Old 11-20-2013, 06:07 PM   #1
FullBlown
FullBlown's Avatar
Drives: Scion FRS
Motec M1 Plug N Play
After months of waiting, we are very excited to have been given the opportunity to test m150 ecu for the FRS/BRZ.
We know this setup won't be necessary for most applications but for those who are looking to take it to the next level. You can't get any better than this.
MoTeC's M150 Toyota FT86 / Subaru BRZ plug-in kit is a fully programmable direct replacement for the factory-fitted
ECU.
No rewiring is necessary, the kit plugs into the stock wiring harness using the original sensors and fuel system. All
original functions are maintained.
Key advantages to the new M1 solutions are:
• Fully integrates with all original systems, including Direct Injection, Stability, Dash, Power Steering, ABS,
Airconditioning, and Alternator control.
• Pre-configured sensor calibrations for Original Equipment (OE) sensors and engine triggers.
• Pre-configured control of Port and Direct Injectors with a tuneable balance table.
• Pre-configured FT86 Reference Mode for Engine Speed, Ignition Timing, and control of 4 camshafts with tuneable
Inlet and Exhaust cam timing tables.
• Pre-configured On-board Knock for each cylinder with 2 OE knock sensors and selectable centre frequency
• Pre-configured physical settings for Engine Displacement, Fuel Density, Stoichiometric Ratio, Fuel Pressure, and
Injector Linearisation allow for simplified engine start-up prior to tuning
• Pre-configured CAN messaging for OE systems including ABS / Stability, Dashboard, and Power Steering.
• Pre-configured control of OE coolant fans with 3 temperature thresholds
• Pre-configured transient fuelling compensation using physical modelling of Fuel Film Deposit for Port and Direct
injectors.
• Pre-configured Wheel Speed detection via CAN from OE ABS system, allowing Gear Detection via engine speed /
wheel speed estimate
• Configurable Boost control for a single turbo
• Configurable Anti-Lag for single turbo variants with Ignition Timing Limit, Fuel Volume Trim, Ignition Cut, Engine
Speed Limit, Boost Aim and Throttle Aim tables
• Gearbox position detection via sensor or engine speed / wheel speed estimate
• Gearbox shift request via Up Shift Switch / Down Shift Switch or Gear Lever Force sensor
• Gearbox Shift Control with Ignition Cut and Engine Speed matching
• GPS acquisition and logging via CAN or RS232 (hardware dependant)
• Intercooler Temperature and Spray control
• Lap Distance, Time and Number via BR2 or Switched Input, with Split and Sector options
• Configurable Launch Control with tables for Launch Engine Speed vs. Vehicle Speed, Launch Throttle Limit vs.
Vehicle Speed, Launch Boost Aim vs. Vehicle Speed, and Launch Fuel Volume Trim vs. Vehicle Speed.
• Race Time system with tables for Ignition Timing Compensation, Fuel Mixture Aim, Boost Limit, and Throttle
Limit.
• Auxiliary Timer system with tables for Ignition Timing Compensation, Fuel Volume Trim, and Fuel Mixture Aim
• Engine Load Average channel with tables for Engine Speed Limit, Ignition Timing Trim, Fuel Mixture Aim, Boost
Limit, and Throttle Limit
• Engine Run Time Total for engine hour logging
• Configurable Security for multiple users with differing access options
• ECU CAN Receive from a defined ID Base Address for data reception from MoTeC devices
• 4 Configurable Driver Switches and 4 Driver Rotary Switches with each of 9 positions simultaneously mappable to
Launch Control, Pit Switch, Anti-Lag, Traction, Auxiliary Time, Race Time Reset, Gear Automatic, Engine Speed
Limit Maximum, Throttle Pedal Translation, Fuel Volume Trim, Ignition Timing, Fuel Mixture Aim, Boost Limit,
Traction Aim, and Traction Control Range.
• Analogue Tachometer output with configurable Output Pin and scaling
• Transmission Pump output with Transmission Temperature threshold and hysteresis control.
• Traction Control with tables for Aim Main, Aim Compensation, Control Range.
