PM   #10
infinite012
That piece?
Old 11-22-2013, 08:58 AM   #11
mid_life_crisis
That piece?
That is it exactly. It looks like it extends a little under the center console and might have an attachment point under there. I really don't want to remove the center console if I can avoid it, although I have plans that will require it eventually. If it has to come out, I'll do as much prep work as I can and do both projects at once while it is out.
Old 11-22-2013, 09:08 AM   #12
infinite012
http://www.ft86club.com/forums/showthread.php?t=25957
You need to remove rear seat bottoms and center console, then pop out 2 tabs to pull that piece out.
The Following User Says Thank You to infinite012 For This Useful Post:
mid_life_crisis (11-22-2013)
Old 11-29-2013, 09:52 PM   #13
mikepaul21
mikepaul21's Avatar
Drives: 2013 Subaru BRZ
do you guys know how much the rear seats weigh?
mikepaul21 is offline   Reply With Quote
Old 12-01-2013, 05:16 PM   #14
jm1681
Drives: MKVI VW GTI
15lbs for the seat back, and about 3lbs each for the bases.
jm1681 is offline   Reply With Quote
How-To: Remove Rear Deck & Third Brake Light Moshpit37 DIY (Do-It-Yourself) Guides 63 08-01-2020 09:48 PM
[Question] How to remove stains from rustproofing i_4got Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 1 05-01-2013 04:59 AM
Best way to remove the Scion Rear Bumper Applique? Tim_Asphalt_FRS Cosmetic Modification (Interior/Exterior/Lighting) 28 12-25-2012 01:30 AM
will polishing your car to remove swirls remove opti-coat? bacon_cheese_beer Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 11 10-25-2012 10:41 PM
TRD Rear Lip question/opinion DC-FRS Cosmetic Modification (Interior/Exterior/Lighting) 2 08-18-2012 01:50 PM
