Old 01-29-2013, 10:23 PM   #1
ECUtrav
Drives: 2013 Whiteout Scion FR-S
Plug & Play Flash Modules
I've owned a Hyundai Genesis Coupe 2.0T and 2012 Mustang GT and both had plug 'n play flash modules available. PowerAxel manufactures the module for Hyundai vehicles and SCT/Bama Tuning for the Mustangs. I don't know if any of you are familiar with those devices, but it would be great to get one for the BRZ/FR-S.
You simply plug it into the OBD port and load a particular tune, while still having the option to set the ECU back to stock settings.
Has anyone heard anything on a product like this for our cars?
ECUtrav is offline   Reply With Quote
Old 01-29-2013, 10:37 PM   #2
Tansey86
Tansey86's Avatar
Drives: 2003 Subaru Outback
An Accessport from COBB is what we would use, if they made one, but I dont believe they are.
Tansey86 is offline   Reply With Quote
Old 01-29-2013, 10:39 PM   #3
Xdragonxb0i
Drives: ex500r
Dont take my word for it.
But i though you could copy the stock map, and save it for a later use with ecutek.
Also i think you can save up to 4 maps on it to switch between.
Xdragonxb0i is offline   Reply With Quote
Old 01-30-2013, 09:24 AM   #4
Frostyman
Drives: 2013 Raven FRS
You are correct, you can do that with your ecutek cable.
Frostyman is offline   Reply With Quote
Old 01-30-2013, 10:31 AM   #5
Books
Books's Avatar
Drives: Ultramarine FR-S (MT)
Yes, with EcuTek you can but it's not as easy to use like what OP mentioned or AccessPort.
Books is offline   Reply With Quote
Old 01-30-2013, 11:04 AM   #6
Foobar
SLO NO MO
Foobar's Avatar
What's the method for backing up the stock ECU Flash using ECUTek?
Old 02-05-2013, 01:16 PM   #7
wWaldo
Drives: Asphalt Frs
I had a genesis and was looking for the same thing... plug and play
wWaldo is offline   Reply With Quote
Old 02-05-2013, 02:27 PM   #8
industrial
Add lightness!
industrial's Avatar
Drives: 17' WRX
I'm hope something like that is coming. All we have so far is ecutek and unichip. Which isn't too bad considering this a new car that's been out less than a year.
industrial is offline   Reply With Quote
Old 02-05-2013, 03:19 PM   #9
mad_sb
Drives: 2013 Asphalt FR-S
You don't really "back up" the stock rom with EcuTek, but you can flash in a stock rom at any time.. just need to know which rom was in your ecu before you flashed in an tuned map.
Old 02-05-2013, 03:26 PM   #10
Foobar
SLO NO MO
Foobar's Avatar
OK yeah that I knew. I had heard someone else mention they could back up the stock flash with ECUTek so I thought I'd ask because I wanted to get the latest flash that the dealers were using after that TSB Recall and I only had the stock ROM provided to me prior to that. After I asked this question, I have since received the correct stock flash.
Old 02-05-2013, 03:54 PM   #11
xjohnx
Grip>Slip
xjohnx's Avatar
You can backup the stock rom with ecutek if you so desire. just use the read rom feature.
Old 02-05-2013, 05:24 PM   #12
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
I did not see any read rom feature on my EcuTek software. Perhaps the Tuner version of the software allows you to do that.
Old 02-05-2013, 05:35 PM   #13
xjohnx
Grip>Slip
xjohnx's Avatar
I don't have mine handy but i could have swore it was on the same page that you program the ECU from. Perhaps you have to query it first. Either way, anyone you buy a tune from will supply you with the OEM rom, so it's not really an issue.
Old 02-05-2013, 08:22 PM   #14
xwd
Yeah I don't think on the base user software there is a read rom function...but you can flash with the base rom.
Are GT86 Headlights Plug and Play with FRS? tbwoodlee Cosmetic Modification (Interior/Exterior/Lighting) 93 03-01-2018 07:48 PM
ECU Plug and Play Mo707 Engine, Exhaust, Transmission 8 08-26-2012 11:21 AM
Xenon HID Conversion PLUG & PLAY jarviz Cosmetic Modification (Interior/Exterior/Lighting) 5 08-01-2012 05:34 PM
HID Plug 'n Play Kit JW89225 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 24 07-31-2012 12:17 AM
Which hid plug n play kit? huma Cosmetic Modification (Interior/Exterior/Lighting) 11 07-20-2012 11:10 PM