• 4 Optional Outputs for PWM Control of added actuators:
• Duty Cycle tables using Engine Speed and Throttle or Manifold Pressure Axes
• Activation based on Inlet Manifold Pressure or Throttle Position
• Aux Output 1 includes tables for Ignition Timing Compensation, Fuel Volume Trim, and Fuel Mixture Aim
• Optional channels for additional sensors via input pin and/or CAN message, including:
FullBlown is offline   Reply With Quote
The Following 31 Users Say Thank You to FullBlown For This Useful Post:
armythug (11-20-2013), Bach415 (12-09-2013), clayrush (12-06-2013), Dipstik-sportech (11-20-2013), Drift-Office (11-20-2013), EmeraldMalta (11-21-2013), Frs300 (11-20-2013), FTEIGHTSIX (11-21-2013), hmong337 (11-21-2013), humanshield (11-23-2013), mack4477 (11-21-2013), mad_sb (12-10-2013), mobybrz (11-21-2013), Mr. (11-20-2013), mrk1 (11-20-2013), pmccut (11-20-2013), PRORICAN (11-20-2013), roddy (11-22-2013), rusty959 (11-21-2013), Sellout (11-20-2013), Shiv@Openflash (11-20-2013), Silverpike (11-21-2013), SirBrass (11-21-2013), Sithspawn (11-22-2013), SmsAlSuwaidi (11-20-2013), Sportsguy83 (11-20-2013), SubiePig (11-22-2013), Team STILLEN (11-21-2013), tech4pdx (11-20-2013), tg_1981 (11-21-2013), WHITE (11-22-2013)
Old 11-20-2013, 06:10 PM   #2
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
That's a great standalone
Shiv@Openflash is offline   Reply With Quote
Old 11-20-2013, 06:12 PM   #3
bakerr6
Drives: 2013 raven black fr-s
agreed, but too much money for me. There is another shop I believe that will either be using this or the haltech unit. I'll let them chime in when they finish their project.
bakerr6 is offline   Reply With Quote
Old 11-20-2013, 06:23 PM   #4
SmsAlSuwaidi
Boosted
SmsAlSuwaidi's Avatar
Drives: Not a supra....yet
Originally Posted by shiv@vishnu View Post
That's is the GREATEST standalone
Fixed that for you
This is for sure going on my build when i get a built block.
God i always wanted a Motec on what ever car i had
The Following User Says Thank You to SmsAlSuwaidi For This Useful Post:
Old 11-20-2013, 07:50 PM   #5
FullBlown
FullBlown's Avatar
Drives: Scion FRS
We will post results as soon as we can.
The Following 3 Users Say Thank You to FullBlown For This Useful Post:
Dipstik-sportech (11-20-2013), Frs300 (11-20-2013), SmsAlSuwaidi (11-20-2013)
Old 11-20-2013, 10:22 PM   #6
Dipstik-sportech
Dipstik-sportech's Avatar
I knew I should've left my car there last time lol.
Old 11-20-2013, 10:29 PM   #7
tech4pdx
Make love
tech4pdx's Avatar
Drives: H8R.. Not really
Oh god..please..no. *slowly opens wallet*
tech4pdx is offline   Reply With Quote
Old 11-20-2013, 11:01 PM   #8
pixel67
pixel67's Avatar
Drives: 13 Asphalt FRS AT
And realizes it's empty after the last round of "feeding the obsession". Can't wait to see this installed!
pixel67 is offline   Reply With Quote
The Following User Says Thank You to pixel67 For This Useful Post:
tech4pdx (11-21-2013)
Old 11-20-2013, 11:08 PM   #9
trigger happy
Bang Bang
trigger happy's Avatar
Drives: 2013 Raven FR-S
Ballin
Raven 6MT//Injen CAI//VDS UEL//Invidia N1//OFT//ST Coilovers
trigger happy is offline   Reply With Quote
Old 11-21-2013, 12:28 AM   #10
tech4pdx
Make love
tech4pdx's Avatar
It's always empty. Wallet is symbolism for that Armageddon chip in my arm.
Old 11-21-2013, 12:30 AM   #11
mrk1
Drives: Sterling BRZ Ltd
That's awesome
The Build Thread
GT28RS - eBoost2 - 3.91 Final Drive - Supra LSD
mrk1 is offline   Reply With Quote
Old 11-21-2013, 12:39 AM   #12
jamesm
i know i don't need this, but i want it. added to my wish list .
The Following User Says Thank You to jamesm For This Useful Post:
SmsAlSuwaidi (11-21-2013)
Old 11-21-2013, 12:55 AM   #13
Jesse@JDLAutodesign
Jesse@JDLAutodesign's Avatar
Drives: 2013 Raven Black FRS
Anyone want an aem series 2 ems with plug and play harness?!? :P
Jesse@JDLAutodesign is offline   Reply With Quote
Old 11-21-2013, 01:25 AM   #14
Frs300
Frs300's Avatar
Drives: Pile of junk
if you want to give it to me for free
Frs300 is offline   Reply With Quote
FS: Oil Pressure gauge (includes Block galley plug for free!) True plug and play! Sportsguy83 Engine, Exhaust, Bolt-Ons 10 08-30-2013 11:53 AM
Plug & Play Flash Modules ECUtrav Engine, Exhaust, Transmission 27 02-06-2013 03:27 PM
ECU Plug and Play Mo707 Engine, Exhaust, Transmission 8 08-26-2012 12:21 PM
HID Plug 'n Play Kit JW89225 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 24 07-31-2012 01:17 AM
Which hid plug n play kit? huma Cosmetic Modification (Interior/Exterior/Lighting) 11 07-21-2012 12:10 AM
